removal of nail polish on a carbon frame
Results 1 to 13 of 13
    Nov 2010
    Interested in suggestions on how to remove nail polish on a carbon frame without causing any damage to the carbon. Any cleaners specifically made for this condition?
    Reputation: PBL450's Avatar
    Apr 2014
    Quote Originally Posted by hartley1 View Post
    I would leave the nail polish where it is... Why bother removing a purely cosmetic concern with a potentially physical repercussion?
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    Dec 2006
    Use NAIL POLISH REMOVER.
    Nov 2010
    I wish to remove it and reapply it because it is uneven and lumpy.
    Oct 2017
    Acetone/Nail Polish Remover.
    Never Give Up!
    Mar 2009
    if really bothers you that much... lightly sand with very fine wet/dry sandpaper until the you get the desired look/feel you want and reapply clear coat, problem solved!
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by ROAD&DIRT View Post
    That's what I was going to suggest. And if you have a very light touch with the sanding, you might even be able to avoid the final clearcoat step, if you can get acceptable gloss with rubbing/polishing compound. That would negate the risk of making lumps all over again.
    "None of us knows for sure what's out there; that's why we keep looking. Keep your faith; travel hopefully. The universe will surprise you, constantly." The 13th Doctor.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Finx View Post
    I would not do this. It may dissolve more than the nail polish.
    Personally, I would leave it alone and ride the bike.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Reputation: velodog's Avatar
    Sep 2007
    It's called "beausage", also known as honest wear from using the bike as it's intended. Just ride and enjoy the bike.
    Too old to ride plastic
    Apr 2014
    In thinking about this question, I have to ask, how did you get nail polish on your frame? I can see lipstick on your collar... What was going on with the polishing of nails on the bike? Eating you lunch on the bike is a skill, polishing your nails on your last century? Thatís epic!
    Nail polish is often used as touch-up paint. Modern frames that are painted or clear coated should also have a modern urethane paint that is not affected by acetone. The base material of carbon fiber and epoxy resin is also unaffected by acetone. Acetone will remove nail polish.
    'brifter' is f'ing stupid
    Quote Originally Posted by Peter P. View Post
    ^Best answer obviously^
    #promechaniclife
    Dec 2006
    An update on my answer to use nail polish remover.
    While nail polish remover CONTAINS acetone, it is in a specific concentration. Look at the labels while perusing the nail polish remover and you'll find nail polish remover that's PURE acetone, REGULAR, EXTRA-STRENGTH, and ACETONE-FREE.
    Buy the regular. I recently used pure acetone to remove some stubborn paint from a piece of plastic, and it started to remove the plastic as well. I'd previously used nail polish remover and didn't have a problem so I figured using the read deal wouldn't be a problem. I was wrong.
  1. Spray paint vs. nail polish
    By old_fuji in forum The Lounge
    Last Post: 02-27-2017, 12:38 PM
  2. Clear Nail Polish ON Felt F1
    By petercaro in forum Felt
    Last Post: 09-21-2016, 06:05 AM
  3. Nail Polish remover for tubular glue removal?
    By CleavesF in forum Wheels and Tires
    Last Post: 03-17-2013, 05:35 PM
  4. Re-introducing the cf-laquer damage/nail polish topic.
    By Ventruck in forum Bikes, Frames and Forks
    Last Post: 03-22-2012, 07:02 PM
  5. How to protect carbon frame... wax??? polish???
    By innatehealer in forum Components, Wrenching
    Last Post: 01-31-2005, 07:03 AM
