A Strava Question...
Results 1 to 8 of 8
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    x
    So, I ride rollers in the winter. Is there a cycling computer or device (Garmin, etc?) That will track miles the way a standard (wired) cycling computer would do, (with a sensor on the wheel) so I can add those miles to my annual total?
    Just curious. I did 90-95 one hour sessions on the rollers last winter, and I would like to know what the theoretical miles would have been.
    Thanks!
    May 2016
    Quote Originally Posted by rideit View Post
    x
    Thanks!
    I use a Garmin speed sensor on the rear wheel and my Garmin 520 uploads the ride/miles to Strava
    'brifter' is f'ing stupid
    ^Works great^
    #promechaniclife
    Reputation: Srode's Avatar
    Aug 2012
    Quote Originally Posted by smokersteve View Post
    ^Works great^
    yep, that works - just make sure you have the Garmin set to inside trainer mode or you may not get much mileage credit because Strava will check and correct distance with GPS and that will only get you credit for the GPS drift. You can log the miles under a new bike called rollers and easily see how many roller miles you have vs real ones too if you want.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Feb 2002
    Emphasis on the theoretical. Equating roller miles with road miles is only meaningful if the effort required is the same for the same speed/distance ridden. If the roller resistance is really low, then you would get many more "miles" for the same amount of effort. Why would that "mileage" number be meaningful in any way? Likewise if you have rollers with high resistance or ride with low tire pressure. I understand the desire to log miles, but unless you have some means to compare the power expended, it's pointless.
    May 2012
    Interesting posts on power meter data riding on rollers.
    https://forum.slowtwitch.com/forum/S...lers_P3626255/
    Jul 2012
    Sounds like you need "smart rollers"
    Feb 2005
    Ok, then, next question, any of you use power meters on rollers?
  1. Strava Fan or Strava Hater?
    By Jason303 in forum General Cycling Discussion
    Last Post: 09-04-2013, 11:17 AM
  2. Strava Fan or Strava Hater?
    By Jason303 in forum Northern California
    Last Post: 06-28-2013, 06:06 PM
  3. Strava Question
    By Mufasa in forum General Cycling Discussion
    Last Post: 06-10-2013, 06:41 PM
  4. Strava Fan or Strava Hater?
    By Jason303 in forum Southern California
    Last Post: 03-18-2013, 12:12 PM
  5. QUICK strava question...
    By RobbMaxx in forum General Cycling Discussion
    Last Post: 09-05-2012, 02:35 PM
