Saddle Sag
Results 1 to 25 of 37
Thread: Saddle Sag
    Jack of no trades
    Reputation: Wood Devil's Avatar
    Apr 2011
    Saddle Sag
    Most every saddle I've had before, over time, loses it's shape and starts to sag in the middle. My old Fizik Arione, for example, started out perfecty flat. Gradually over time it took up a dip in the middle where, if I took a level and rested it on the nose and rear of the saddle, there would be almost a half inch sag in the middle. This, naturally, affects bike fit to some degree, as you can't easily slide back and forth without discomfort.
    Does anyone have any tips to prevent the sagging, short of buying a new saddle every couple months?
    Mar 2004
    Carbon base saddles should not say as much as composite
    Feb 2002
    Quote Originally Posted by Wood Devil View Post
    I'm completely baffled by your experience. My previous Fizik Arione lasted 35,000 miles until a saddle rail broke. Zero sag. I weigh about 175 lb (80 kg). A modern non-leather saddle will not sag unless the plastic base has been deformed, and that won't happen without a serious applied load that damages the saddle. Any chance you have a strange seat post and are bending the saddle rails? What you describe is bizarre.
    Apr 2011
    Half an inch is HUGE in bicycle fit. Maybe it was a string of bad luck that you ended up with defective product more than once...?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Very bizarre. Never had a saddle sag, not even a little. Never even heard of it happening. I can't even fathom how that's possible to sag 1/2" over ~11" in length.
    Needing a new saddle... "every couple months" Something ain't right.
    Post pictures.
    Pictures?
    To be honest I have trouble believing it. That saddle doesn't have even half inch of padding and plastic couldn't stretch that much if at all. And you would obviously noticed 'broken'. And after just a couple months?
    pmf
    pmf is online now
    Kerry is correct.
    I had the exact same reaction. I've ridden the same saddle for almost 30 years. Not the same single saddle -- they do wear out. But the same Selle Italia Flite that is nowadays sold as a retro '90's' version. Sagging? Never. And its not even a carbon fiber shell. After a lot of miles, the leather wears out on the sides near the back. You wear a saddle out every few months!? Something odd is going on. This happens with different models too?
    I have never experienced this. What do you think is sagging, the saddle base? Foam getting compressed?
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I find this bizarre as well unless you weigh over 300lbs and ride 10,000 miles every few months. Leather saddles will sag a little with use, but can be adjusted. They do not sag a half inch however.
    "With
    -- DCGriz, RBR.
    Mar 2019
    yeah... try shoving a baloney sandwich in your shorts as a spacer.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by rudge66 View Post
    The Rudge Method. No worse than any of your other advice.
    "With
    -- DCGriz, RBR.
    gazing from the shadows
    Jan 2003
    I tension my Brooks once in a while to counter sag. I have seen other saddles give up over a very long time and get flexier, but have never noticed sag that stayed when unweighted.
    Here's my guess why you might see sag when others don't on their bikes. I would guess that you are sitting further forward on the saddle (always or more often) than most.
    If you sit properly, very near the back, the pressure on the saddle is going to be pushing the nose up and the back down. That won't create sag in the middle.
    If you are more towards the middle of the saddle, the pressure will be down BETWEEN the attachment points of the rails to the saddle. That will flex the saddle itself, and over time that flex could get set in place.
    Get a brooks and tension it when needed. Get a carbon saddle and see if that lasts longer. Pay attention to your sitting position and try not to slide forward all the time. Keep getting new saddles. Four options I can see.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by QuiQuaeQuod View Post
    Better yet, get a Selle Anatomica:
    https://selleanatomica.com/?_vsrefdo...EaAmGREALw_wcB
    Unlike the Brooks, it doesn't need any breaking in before it is comfortable. You will need to re-tention it a few hundred miles from new, but after that, you won't need to re-tention for thousands of miles.
    "With
    -- DCGriz, RBR.
    I get what you are saying but what could possibly cause a 1/2 an inch sag on a saddle that doesn't have 1/2 an inch of padding and a plastic, carbon or whatever non-stretchable shell?
    The rails getting jammed further in to the holes they are inserted in is the only possibility I can think of and one should be able to ID that by just checking if the rails are allowed to slide back out to where they were originally.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Not every posterior meshes well with every saddle, though.
    FWIW, I ride Brooks saddles (B-17s and a Professional), but only the wider versions of them, as my bum can't abide by the narrower ones.
    Everyone's MMV.
    Donald Trump has never had a wife he didn't cheat on.
    There are over 6.2 million covid cases in the United States (as of September 6th), eight months after Donald Trump said it was "totally under control," and that "it's gonna be just fine."
    Jan 2003
    Entropy.
    I can't speak to carbon since I have never wanted to torture my butt that much, but any plastic material does flex, and if you push down hard in the middle of a saddle it will flex (down, but also the sides will flex outward a bit). Anything that flexes will eventually stop returning to the original position and/or get weaker over time.
    If the OP is sitting in a way that flexes is, the saddle is being flexed every ride. And held in the flexed position for a very long time. That a plastic shell would take a set from that does not surprise me. in general.
    Never seen it, others have not either, so I the only thing I could come up with is sitting in the middle of the saddle and not at the back. That does not mean I am right, but I can't think of another thing that would do it (other than a cracked saddle shell, or some other damage, which does not seem to be the case.)
    Feb 2002
    Entropy.
    In the case of plastics, or reinforced plastics, the concept of "take a set" doesn't really apply. Once a plastic starts to fail (has exceeded its elastic limit) it will pretty much continue to fail. The regular flexing of a plastic saddle will not cause failure in any rational time frame. No one could ride enough miles in 2 months to cause this.
    Jan 2003
    Set, start to fail, microcracks... whatever it might be I am starting with the assumption that the OP is accurate so it DID happen. Then I am trying to provide a way it could. The only thing I can think of is sitting too far forward and sagging the saddle while riding.
    An experiment could be done. Take a saddle of similar construction and weight it with 150 (or whatever, 200 might be a better static load since you won't have the sharp forces of the road in play) lbs in the middle of the saddle. It will sag. Take the weight off and check every week. (yeah, not the greatest experiment given 24/7 load, but as a proof of concept it has some value.)
    That would not get at the dynamic load put on it hitting bumps and such. Maybe going with a higher static load would work, or some active test rig that is run 2 hours a day. Not worth anyone's time to do right. But I can see how someone here might take an older saddle and try heavy weight over time to see if that makes a difference. Someone really bored.
    Given the OP said this happens with every saddle, I have to rule out material defects. Leaving what the OP is doing to the saddle. Can't see how over/undertorquing would create the problem. I can't see how ozone would do this to the plastic of the saddle without rotting the tires way faster, assuming it was stored near an ozone source. So that pretty much leaves riding.
    Never seen this happen, I don't know how it could happen in 2 months. But from what I know of this situation, I can only think of one likely cause.
    Observation or reporting error could also be in play. But assuming it is not.... you have my guess.
    Apr 2011
    OP is an average size guy. Unless he put on a lot of weight since this post.
    Feb 2002
    And you will note that with all this input, the OP has not responded once. I guess we'll never know.
    Jan 2003
    Maybe the OP too busy is dealing with the medical issues that come from smashing your taint down on the middle of the saddle for every ride?
    BTW, I would put more money on the OP being inaccurate in reporting than my answer being right.
    Jack of no trades
    Apr 2011
    Sorry for the late reply. Lost track of the thread.
    I don't understand that no one here knows what I'm talking about.
    Take your saddle, a brand new saddle. Something like the Fizike Arione. Look at it from the side and note that you can run a level from the back to the nose, it is that flat. Over time, however, if you look at the same saddle from the side you will see that it is no longer straight, but has a slight dip in the middle where you're always sitting.
    Plastic wears out and deforms. So does the padding. That's what I'm talking about. I don't know what the hell you guys are using for saddle that don't deform slightly with regular use, but I want one.
    I mean, hell, even go over to your bike now and press down on the saddle where your sitbones would be. Note how you can push on the padding and also depress the plastic frame. Now, imagine your full bodyweight. The saddle is going to sag under your weight. Over time it will lose it's shape. That's what I'm talking about here. And I'm no heavy-weight -- I'm only 140 lbs.
    To prove this fact that the saddle dips during riding, I used a app called Saddle Adjust. You place the phone on your saddle and it will give you the angle of your saddle tilt. Before my ride it was a 0.4, and after my ride it was at 0.7 ... meaning the plastic frame deforms with use, in the middle where your sitting, and as a result, the nose rises a bit, which becomes uncomfortable over the course of the ride.
    I really don't know how to explain it.
    Apr 2011
    Except 1/2 inch is not slight. It's huge in bike fit context and that's what many are wondering about. Unless that was a typo.
    Jan 2003
    .. meaning the plastic frame deforms with use, in the middle where your sitting, ...
    I don't sit in the middle of my saddles.
    I sit very near the back edge. Where you are supposed to sit. Where the saddle is designed for you to sit.
    tlg
    tlg is online now
    May 2011
    That's what everyone thought you were talking about. And no one can comprehend how a 1/2" is possible.
    PICTURES!
    Never seen what you're talking about in years of use.... yet you're seeing it every couple months.
    Makes zero sense. My saddle, and every saddle I've ever owned is the exact shape as when new.
    Nope. It doesn't do that. The padding depresses maybe 1/8-3/16". No friggin way can I deform the frame.
    PICTURES!
  1. Arione Saddle Sag
    By sbindra in forum Components, Wrenching
    Last Post: 07-16-2010, 03:44 PM
  2. Saddle sag?
    By de.abeja in forum Components, Wrenching
    Last Post: 11-27-2007, 09:37 AM
  3. when should saddle be replaced due to shell sag or safety?
    By acid_rider in forum Components, Wrenching
    Last Post: 10-05-2006, 10:17 AM
  4. brooks saddle sag
    By jfd141 in forum General Cycling Discussion
    Last Post: 08-04-2004, 03:31 PM
  5. what do you want at a SAG?
    By haiku d'etat in forum General Cycling Discussion
    Last Post: 07-03-2004, 07:12 AM
