Most trivial, make-or-break features
Results 1 to 21 of 21
    Jul 2008
    This is just for fun, but as I look at and research a new bike purchase, I find there are some really minor and/or trivial things that shouldn't be important to me, but are.
    For example, the Treks have the DuoTrap feature that neatly hides away a sensor. Also, their Blendr stem things.
    Also, the (now old) Roubaix had that totally odd seat post. Even if that was the perfect bike, I would have a hard time getting it because of that.
    So, what are your trivial, yet oddly-important-to-you things on a bike?
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    A sturdy kickstand is a "must have" for me. There is no way I'm going to just lean my uber-light carbon bike on the side of the wall like some cycling neophyte.
    Oct 2005
    Quote Originally Posted by Retro Grouch View Post
    Last weekend, after topping out on a long MTB trail and stopping for lunch, we laid our bikes down on the jagged limestone off of the trail. My friend made an interesting observation: we just laid $10k in carbon fiber bikes on the ground and at leas one has hidden compartments for electronic shifting batteries. Isn't it time for trigger-actuated stealth kickstands?
    Reputation: velodog's Avatar
    Sep 2007
    I have no need for a kickstand. Knowing that the bike will eventually fall over while using a kickstand, I just drop the bike to the ground when I get off, usually to the derailleur side.
    This had always worked as a kid and works just as well now, as an adult.
    Too old to ride plastic
    T K
    T K is offline
    wasssabi
    Reputation: T K's Avatar
    Feb 2009
    Too many logos. My last bike said Colnago on it like 16 times. Twice on the down tube and once on the head tube would suffice.
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    wind fairing.
    I used one for a year around 1981. kind of neat but I can live without.
    Faith is pretending to know things you don't know
    Never Give Up!
    Mar 2009
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    a real member's member
    Jul 2016
    Quote Originally Posted by lightning33 View Post
    the stuff hanging from my bikes must read, "Campagnolo."
    It would still work fine if it read "Suntour Cyclone" or something similar, but it just wouldn't feel right.
    Devoid of all flim-flam
    Reputation: Mapei's Avatar
    I'm crazed over where they put the holes for the water bottle holders.
    Mapie is a conventional looking former Hollywood bon viveur, now leading a quiet life in a house made of wood by an isolated beach. He has cultivated a taste for culture, and is a celebrated raconteur amongst his local associates, who are artists, actors, and other leftfield/eccentric types. I imagine he has a telescope, and an unusual sculpture outside his front door. He is also a beach comber. The Rydster.
    Banned forever.....or not
    Aug 2002
    For me, it's modern steel construction with a carbon fork. Threaded bottom bracket and a press in headset.
    Dogbert.
    I>U
    Reputation: Rogus's Avatar
    Nov 2010
    Bladed spokes. They just destroy the baseball cards way too quickly.
    Oct 2017
    Duotrap is kinda pointless these days.
    It's ANT+ only, and requires magnets on your wheel and crank.
    Modern sensors are 2 Channel BTLE as well as ANT+, and don't require magnets.
    Sep 2007
    Quote Originally Posted by Rogus View Post
    And they completely rule out balloons.
    Reputation: Fredrico's Avatar
    Jun 2002
    Internal cable routings.
    Reputation: PBL450's Avatar
    Apr 2014
    Bike weight. Because itís more important than aerodynamics.
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    'brifter' is f'ing stupid
    Quote Originally Posted by Fredrico View Post
    Poorly designed internal cable routing. Done correctly it's fine. Non-threaded bottom brackets. Shimano shifters that break cables/are harder than any other to pull hoods forward/are harder than any other to get a 5mm into the right spot to install. Di2 that needs near-constant updating. Bottle cages that completely block front derailleur mounting bolts. I'm sure there are more.
    #promechaniclife
    Jun 2002
    I feel your pain! We used to call it "Sh!tmano." We decided the Shimano designers were getting even with us for losing WW2. . Campy parts were a breath of fresh air, built to service. This apparently is still true.
    So Di2 has to be upgraded all the time? Forget it. Cables only have to be upgraded when they break, always at the clicks in the shifters. Down tube shifter cables break where they bend around the levers. Rider feels the breaks when reaching down and shifting, and replaces the cable in a couple of minutes, no adjustments necessary.
    Yes, non threaded BBs suck. Old style cup and cone are still the best. They're entirely serviceable. Threaded cartridges always fail sooner than cup and cone, IME. It's pretty obvious press fit BBs were a response to the fact carbon threads wouldn't hold. Aluminum inserts corroded and came loose, so they eliminated threads and went with "press fit." About the worst place to rely on press fit, so they try to make up for it with massive BBs.
    Well, good for the latest internal cable schemes. I've had nothing but problems. Sweat inevitably gets stuck in the holes, corrodes the aluminum, steel, or carbon tubing, teflon cable housing, and the old housing won't come out when you go to replace it. They've been around since the '80s at least. Plenty of reasons external cables haven't been relegated obsolete over 40 years. They're serviceable!
    Russian Troll Farmer
    Sep 2016
    You can always be "French", just turn on crank to bottom and lean the pedal against the curb....
    "L'enfer, c'est les autres"
    Nov 2009
    As I recall, Japan and Italy were both on the losing side in WWII.
    Reputation: Wetworks's Avatar
    Aug 2012
    Yup! That or positioning the rear tire at an angle to the object you intend to lean it against, steer front wheel same way, now you have 3 points of contact leaning in the same direction, just like a kickstand.
    Pretty much anything proprietary is no go for me.
    Seat post collar would be a good example of that as it applies to being seemingly trivial. (not to mention the seatpost itself which is a bit less trivial).
  1. What Are the 5 Trivial Things You Hate Most?
    By SystemShock in forum The Lounge
    Last Post: 02-04-2016, 01:45 PM
  2. What's the most trivial thing that kept you
    By FlynG in forum The Lounge
    Last Post: 10-19-2009, 01:01 PM
  3. Replies: 8
    Last Post: 10-12-2009, 01:45 PM
  4. This question might sound trivial and shallow, but...
    By rbmn9529 in forum Bikes, Frames and Forks
    Last Post: 07-24-2007, 05:58 AM
  5. Bottom bracket - most important features
    By cossington in forum Components, Wrenching
    Last Post: 02-11-2004, 01:07 PM
