Sizing confusion
Results 1 to 15 of 15
    Jun 2014
    Sizing confusion
    I am upgrading from a 10 yr old Specialized aluminum road bike(size 54.5) to a new bike. Have shopped at 2 LBS. I like the Specialized Ruby Comp and the Cannondale Synapse. Sizing is a bit confusing. LBS #1 fitted me with Specialized Ruby 57. LBS #2 said Cannondale Synapse size 51 was the correct fit. Does size differ that much in different brands and geometries?
    I am not a super experienced rider and both bikes felt pretty good on short test rides.
    I am 5'7" with a 30 inch inseam.
    Any thoughts?
    Jun 2010
    Quote Originally Posted by MtnGinny View Post
    I am upgrading from a 10 yr old Specialized aluminum road bike(size 54.5) to a new bike. Have shopped at 2 LBS. I like the Specialized Ruby Comp and the Cannondale Synapse. Sizing is a bit confusing. LBS #1 fitted me with Specialized Ruby 56. LBS #2 said Cannondale Synapse size 51 was the correct fit. Does size differ that much in different brands and geometries?
    Any thoughts?
    The specialized Ruby doesn't come in a 56....
    Jun 2014
    oops, 57
    May 2012
    Ruby is a womens geomenty bike, and Synapse is not. Was it a Roubaix?
    Jun 2014
    May 2012
    Sorry. Didnt know that they had a womens specific model. The 57 Ruby has a 566mm top tube. The Synapse 51 is 525mm. That is quite a difference. Did you feel more stretched out on the Ruby? Cramped on the Cannondale?
    Jun 2010
    based on just your height and inseam I would say the LBS that fit you on a Ruby 57 is completely wrong. My guess would be a 51 or a 54 depending on your actual dimensions
    Jun 2014
    Maybe a bit stretched out on the Ruby. I do have long arms. I rode the bikes about 2 weeks apart so hard to directly compare. I was fairly upright on the Synapse.
    The LBS didn't have a 54 Ruby, but I tried a 54 Amira and felt a little cramped.
    May 2012
    As a point of reference Im 5'8" with a 30" inseam and ride a 54 Roubaix.
    Dec 2010
    Size varies widely by brand. I typically ignore the labled sizing on a given frame and look at the geometry chart. In particular, effective top tube is all that really matters. Inseam and seat tube length is almost irrelevant.
    May 2012
    You should not limit yourself to womens specific bikes. They work well for some, but not all.
    Jun 2014
    Thanks everyone! I think I will be doing more test riding :-)
    Reputation: 9W9W's Avatar
    Apr 2012
    also for reference:
    Mah wimminz is 5'9.5 and rides a 56 Synapse (womens specific), she's all leg (tall jeans only). IIRC, the geo on the 56 synapse has a 54 effective toptube.
    Jan 2009
    Go with the 51cm. You can always add a longer stem if it's a little short. If it feels too upright you can flip the stem to drop the bars.
    Apr 2012
    Quote Originally Posted by g-dawg View Post
    While true somewhat, don't forget about the implications a smaller frame has on your head tube. You can get a longer stem, but you can only stack so many spacers onto your steerer to compensate for the 1-1.5cm drop in HT length from the larger frame per size.
  1. MXL sizing confusion
    By bolo yeung in forum Merckx
    Last Post: 09-02-2014, 02:13 PM
  2. Square Taper Bottom bracket confusion, confusion, confusion!!!
    By Ride-Fly in forum Components, Wrenching
    Last Post: 10-06-2010, 08:30 PM
  3. '08 Kona JtS... sizing and confusion!
    By Marcos_E in forum Beginner's Corner
    Last Post: 08-03-2008, 05:06 PM
  4. Confusion over frame sizing.. 5' 10.5" and I need a 58cm?
    By mwilcko2 in forum Bikes, Frames and Forks
    Last Post: 04-04-2008, 03:29 PM
  5. Confusion about Sys 6..Help!
    By jinxkal in forum Cannondale
    Last Post: 06-04-2007, 06:43 PM
