stem rise & length
Results 1 to 2 of 2
    stem rise & length
    Rather than start a silly debate over the length of steering tube spacers, I thought I'd post a table that lists the additional rise obtained from stems with different angles and the change in horizontal length due to the angle. The table list values for an average length, 110mm stem. Longer stem stems will produce a bit more rise when flipped and shorter ones will have less. I left out a 73 (-17) degree stem since it offers no additional rise.
    A table like this can be very helpful in predicting the stem angle and spacer combination required to produce a particular handlebar height, if the head tube and headset height are known.
    I also made an Excel program that can calculate the stem rise and length for any stem.
    Whenever a stem is flipped the increase in rise is likely to be a few milimeters less than shown due to the fact the center of a stem's extension rarely intersects the center of the stem clamp. When a stem is flipped from 80 to 100 degree, for instance, a few millimeters of the theoretical rise will not occur due to the off-center location of the stem extension. Different brands of stems also vary in the height of the stem clamp, which can affect the rise by a few milimeters, if you're comparing two different brands. Most stem clamp heights are in the 35-40mm range.
    Well, the table doesn't post properly! Anyone know how to edit it to produce columns?
    stem stem HT additional horizontal
    angle length angle stem rise stem length
    80 110 73 13 109
    82 110 73 17 109
    84 110 73 21 108
    90 110 73 32 105
    96 110 73 43 101
    98 110 73 46 100
    100 110 73 50 98
    107 110 73 62 91
    Common stem angles: 73/107, 80/100, 82/98, 84/96, 90/90
    Reputation: Frith's Avatar
    Oct 2002
    thanks for the info
    let's see if we can make this a bit easier to read...
    stem angle stem length HT angle additional stem rise horizontal stem length
    80 110 73 13 109
    82 110 73 17 109
    84 110 73 21 108
    90 110 73 32 105
    96 110 73 43 101
    98 110 73 46 100
    100 110 73 50 98
    107 110 73 62 91
  1. The stem question, again...
    By Farmpunker in forum Components, Wrenching
    Last Post: 04-12-2005, 02:42 PM
  2. Colnago Frames - who do they fit
    By avitar in forum General Cycling Discussion
    Last Post: 05-07-2004, 12:25 PM
  3. relation between top tube length vs. stem length
    By NoMSG in forum General Cycling Discussion
    Last Post: 03-20-2004, 05:29 PM
  4. Proper BB length????
    By TNSquared in forum Components, Wrenching
    Last Post: 03-16-2004, 12:13 PM
  5. Where can I find the stem I need?
    By DoothaBartman in forum General Cycling Discussion
    Last Post: 03-11-2004, 01:53 PM
