MUCH higher power on one bike? - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Jul 2012
    It's not a theory. It's physics. Yes, about 1 watt. In the scope of this conversation, it's not "MUCH higher power" of 20 watts
    Yes
    Bike Calculator
    But part of the problem, albeit, a small part. Now factor in Stages % variance and the other things going on it all adds up. We don't know if the rpms, speed, gearing and tire pressure were all consistent etc. Perhaps the OP can post all the variables of the ride (i.e. rpms, speed, HR, temperature etc.) besides watts and we will have a better picture to go off other than just watts. Was everything exactly the same; I highly doubt it. There are many things that can affect a ride and we are only working with 1 of those variables.
  2. #27
    Reputation: taodemon's Avatar
    Mar 2014
    Not on a flat road. A 5lb heavier bike will reduce your speed ~0.04mph. Nowhere in the realm of 20watts.
    And on a 10% climb, a 5lb heavier bike requires 11watts more.
    Weight alone likely wouldn't do it but when combined with fatter cx tires, less aero bike frame/wheels and most significantly a much less aero position for the rider and 20 watts isn't that big a difference. At 20mph on equal weight bikes according to that calculator hood to drops alone is 39 watts, a mtb tire vs clincher is 49 watts, so the combined lesser extremes of weight, cx tires, position could easily be 20 watts.
  3. #28
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by taodemon View Post
    The fatter tires could be making it so you have to exert more watts for less speed......
    Wider tires have less rolling resistance, so that will cancel out the added weight and less aero profile of the tires.
    As TLG said, the OP should swap the power meters and do the conparison again.
  4. #29
    Reputation: velodog's Avatar
    Sep 2007
    This would be true of like tires, but not so much if comparing road tire to CX tire or a lesser quality wider tire.
    Too old to ride plastic
  5. #30
    [REDACTED]
    May 2014
    Yes, I stand corrected. A CX tire usually has a tread which will roll slower than a smooth tire of any width.
  6. #31
    Nov 2009
    So you never answered.... can you swap the power meters between bikes?
    I can't believe you had to ask this question again. All the other talk about stack, reach, bike weight, tires, etc. is a waste of time until you swap the meters.
  7. #32
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Quote Originally Posted by tomato coupe View Post
    ...talk about stack, reach, bike weight, tires, etc. is a waste of time until you swap the meters.
    ^^^^This.
  8. #33
    [REDACTED]
    May 2014
    Quote Originally Posted by GlobalGuy View Post
    ^^^^This.
    ^^^^^That.^^^^^
  9. #34
    Sep 2007
    ^^^^This.
    ^^^^^That.^^^^^
    ^^^^The Other Thing.^^^^
  10. #35
    Reputation: OldZaskar's Avatar
    Jul 2009
    ^^^^^^^^^^^THIS^^^^^^^^^^^
    Seriously, OP - like, 5 of us have asked if you can swap PMs. The irony here is ironic - you're measuring the difference is measurements with measuring devices... swapping said measuring devices will answer the question. At least tell us you can't swap them (1x vs etc) so we'll stop asking ;-)
  11. #36
    [REDACTED]
    May 2014
    Quote Originally Posted by OldZaskar View Post
    ^^^^^What he said.^^^^^
  12. #37
    Apr 2011
    "higher power", I thought this thread is about some kind of spiritual experience in cycling world. 👼
  13. #38
    Reputation: Srode's Avatar
    Aug 2012
    compare your HR and power on one vs the other, you might just be pedaling harder on one.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  14. #39
    [REDACTED]
    May 2014
    Pedalling harder usually results in going faster.
  15. #40
    Sep 2007
    Sure, if you're comparing like bikes. A CX bike with cheap, slow tires ain't gonna be as fast as a road bike with high end supple tires. And if the difference is wide enough the road bike could be faster even if you soft peddle it.
  16. #41
    Aug 2012
    Not necessarily faster, but more watts - YUP!
    Gravel Rocks
    Trek Domane
    Trek Crockett
  17. #42
    Jul 2012
    Did you'll scare the OP off?
  18. #43
    Jul 2009
    Quote Originally Posted by Methodical View Post
    He finally swapped the power meters and rode off into the sunset... 20 watts faster
  1. Power higher but less comfortable after fit
    By thisisthebeave in forum General Cycling Discussion
    Last Post: 05-04-2018, 07:51 AM
  2. Same power but higher Heart Rate in more Aero position.
    By Bridgey in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-12-2016, 01:09 PM
  3. Replies: 202
    Last Post: 03-26-2012, 08:30 AM
  4. How much difference do higher-end cranks make...
    By Cni2i in forum Components, Wrenching
    Last Post: 07-20-2010, 10:43 PM
  5. Replies: 31
    Last Post: 08-08-2006, 08:33 AM
