Shifter hard to move
Results 1 to 9 of 9
    Aug 2018
    My left shifter, which actuates the front derailleur, was recently replaced. It worked fine at first, now it is very hard to move the big lever to go to the larger chain ring; the small lever is fine. Any thoughts?
    Russian Troll Farmer
    Sep 2016
    Cable stretch? Cable bolt not torqued down properly? Normal seating of the end at the shifter? I dunno-don't have my crystal ball handy.
    "L'enfer, c'est les autres"
    'brifter' is a lame word.
    No such thing.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Quote Originally Posted by coondogger View Post
    Do you mean that it is physically hard to push the lever, or that when you push the lever it is hard to get it on the big ring? Also, do you know that there is a components/wrenching forum here?
    He's posted there as well.
    Aug 2018
    Physically hard to push the lever.
    Aug 2018
    To be clear, the derailleur is fine. The large shift lever to move chain to bigger chain ring is physically hard to move. I tried a teflon cable and it didnít solve the problem.
    Cycling Addict
    Nov 2013
    Is there too sharp an angle in the cable housing at it heads to the downtube? This could be causing extra resistance to your shift attempt. With some bikes it works better to have the cable/housing go around the front of the head tube before entering the downtube interior routing.
    Life is short... enjoy the ride.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Can you physically move the front derailleur by pulling on the cable? If you can, then there is something wrong with the shifter itself. If not, then the FD is binding.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
  1. Shifter hard to move
    By coondogger in forum Components, Wrenching
    Last Post: 08-15-2019, 06:09 PM
  2. Bike struggles to move (ok, I struggle to move anymore) ??
    By jdlongstreet in forum General Cycling Discussion
    Last Post: 09-08-2014, 03:11 AM
  3. good move or bad move
    By mitong in forum Cannondale
    Last Post: 11-18-2009, 11:27 PM
  4. Centaur FD Shifter Lever Hard to Move
    By Milanomike in forum Campagnolo
    Last Post: 07-22-2008, 03:18 PM
  5. Replies: 14
    Last Post: 09-07-2006, 12:10 PM
