Stack/reach question
Results 1 to 8 of 8
    Feb 2018
    I am looking at a new bike. Lately I have been getting some niggles in my neck from my position. I could change my position slightly, but would like a touch more upright in my new ride.
    The current front-runner is 11mm higher in stack than my current ride. Is this significant? So, if I had all the spacers set up on both bikes (or no spacers), would that 11mm be felt?
    'brifter' is a lame word.
    Depends. Some people will feel it for sure, some not. You? Who knows?
    I work for some bike racers
    and a bunch of skateboards
    Feb 2018
    Enough to potentially alleviate neck issues? I get that everyone is different, but I don't want to make a tiny change nor make giant change. Would a 1cm change be about right?
    Apr 2019
    They sell spacers as small as 3mm so to some people 11mm would be a very big change.
    The obvious answer would be to move the spacers on your current bike and see if it's noticeable but as it's only a couple of minutes work at most I assumethe steerer's been cut so you can't?
    ngl
    ngl is offline
    Jan 2002
    And to ad to suicidal's comment, if the is no more room for spacers then maybe flip your stem to get more height. Also, maybe get a bike fit to see if anything else could be adjusted. It'll be a lot cheaper than buying a new bike.
    Feb 2002
    Quote Originally Posted by billiegoat View Post
    In addition to all the comments about the effect of a change, consider doing some exercises to strengthen your neck and improve flexibility. That may be all that's needed to sort yourself.
    Feb 2018
    I have had a pro fit, BUT I changed it a bit. The fitter put me on a + angle stem minus a few spacers, but over time, slowly, I flipped the stem to a - angle (looks better to boot) and added some spacers (all of them, so no more room), so the net change was not all that big. Further, I have not been riding as much as I was, so maybe the exercises/stretches might be the ticket.
    Thanks for the replies!
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    If the only reason you want a new bike is to get a more upright position, change to a more upright stem and tilt your bars up slightly. You can get a good 35 degree stem for $30:
    https://www.trekbicyclesuperstore.co...SABEgLMOvD_BwE
    And here's a 30 degree stem for $40:
    https://www.trekbicyclesuperstore.co...m-333850-1.htm
    I have bulging disks in my neck and couldn't ride without one of these.
  1. Stack and reach measurements
    By musicociclista in forum Giant
    Last Post: 11-29-2009, 07:39 AM
  2. Replies: 3
    Last Post: 09-12-2009, 03:41 PM
  3. Stack/Reach of Sworks E5 from Geometry measurements
    By ceruleance in forum General Cycling Discussion
    Last Post: 03-30-2009, 04:13 AM
  4. Stack and Reach
    By cubz32 in forum Bikes, Frames and Forks
    Last Post: 11-02-2008, 02:51 PM
  5. LOOK - Stack and Reach Measurements
    By uscsig51 in forum Look
    Last Post: 11-13-2007, 06:35 AM
