Talk me into a 46/36
Page 1 of 5 123 ... LastLast
Results 1 to 25 of 101
    Feb 2006
    ....anyone?
    I don't get it. Why have less range than a compact?
    I'd think that anyone who thinks 50 is too big would also rather 34 instead of 36 on the other end for hills.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by saddle tramp View Post
    ....anyone?
    No. Given this is a road bike forum. That sounds dumb.
    Me either. About the only place that'd be useful is on a flatland cyclocross.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    What kind of bike, and what kind of riding? On trails with steep hills or pancake flat roads?
    I have 46/36 + 11-32 on my CX/Gravel bike, ride mixed terrain with a fair amount of hilly dirt but plenty of pavement, and it's great. I don't feel like I need a bigger chain ring when I'm riding it, even on the road... but I'm rarely trying to ride fast on that bike.
    I have 53/39 + 11-28 on my road bike, there are times I think about putting the 52/36 setup on but I still manage just fine on hills with it. I don't think I'll ever go back to a 50/34, and 46/36 would look really goofy on that bike.
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    IIRC, they use 46/36 in the circus, for the bikes that bears and clowns ride on.
    What the what???
    Jul 2009
    I liked 46/34 once upon a time. But, I ride on mostly flat land.
    Now, though, it's 1X on all my bikes. I like the simplicity.
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Russian Troll Farmer
    Sep 2016
    I dunno...10 cog spacing between rings kinda went out with 6 sp freewheels.
    "L'enfer, c'est les autres"
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Relic from CX, where if you needed a gear lower than 36/X you probably were faster walking...which also resulted in the only crankset for roadish groups that had lower gearing than a compact was 46/36.
    Today though you can get 46/30 or 48/32
    Proud luddite
    Reputation: azpeterb's Avatar
    Jun 2006
    If you already are against it and need to be talked into it then say no more...you made the right decision to begin with.
    Mar 2004
    Is this a mountain bike?
    Reputation: velodog's Avatar
    Sep 2007
    I'm running a 46x30 on a bike and like it, it's like a 1x with a granny. I rarely use a 50 tooth chainring with an 11 or 12 tooth rear cog so I didn't see a point. I now have more useable gears.
    Too old to ride plastic
    Feb 2002
    Keeping the standard 16t jump in a compact (50/34) would result in a larger % change by starting at a 30. So maybe (if available) a 46/31 would keep the same % change. Agree that 46/36 makes zero sense.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I concur. In a world where a 16 tooth jump has been perfected, why go back to only a 10 tooth difference? Makes no sense to me.
    "With
    -- DCGriz, RBR.
    Mar 2004
    i bought used cross bike with 46/36. and yeah, didn't really understand it. have a 50-34 on my road bike. so i swapped the rear to 11-34 (from 11-28) for the hilly area and trails i ride in. but since it's 110bcd/5-bolt, i can only find a 34 to swap the 36...
    road:: serotta.colorado calfee.tetrapro
    gravel:: felt.65x
    tri::felt.b12
    tandem::burley tosa
    Sep 2007
    Quote Originally Posted by jksu View Post
    Here's some sort of magic that is supposed to work. But think that the set of rings need be used together, but I'm not sure.
    https://www.ebay.com/itm/bikinGreen-...MAAOSwOj5cxUSS
    Reputation: Fredrico's Avatar
    Jun 2002
    ....anyone?
    If that 46 isn't too low for when you're really feeling good or about to be dropped on the Tuesday club ride, go for it. With all due respect to Lombard's 16 t. ideal, 10 teeth difference shifts faster and smoother than 16 teeth. Now you can use the front derailleur at speed. It'll shift precisely. The legs can pick up the cadence without losing bike speed, spinning out, or having to double shift in the back. I luxuriated one winter on the rolling hills of ETX with 52/44 in front and a 22 climbing cog in back. It was like having two big chainrings instead of one, instantly selectable with a quick flick of the shifter, no cadence pick ups, just ever so slightly easier or harder, exactly what rider wants on a hard ride.
    That 36 inner ring or larger would climb well on a 20-25# road bike. On a 30, rider would be spinning out at 8 mph, or riding a few cogs out. Much easier fighting gravity at 70-80 rpm than at 95-110, if the hill isn't a sprint. No need to be "under-geared" on pavement.
    If a horse could draw a buggy up the grade, a bicyclist can with no problem, in 42-28, for starters. Take it from there!
    Feb 2002
    Quote Originally Posted by Fredrico View Post
    I don't think that he presented 16t as an "ideal" but rather something that has been well worked out and works well. Of course a smaller tooth jump will tend to shift better. Back in the "half step plus granny" days, 3, 4, or 5t jumps made for really smooth front shifts, but limited the gear range. And that is the reason to stick with the 16t jump - to gain the full use of the cassette range.
    I can see the narrower jump for actual CX racing where pressure on the shift is high and missing a shift can cost you. For general use, it doesn't offer much benefit and you lose a bunch of gear range.
    Banned Sock Puppet
    May 2014
    Exactly. Chain drops were made virtually non-existent with the Shimano 5800/6800/9000 generation and beyond. Shifts smooth as silk.
    As usual, Fred's posts should be taken with a grain of salt which would lead us to believe he regularly rides up hills in these difficult gears even though we have never seen him pedal a bike. Lastly, comparing horse power to human power is ludicrous to say the least.
    "With
    -- DCGriz, RBR.
    Jun 2002
    Builders graded roads that could handle one horse power pulling a carriage. Those roads are still around and graded perfectly for one person on a bicycle. The roads in DC Metro, the rolling hills of ETX, and even the LA valley and adjoining hills, are all doable by riders with a few thousand miles in their legs, in 42-28 on a 24# road bike. That's all I'm saying.
    Paris-Roubaix riders have 52/44s and 53/45s. They want larger gears, finding slower cadences keeps the bike on the cobbles more evenly. They don't want the range a climber would prefer. The course is flat.
    IOW, use the gears that work. Get rid of the ones that don't and you never use. The legs don't need the "bailout gears" after the first year. How often do you use that 50-11 or 34-30? How often do you climb in 39-28 for that matter? I never see it on the MUT.
    Also, my experience wrestling with thousands of these bikes, is that 16+ tooth jumps is just an invitation for a lost chain. The rear derailleur has to take up lots of slack. If the stop screws are slightly out of adjustment, the cage is slightly out of parallel with the rings or too high, the chain is worn out, shifting on a bump in the road can drop the chain. This never happens with less than a 10 tooth jump. The movement is minimal, so rear derailleur quickly takes up the slack. Shimano engineers the chain and rings to shift under power. That would minimize chain slack, but most riders don't shift under power.
    Banned Sock Puppet
    May 2014
    Of course you never see it on a MUT. MUT's are mostly flat to 3% max.
    As I stated before, modern drivetrains are designed to handle a 16 tooth jump. I have been riding 8000+ miles on these and have dropped my chain exactly twice in that time. Both times were my own error, not the fault of the drivetrain. If you know how to shift properly, this no longer is a problem.
    FYI, I recently had to replace a chain on a 6800 drivetrain at 6000 miles due to a stiff link. Guess what? This chain had almost no wear otherwise. I even cross chain in small-small quite often. Replaced the chain, old cassette, still shifts flawlessly.
    Have you ever ridden a bike with a modern drivetrain, Fred? From your past posts, it sounds like most of your equipment is vintage. Nothing wrong with that IMO, but comparing the behavior of 1990's drivetrains to present day equipment is an apples to oranges comparison.
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    May 2011
    Stop riding the MUT and go out on real roads. Why do you need gears at all on a MUT?
    I use 50-11 & 34-30 on virtually every ride. But then.... I never ever ride on a MUT.
    You really don't know what you're talking about.
    I realize that in the Cat 7 world of MUP chasing and fantasy rides quick shifting is very important and 44/22 is all anyone would ever need for those monster daydream climbs.
    But in the real world where people ride fast and/or competitively; needing to shift in the front "at speed" is quite rare (as is losing half a revolution to do it mattering) and the need for gears lower than 44/22 is not rare at all for those who might actually climb not just post about it on the internet.
    But I do realize that losing half a pedal stroke to shift could make or break getting by a dog walker in time to beat someone to the next crosswalk so whatever works for you.
    Banned Sock Puppet
    May 2014
    I tried to put it in a nicer way, but yes. I don't think Fred has worked on a bike in a long time.
    BTW, you need to correct that quote which was written by Fred, not Saddle Tramp.
    and the need for gears lower than 44/22 is not rare at allfor those who might actually climb not just post about it on the internet.
    Bingo!
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    May 2011
    facts are neither mean nor nice.
    Thanks. Fixed. Didn't notice that. Must've been autosaved in there.
    Feb 2002
    Really? 35 mph? I take it you would rather pedal down hills than just get in a tight tuck and coast? You would actually be faster in the tuck.
  1. Why 36/46 and not 34/46?
    By CharT in forum Cyclocross
    Last Post: 07-07-2015, 07:01 AM
  2. Chainring pairings - 34/46 vs 36/46
    By jared_j in forum Cyclocross
    Last Post: 06-15-2012, 12:08 PM
  3. Mavic SUP cermaics 36/36 vs 32/36
    By bolo yeung in forum Wheels and Tires
    Last Post: 07-30-2010, 10:09 AM
  4. Want to go 46/36/26 or 48/38/28 on my triple....
    By Doggity in forum Components, Wrenching
    Last Post: 08-25-2006, 09:42 AM
  5. Pew Research Ctr poll has it 46 - 46...
    By spyderman in forum Politics Only
    Last Post: 09-17-2004, 09:12 AM
