Should i get a carbon fork? - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
  1. #26
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by happybill68 View Post
    I’m 210, so maybe 75 psi would be to low
    Umm, yup. Once again, No Time Toulouse was shooting from the hip.
    For your weight with 25mm tires, 90F/110R is about right. You could get away with less, but at the risk of pinch flats.
  2. #27
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Have you personally noticed a difference in comfort between a carbon and alloy seat post? I haven't.
    Yes I have. The only other major difference I've found is with carbon bars but 1" carbon bars are too sketchy. Tire pressure makes a difference more so than the tire (unless you use really cheap tires), but I despise the feel of anything under 100 psi so that's a no go for me.
    Carbon seat posts flex way more than you think. I have a rear camera mounted on the saddle and compared to the aluminum seat post there is way more vertical movement (you can judge it against the rear tire in the frame).
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
  1. Replies: 4
    Last Post: 04-24-2013, 08:47 PM
  2. Replies: 2
    Last Post: 05-09-2012, 03:48 PM
  3. Aerus C4FK Carbon Fork vs. Ritchey Pro UD Carbon Fork
    By JohnHenry in forum Components, Wrenching
    Last Post: 08-10-2008, 07:27 PM
  4. 1" Carbon Fork to a 1-1/8" Carbon Fork Conversion?
    By steveh_houston in forum Components, Wrenching
    Last Post: 08-26-2007, 07:04 AM
  5. Icon Air Rail carbon fork vs. Columbus Crave carbon fork
    By dd74 in forum Bikes, Frames and Forks
    Last Post: 08-21-2007, 03:40 AM
