repairing a 1991 Specialized Allez Epic
Results 1 to 12 of 12
    Crash Test Dummy
    Feb 2012
    A buddy of mine was out for a ride on his CF Allez when the chain dropped off the rear, derailleur jammed in the wheel, and the aluminum derailleur hanger bent. What are the chances of straightening the derailleur hanger?
    Reputation: SOME_1_ELSE_1999's Avatar
    Apr 2011
    pics would help....
    Do not argue with an idiot. He will drag you down to his
    level and beat you with experience.
    http://surlybikes.com/blog/2514/
    Crash Test Dummy
    Feb 2012
    LC
    LC is offline
    Looks like the bend is past the wheel axle so it is not structural or effects the alignment. Good chance to straighten that one if you have the right tools. I have an old frame with that same dropout and they are really strong so it is going to take some serious effort to bend it back.
    Dec 2006
    Aluminum gets weak very quickly as it's bent. Also, due to the age of the frame, it's unlikely you'd be able to get a replacement dropout for a firm that repairs carbon frames to install, if they could.
    The dropout COULD be straightened be you should keep an eye on it, long term, for cracks to form. An aluminum dropout will certainly be weaker after the accident and subsequent realignment; they're is no telling how long it will last. The trick to doing the job easily is to flip the wheel around so the cogs are on the left side of the bike. You WANT the wheel in the dropouts during alignment to keep the dropouts parallel; it's really only the hanger that's bent.
    Next, you install a derailleur hanger alignment tool in place of the rear derailleur. The tool is both an alignment gauge and a leverage tool to straighten the hanger. Most cyclists don't own this tool but bike shops will. It's necessary to get the hanger in correct alignment for good rear shifting. You want to bend the dropout into alignment with as few steps as possible, because aluminum doesn't like the repeated bending.
    Tip for using the tool: The idea is to have the same gap between the tool and the rim. You should reference the same part of the wheel as you rotate the tool i.e., indicate off the rim sidewall adjacent to the valve. This is so because your wheel might be out of true. Tip #2: It's a pain to check alignment using the tool if you have to check a spot between the seat and chainstays i.e., behind the seat tube. The good thing is YOU DON'T HAVE TO. The idea is to have the derailleur hanger and the wheel in the same plane. If you remember your geometry, 3 points in space represent a plane. So, you can check your alignment at the very bottom of the wheel, at the very top, and at the very rearmost, and you're all set.
    If you choose to bring it to a bike shop, expect some to refuse to do the work for fear of cracking the ALUMINUM dropout. It's a real possibility. If you can persuade them you'll absolve them of any responsibility, perhaps they'll give it a go. Otherwise, it would be cheaper to buy the hanger tool yourself to try the alignment, before tossing the frame into the garbage. The hanger tool is handy for any bike with an aluminum or steel dropout, with the earlier reservations on aluminum dropouts still applying. Titanium dropouts are extremely tough to align, and you can't align carbon dropouts at all.
    Episodes such as yours illustrate why it's a good reason to consider how a frame's dropouts are constructed when buying a new bike or frame. Even a bike with a replaceable derailleur hanger would have saved your friend, but his frame likely pre-dates that feature.
    Crash Test Dummy
    Feb 2012
    nevermind
    Dec 2018
    Quote Originally Posted by Peter P. View Post
    In case someone ever has same problem, dropout on these bikes is NOT ALUMINUM lol it is steel and it is very easy to repair, just leave your bike at any shop, they have right tool to fix it, Same thing happenned to me, costed me 5 bux and is better than it ever was, perfectly straight.
    May 2016
    Put a new hanger on...they are cheap
    Reputation: Oxtox's Avatar
    Aug 2006
    Quote Originally Posted by smokersteve View Post
    feel free to explain how to do it on this particular bike.
    'brifter' is a lame word.
    This was at least 10 years before replaceable hangers became a thing.
    I work for some bike racers
    and a bunch of skateboards
    May 2016
    Quote Originally Posted by Oxtox View Post
    My bad. Didn't see the year of the bike
    a real member's member
    Jul 2016
    old thread, i know, but ...
    the youtube hack, rj the bike guy (or whatever his name is), has made a helpful video to build your own hanger alignment tool with a couple bolts, nuts, and washers. i did this and have used it a number of times on old bikes. works great.
