Swapping SRAM APEX 11-32t cassette for something more conventional
Results 1 to 11 of 11
    Jul 2012
    What steps would I have to take to swap out my cassette to something with a more conventional gear spacing. I like the way Apex performs but I live in South-Eastern Michigan and the climbs here a nothing that extreme. Could I just swap out the rear cassette and been done with it or does the rear derailleur need to be adjusted? Just curious. Apparently I have the Wifli RD which has a max 32t capacity. I'd like to throw on like an 11-28 or something. Thanks in advance
    Idiot at large
    Apr 2010
    Throw a new cassette on, and shorten the chain.
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    May 2012
    Just swap it out, check the shifting and you're good to go. I just did the same thing, swapped the 11-32 on my Giant to a 12-27. I had to adjust the cable tension for the RD by 1/4 click but that was it.
    Mar 2013
    Quote Originally Posted by tednugent View Post
    +1, works every time!!
    Reputation: drmayer's Avatar
    Mar 2009
    Note that you don't have to shorten the chain, as it will be longer than it needs to be but it is not too long. I use an 11-32 and 11-28 on my cross bike and like to switch between them. I suffer no ill effects from the chain length when using the 11-28.
    Reputation: BigPoser's Avatar
    Jan 2013
    I'm doing something very similar except I picked up a Force RD to go with my 12-28. haven't got it on the bike just yet, but will soon.
    Nov 2010
    Re: Swapping SRAM APEX 11-32t cassette for something more conventional
    I went the other way for my needs, and had to swap parts out. You can adjust into a smaller <32 cassette, but you can't adjust from non-wifli into >28, you have swap parts. It was an adventure, and the principles all work to help you out.
    -cassette-install what you like, matching brand probably a good idea.
    -chain, between a 32 and 28, one link to long, but not significant, derailleur can handle it, or just remove a link - ez. If you have some fair mileage, wouldn't be a bad time to put a fresh chain on.
    -derailleur- the difference between wifli and standard are as I remember a 5mm longer body, (not just the cage is longer), the distance between the pivots is increased to clear the larger cogs. It has been argued whether a short is 'crisper' than wifli, I couldn't feel it, but to some folks, they have that ability, I don't.
    -adjustments - in these days of mass production, it should be cool, maybe a tweak. Don't forget to check/reset the b-screw for clearance.
    In my adventure I built the bike, ran a few hundred miles and figured I needed MORE gear, had to flesh all this out found you can't just swap cassettes and I ended up with the RD, cassette, and chain leftover-sitting on my bike bench.
    I hope that this helps.
    Jul 2012
    Quote Originally Posted by davez26 View Post
    Yes this makes sense. The Wifli seems like the equivalent of a long cage RD. Good to know that I can just swap them out on demand if I ever go somewhere with more climbing. wiggle has a really good deal on the SRAM PG1070 that I'm probably going to jump on.
    that 11-32t cassette is a strange thing. I always feel like I shifting trying to find that sweet spot, cruising speed gear and its just never there. I feel like I'm either spinning out or mashing too hard. Hopefully a new cassette will alleviate this problem
    Nov 2010
    In an 11-28/11-32:
    11-12-13-14-15-17-19-22-25-28, 11-12-13-15-17-19-22-25-28-32
    So you get the 14 you didn't have in the 11-32.
    11-12-13-14-15-17-19-21-23-26 seems like it would be pretty smooth if you could run it.
    Sometimes I feel I didn't have the 'right' gear with that spacing, but I need both ends here in CO.
    Strange to talk about when my first bike had a 14-17-21-24-28. In retrospect, I am spoiled.
    Feb 2002
    Don't touch the chain
    Absolutely no need to shorten the chain.
    'brifter' is a lame word.
    if the OP doesn't change the rear derailleur, why would he need to shorten the chain? please explain...
    I work for some bike racers
    and a bunch of skateboards
  1. sram apex derailleur/cassette ??
    By shackleton in forum Components, Wrenching
    Last Post: 05-18-2011, 07:44 AM
  2. Mixing Sram apex 11-32 cassette with Shimano Xt...
    By Ventura Roubaix in forum Components, Wrenching
    Last Post: 12-20-2010, 01:05 PM
  3. 1 x 10 SRAM apex w/ 11/32 cassette? Advice...
    By Jetmugg in forum Cyclocross
    Last Post: 11-11-2010, 11:49 AM
  4. When are SRAM Apex bikes coming out? When are the SRAM Apex groups being sold?
    By Stu_the_weak in forum General Cycling Discussion
    Last Post: 07-26-2010, 11:01 AM
  5. Cassette swapping
    By amygdala in forum Components, Wrenching
    Last Post: 03-25-2006, 09:59 AM
