• 02-16-2018
    Wetworks
    Quote:
    Originally Posted by Rnk_3 View Post
    Interesting, I would say I had relief on the bike too, at least the pain never popped into my mind.
    I have seen a pelvic floor pysio a number of times but felt that was making things worse and was uncomfortable af. How long would you say it was from when you first had symptons to when you were able to ride again and be pain free after?
    My symptoms lasted the better part of a year, but I rode despite that. I was treated empirically for prostatitis, had blood flow tested (it was decreased, no surprise if I was in spasm), and went to a PT before finally getting on Elavil. I'd recommend going to a proctologist instead of pursuing the physio.
    Before I was rode the other day, my pain was just a mild discomfort. It doesn't help I sit for 8 hours a day at work. That was the only time it was sztart to hurt a little, after 6 hours or so, but the pain wouldn't linger at the end of the day. I will mention this to the doctor next time I go in. I have an ultgra sound of the perenail area on Tuesday. (I know it won't show anything but it's the steps you have to take to get anywhere)
    Thanks for the quick resonse.
    I'd wager that, much like saddles, the softer the chair you sit in the worse your symptoms? I took to sitting on a piece of wood when at the desk, actually experienced moderate relief.
    I'm not saying that there can't be PN involvement, either, but I'd almost bet your symptoms are stemming from pelvic floor spasming.
  • 02-16-2018
    Rnk_3
    1 Attachment(s)
    Yep that is bang on. Took me a while to learn, but a couch with soft cusions that puts pressue on the perenium can case a bad fliar up for a week or two, similar to riding a bike. I bought a cusion your assets seat which has helped quite alot. I take it anywhere I may have to sit on a soft surface.
    I also have found that underware and tight clothing casues discomfort and I find I have to constantly readjust myself when wearing certain underware, does that sound familiar?
    I was riding the specialized power saddle and had it pressure mapped this summer and it was determined my pressure mapping was very good. One thing I did have the seat too high wghich may have caused the issue in ther first place.
    I then did quite a lot of reserch, and ended up purchasing the Rido R2 which is essentially a noseless saddle, with a nose.
    Attachment 321886
    I got my fitter to put it on the day before I rode this week and he confirmed with the pressure mapping that the weight was 100% all on my sit bones. No pressure what so ever on any of the soft tissue areas.
    Did you do any type of pelvic floor pysio?
    Also, did you have any other symptons besides perenium pain? I don't really have any other symptons associated with pelvic floor disfuction or PN besides the dull aching perrenial pain.
    Again thank you very much for your help. Your case sound the most similar to mine that I have heard.
  • 03-31-2018
    Rnk_3
    So update, I went and purchased a recumbent (Bacchetta Carbon Aero) assuming that would solve the issue. Nope, later on in the night after the first ride, that all too familiar dull ache in my perineum returned in full force. I was stupid and bought with out trying it ( no where to try it with in hundreds and hundreds of miles) and 4 grand later, it solved nothing. I assumed the reclined position with all of my wight on my back would of solved the issue.
    Must be something with the pedal motion itself.
  • 04-01-2018
    Wetworks
    If I am right (and I think I am) that you have pelvic floor syndrome, then a recumbent is actually going to make it worse. You really need to go back and re-read what I wrote to you. After that, pitch this the same way you did to a PT, proctologist, or urologist. Trust me, alarm bells will go off and they will treat this as what it is, pelvic floor dysfunction.
  • 04-04-2018
    Ken2
    I had a similar pelvic disfunction for over a year. Urologists know next to nothing about it--they treat you for "prostatitis" with drugs, when that doesn't work they call it "neuropathic pain" and have no remedies.
    I recommend a pelvic floor physiotherapist--that's what finally helped me. Also have a look at this book http://tinyurl.com/PelvicPain222 .
  • 04-04-2018
    Rnk_3
    I have an appointment set up with another PT physio in July, and with an Osteopath in a couple weeks.
    Re reading what you experienced, did the cycling flare you up bad after the fact? I know you said you experienced relief while biking, but if you had been feeling a little better, then biked, would it flare it up?
    Since my ride last Thursday I have been aching bad, especially while sleeping. It's slowly improving, but every time I bike it is back to square one. I guess I have to give it up for a period longer than 5 months like I did
  • 04-04-2018
    Rnk_3
    I actually read headache in the pelvis and have been doing some of the stretches, though I am not sure how much they are helping.
    What were your symptoms? My only symptom is an ache in the centre of perineum, somewhere in the prostate area. It gets a little better if I don't cycle and try avoiding to sit as much as possible, but easily gets flared and anytime I cycle it is back to square one.
  • 04-04-2018
    Ken2
    Pelvic floor dysfunction
    I had perineal pain as you describe, also tip of penis pain. Worse when sitting, in fact I got a standing desk for work because I couldn't concentrate through the pain while sitting. Also got a portable laptop stand so I could lie down and work in bed http://tinyurl.com/LaptopStand11 .
    Like WetWorks, I found some (relative) relief cycling, but only on a noseless saddle like the Hobson. My theory was likewise, that cycling improved circulation some, but it was still far from comfortable, and it was impossible with standard saddles.
    I tried biofeedback, acupuncture, meditating, and exercises after I came to understand that I had pelvic floor spasms/dysfunction. What helped me most was a pelvic floor physical therapist, whom I saw weekly for about a year. If you are located in or near a large metropolitan area you are more likely to find someone who knows what they are doing.
    Also there are seatpads with cutouts for the tailbone area that I found gave me relief when I had to sit, like when driving. Still use one in my car.
  • 04-05-2018
    Wetworks
    It would eventually revert to baseline post-ride, but it wouldn't worsen, no. Ken kind of touched on the reason for improvement during riding; increased blood flow. But that's not how I'd explain it as it obscures the mechanism, which is at the heart of the matter IMO.
    Everyone is going to experience decreased circulation when sitting on a saddle for an extended period of time. The problem for us is we are starting off that process already at less than optimal circulation. So why the improvement? I believe it has to do with sympathetic and parasympathetic parts of the pelvic floor, particularly the external anal sphincter. If you tend to be an internalizing person, there's a good chance you are clenching your external sphincter without even realizing it. A good test is to go sit on the bowl and have a BM. I would wager most people experience immediate relief, followed by a gradual return of symptoms within 30 minutes.
    So, when sitting on a saddle, your mind is concerned more with sympathetic responses, so the parasympathetic nervous system is taking a back seat with decreased motility, increased contraction of the INTERNAL anal sphincter, while the sympathetic nerves are doing their job of keeping you in motion on the bike, looking out for obstacles, etc. The EXTERNAL sphincter, which as opposed to the internal, is innervated by the pudendal nerve, gets a bit of a break due to the anatomical position assumed when sitting on the saddle along with some (possible) partial relaxation of sympathetic external rectal tone.
    So, that's my THEORY as to why I and others may experience relief. And like Ken said, urologists and other MDs are clueless, especially when you lead with "I feel better sitting on a narrow, hard bike saddle." Of course, I could just be talking out of my @$$... :D
  • 04-05-2018
    Fredrico
    Good points.
    I can remember years ago when ramping up fitness, the pelvic floor would tighten up severely when pedaling hard, internal sphincters indeed, and when I rested up after the ride, it would hurt like a bruise. It subsided overnight with slight sensitivity the next day. Learning how to spin solved that problem. I did do some purposeful pedaling up hills careful to keep the power in the legs. The anal muscles still go isometric, but after some training, no longer over-tighten in sympathy with the legs. Definitely something to think about.
  • 04-28-2018
    Rnk_3
    So I went to a Sports Dr and he believes what I have is Osteitis Pubis. Basically inflammation of the pubic symphisis. I could never really pin point the source of the pain, just deep in the pelvis and sure enough, when he pressed down hard on the area it increases the pain. I am going for a bone scan to confirm. This is typically something runners get, but I wager I got it from riding on my saddle 3 cm too high with poor mechanics.
    Causes
    Overload or training errors
    • Exercising on hard surfaces (like concrete)
    • Exercising on uneven ground
    • Beginning an exercise program after a long lay-off period
    • Increasing exercise intensity or duration too quickly
    • Exercising in worn out or ill-fitting shoes
    Biomechanical inefficiencies[edit]
    • Faulty foot and body mechanics and gait disturbances
    • Poor running or walking mechanics
    • Tight, stiff muscles in the hips, groin, and buttocks
    • Muscular imbalances
    • Leg length differences
    Alot of that fits me. Went from zero to 100 doing 2k in 6 weeks with my intensity going from 25kph average to 32kph, my posture on the bike is bad, I never stretched and have poor flexibility, I never warmed up, I never cooled down.
    Cure is to rest for 6+ months from all running and cycling and lots of stretching. I have been playing basketball every week since so I haven't given it a chance to heal at all.
  • 04-29-2018
    Clipped_in
    Quote:
    Originally Posted by octave View Post
    this is about to get personal, but i think awareness of these kinds of things are important for the cycling community.
    Pudendal nerve entrapment in an Ironman athlete: a case report
    i am currently experience many of the symptoms discussed in the above article, namely pain in the tip of my penis and feelings of incontinence and urge to pee all the time even after having just peed.... and all this cropped up after having a proper fit on my bike with the Fizik Aliante Versus X fancy cut-out pressure relieving saddle. so, even if they claim pressure relief, beware. that might not always be the case. i am going to be trying specialized's Power saddle as soon as this clears up.
    in any case, if anyone is experiencing pain, don't just say HTFU. after a few visits to my general physician, i am going in to the urologist on thursday.
    Every two or three years in the spring when I really increase my ride volume I experience very similar symptoms. In my case it is a UTI for which my family doctor perscribes a round of Ciprofloxacin antibiotic and I'm good to go after a few days on the medication.
    I hope your doctor can find for you a similar easy solution to your problem.
  • 04-29-2018
    Ken2
    I avoid Cipro: the FDA now requires "black box" warnings on this medication, alerting doctors and patients that the drug can increase the risk of tendinitis and tendon rupture in some patients.
    There have been reports of runners and cyclists getting Achilles tendon ruptures while on this drug.
  • 05-01-2018
    BlazingPedals
    Octal, have you had your prostate checked? Not being able to fully empty the bladder can be an indication of an enlarged prostate. I don't know if it can cause those other symptoms, though.
  • 06-19-2018
    Rnk_3
    1 Attachment(s)
    The wild goose chase continues. I had a bone scan the ruled out OP I mentioned above.
    I ended up going to a massage therapist last week and she found a trigger point in my adductor. I did the research, and sure enough, those trigger points refer pain to the pelvis. Makes sense as to why the pelvic physio never found anything internally. It also seems to be triggered by excessive cycling, and likely especially in my case when I had my saddle too high, and explains why the recumbent flared it up too.
    I'm going to have her work on it a few sessions and then possibly try fry needling/ trigger point injections. Hopefully this is something that can be fixed.
    Attachment 322944
  • 06-19-2018
    Fredrico
    Attachment 322944
    Lowering the saddle should do it. The legs can take weight off the sit bones not possible when saddle was too high, and ease the saddle pain going hard. That tightens the muscles around the sit bones, and rider has better support.
  • 03-27-2019
    Rnk_3
    So, I am still as bad off as ever. I went to another pelvic physio and this one said I was super tight but got no improvements. I think I am ready to talk to my doctor about Amitriptyline.
    Have you had any side effects from it? One thing that worries me is weight gain. Since I stopped cycling Iím already up 35lbs.
    Are you able to sit on what ever now with out pain?
  • 03-27-2019
    Wetworks
    I'm on an extremely low dose, the only side effect for me was sleepiness, which I overcame after being on the med for a week or two. No issues with weight gain at all. I am presently looking to find the reason for decreased blood flow to my pelvis, waiting for approval for a CT-A. Most of my symptoms have been addressed, but I still have flare-ups from time to time.
  • 03-28-2019
    Rnk_3
    Appreciate the quick reply. Do you think Amitriptyline healed your pelvic floor dysfunction or is just masking the pain? Do you think if you went off now it would return? I just want this pain to end and get back on my bike so badly!
    I just took up jogging this week but I had a good chunk of miniscus removed from my knee a decade ago and the surgeon specifically said to become a cyclist not a marathon runner, but I would rather have knee pain I think than this miserable dull aching **** show I have going on now. I feel like it flares me up as well a little, though not nearly as bad as cycling.
    One other question, when you had the pain before going on the medication did you have the dull aches at night that caused issues sleeping ? Thatís the big thing with me, I can power through the pain during the day, but if it is bothering me at night it becomes unbearable. Luckily last summer my paid wasnít bothering me at night, but this past 4 months it has been bad at night and i have no idea why
    The biggest difference with you and I is that you said your pain would revert to baseline after you biked. For me it flares me up as bad as I ever get after I ride.
    I made the appointment with the doctor so i hope I can get the relief you did. Youíre the closest person to my issue as I have found in my 100s of hours reserching through various forums, FB Groups, Sub Redditís etc. If there is a forum or group for PN or pelvic floor issues I am probably in it
  • 03-29-2019
    Wetworks
    It doesn't mask the pain for me as much as it relaxes the pelvic floor. I was also experiencing the dull aches you described and have since had them disappear for the most part. I do occasionally experience flare-ups, but they tend to be much shorter in duration than previous to Elavil.
    Not sure if it's been mentioned before or if you've come across it, but check into internal hemorrhoids as well. Anything that takes up extra real estate in that region is a problem.
  • 03-29-2019
    Rnk_3
    Iíll look into that, but doc when checking the prostate would have likely felt that, no? Or even the pelvic physio. My pain feels like it is coming from just behind the testicles in the centre of the perenium.
    I do have an appointment in May with a Urologist who I know is probably going to say itís prosititis and put me on antibiotics which wonít do anything for me. I will contact my GP next week but I am guessing they wonít want to do anything for me until I see the urologist.
  • 03-29-2019
    Fredrico
    Pain just behind the testicles? I had that when starting long rides and found when going hard, I'd put too much weight on the exactly this area. Wouldn't notice it until the end of the ride, sometimes by that time painful. That night it felt mildly bruised. A couple of times making it painful to pee.
    So I experimented with positioning on the saddle. I rotated the hips back just enough to alleviate principle weight on the perineal nerve area, concentrating more weight on the sit bones at the wide back of the saddle. I leveled the saddle so I could sit up and peel a banana without sliding forward, and moved back and forth on the saddle to find the most comfortable weight distribution all around. It took a couple of years for this new positioning to become instinctive. The pain went away.
    Look at the position of the hips on the pros. They're not doing a superman. They're bending forward at the waist.
    Basically, positioning on the saddle injured my nether parts, and I kept doing it. When I finally figured out how to sit properly on the saddle, the muscle tissue around the injury recovered, got stronger, and healed the perineal area. So now when "on the rivet" it never lasts long and I won't hurt after the ride.
    Try it, man! Leave the drugs at home. :thumbsup:
  • 03-29-2019
    Rnk_3
    I haven't ridden in 13 months and the perennial pain still bothers me every day. I cannot sit on anything soft, and couldn't even ride the $5k recumbent I bought or I can't even go to the gym with out flaring myself up very bad.
    Trust me, this is a last resort. See this post
    https://forums.roadbikereview.com/ge...ml#post5216759
    My last ride last February was on essentially a noseless saddle and it flared me up to high heaven with all my pressure on my sit bones.
  • 03-29-2019
    Fredrico
    Dunno man. If blood flows into the soft tissue when it isn't resting on something, swells it up so it hurts, seems like a "chronic" injury. The soft tissue needs time to heal. It's not back together yet from the saddle being too high.
    I was riding the specialized power saddle and had it pressure mapped this summer and it was determined my pressure mapping was very good. One thing I did have the seat too high which may have caused the issue in the first place.
    So good pressure mapping points renders the way you're distributing weight on the saddle unlikely to be the cause. The saddle being too high was the culprit. How much time have you had to recover? It took me 2-3 seasons riding, but it would go away when walking or sitting. What's the pain feel like on a brisk walk? What's the tissue that's swelling or the source of the pain? I guess a decent urologist would know all that, as others are suggesting.
    But it seems to me, if at one time you could ride without perineal pain, you could do it again. Maybe take a few months off, take walks, do light weight lifting. Lifting has a magical way of pulling the musculature together, evening out weaknesses and stress in areas one never thinks about. It eliminates toxins, crotches being prime locations as the miles add up. A local infection could produce pain when not resting on something.
    If medicines work, great. But I have a bad attitude about taking drugs more than temporarily, only to get one through the healing process worked out by exercise and regeneration, what the body does. Old folks get ginned up with meds for every damn thing. The only drugs I need are Gas-x and Tums. :D
    Just some thoughts from a 75 year old guy who's been there. We're all different.
  • 03-30-2019
    Rnk_3
    That's the thing I have no idea where the pain is actually coming from. It is just a dull ache that feels like it is in the perineum but it isn't tender at all. There is no where that hurts to the touch.
