Seatpost minimum insertion for this frame
Results 1 to 14 of 14
    Mar 2020
    What would be the safe minimum insertion for this frame?
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    This is usually determined by the seatpost, which should have a minimum insert mark on it.
    Never Give Up!
    Mar 2009
    The seat post dictates the minimum height, not the frame!
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Mar 2020
    I thought the seatpost usually uses caution since there are many different frames.
    With the master frame the tubing goes into a star shape and you can't even get some of the posts to the minium. I think the star shape starts before the 10cm mark (a lot of the seatpost minimum)
    Quote Originally Posted by Ddbigs View Post
    On my Master, the "star" shape starts about 6" down from the top of the lug. I'm using a Ritchey Classic post and I have plenty of post past the min insertion
    'brifter' is f'ing stupid
    In the old days the 'general' rule was 2.5 x the diameter of the post. In the case of a frame like this w/ a 27.2mm post that would be 68mm. Obviously it should be marked on the post.
    If you can't get the post to the min mark there's something wrong w/ the frame...paint or something. It needs to be reamed/cleaned out.
    #promechaniclife
    Mar 2020
    Quote Originally Posted by DaveG View Post
    Maybe it's different sizing or different generation? This one definitely doesn't have that much room. Roughly 9cm. I was hoping to go even less as you I don't want to damage the tube if the seatpost slips a little
    My frame is a 61 (c-t) so maybe less room on a smaller frame? What post do you plan to use?
    Mar 2020
    Thinking of using Deda zero 100 aluminum post
    From a photo of that post at Excel Sports it looks to me that the min insertion line is about 9.5 cm from the bottom. But, that is a super long post and you won't have as much exposed seatpost.
    Oct 2013
    You guys should use the same units, 68mm is way less than 9cm.
    BANNED
    You're right. That's like almost an inch difference!
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by jetdog9 View Post
    Yes. After all, there is somebody out there who makes seatposts for clown bikes....
    "L'enfer, c'est les autres"
    pmf
    pmf is online now
    Exact same story on my Arabesque. Any standard 27.2 seat post should work just fine.
  1. Minimum/Maximum Quill Stem Insertion
    By TomBrooklyn in forum Components, Wrenching
    Last Post: 03-24-2008, 05:22 PM
  2. Fast Forward Seatpost Minimum Insertion
    By mwilcko2 in forum Components, Wrenching
    Last Post: 02-17-2008, 10:54 AM
  3. Deda Seatpost minimum insertion
    By bradford in forum Components, Wrenching
    Last Post: 12-10-2007, 03:43 AM
  4. Minimum tube insertion length for Record carbon?
    By 1speed_Mike in forum Campagnolo
    Last Post: 09-17-2007, 09:56 AM
  5. 585 minimum seatpost insertion
    By Shuteye in forum Look
    Last Post: 01-05-2007, 07:28 PM
