Stack/reach question
Results 1 to 8 of 8
    Feb 2018
    Looking at a new bike and am having paralysis by analysis. So, with regard to stack and reach....
    1) In comparing two frames, is it as simple as comparing the stack and reach to determine which will fit best?
    2) if Bike A has a stack/reach of 580/403 and Bike B has stack/reach of 605/396. If A has a headset cap of 15mm and 25mm of spacers, and B has headset cap of 5mm and 10mm of spacers, are those basically the same?
    'brifter' is f'ing stupid
    Stack is basically the same. Reach is still obviously different but can be adjusted w/ stem length.
    #promechaniclife
    Reputation: 9W9W's Avatar
    Apr 2012
    Quote Originally Posted by billiegoat View Post
    Keep in mind the reach is to the steerer, your effective reach to the hoods will comprise of the handlebar and sram/shimano shifter combo. If you are comparing bikes between brands, keep handlebar reach/drop specifications in mind.
    "That pretty much sums it up. I'm 43 and my max is ~178-180. If that HR chart was mine or Froome's, we'd be on the verge of death. But for you it probably looks like a normal workout." -TLG
    LOLOLOL
    Feb 2018
    Right.
    I just wanted to make sure that A with all the spacers is basically the same as B slammed.
    Reach can be adjusted with a longer stem, in this case, one that is 10ish mm longer.
    Thanks.
    Oct 2017
    You can't change the actual 'reach' number. The head tube tube and bottom bracket are fixed. You can change your fit with a longer stem, setback seatpost, etc..., but there are potentially consequences.
    You need to understand that by lengthening or shortening the stem you are potentially changing the handling of the bike, and your weight distribution on it. There is a reasonable range you can use to compensate, but going to extremes in either direction isn't generally a good idea. Same thing applies to the seatpost.
    There are also other factors to consider. Reach is measured from the bottom bracket forward to the top of the steerer tube. Head tube angle and seat tube angle will also affect your position on the bike (as well as handling).
    Judging by the numbers you provided, the two bikes are *very* different. One seems to be a very slack, high stack endurance style bike, and the other likely a more aggressive race bike. You can change the stem, bars, seat and seatpost to adjust your sitting position, but this won't change the general way the bike handles. Wheelbase, chainstay lengh, tube angles, fork rake, your body weight over the the wheels, etc... will all effect how the bike handles.
    ^True^ but the reach is only 7mm different.
    #promechaniclife
    Oct 2017
    Yup, I guess the point I was trying to make is that if one bike has endurance geometry and the other race geometry, (unless your only goal is for the bike to fit) there is more to it than just putting on a longer or shorter stem.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Finx View Post
    You need to understand that by lengthening or shortening the stem you are potentially changing the handling of the bike........
    From my own experience, this is more of a mole hill than a mountain. But then again, that's probably dependent on the type of rider you are. I'm a strong hill climber, but I'm not a racer-hammerhead type.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
  1. Stack/reach question
    By billiegoat in forum General Cycling Discussion
    Last Post: 05-31-2019, 05:14 AM
  2. Replies: 3
    Last Post: 09-12-2009, 03:41 PM
  3. Stack/Reach of Sworks E5 from Geometry measurements
    By ceruleance in forum General Cycling Discussion
    Last Post: 03-30-2009, 04:13 AM
  4. Stack and Reach
    By cubz32 in forum Bikes, Frames and Forks
    Last Post: 11-02-2008, 02:51 PM
  5. LOOK - Stack and Reach Measurements
    By uscsig51 in forum Look
    Last Post: 11-13-2007, 06:35 AM
