Is there help to smooth out ride?
Results 1 to 20 of 20
    Feb 2010
    I'm new to the road bike scene, so maybe there is just an adjustment period I'm going through. However, it just seems like I'm getting beat up some riding. I've only ridin 110 miles with the farthest one-time stretch being 12 miles. I ride 25% on street and 75% on concrete paved bike path. I ride an entry level Fuji Roubaix. I know coming from my mtb which has a front shock, wider tires, and less air pressure in those tires, but man I feel every little bump and crease in the pavement on my roadie-hands kinda hurt, lower back hurts-it just feels like a very rough ride.
    I'm I just going through the adjustment period or are there things I can do to the bike that would comfort the ride?
    Dan
    May 2008
    The same thing you do on the mountain bike. Bigger (wider) tires if possible, lower pressure (still higher than the mountain bike).
    Sep 2009
    yeah, tires and pressure.
    Better wheels can help too but the price per benefit isn't as attractive there.
    Reputation: 2ndGen's Avatar
    Oct 2008
    + more comfortable Saddle, try Gel on your handlebars and thicker bar tape (possibly with Gel inserts in the tape itself like Fizik's).
    And, yes. Definitely there is an adjustment period.
    If you ride once a week, you'll be re-adjusting all the time.
    You need to put in some regular riding almost daily even if it's just 15-30 minutes.
    Keep those new "roadie" muscles loose once you get them loose.
    Probably slower than you.
    Reputation: suprcivic's Avatar
    Apr 2009
    I've also found that concrete paths can hurt more than the road. There are a lot of seams on those paths and each one hits rythmically, eventually causing pain. Asphalt has a bit more give than concrete and a lot less of those seams. I avoid paths when possible.
    Apr 2005
    Possibly a bike fit issue? How much time was devoted getting the bike sized up for you?
    But if it fits right, first thing I would do would be to get as wide a tire as your bike can handle and drop some pressure. If you have alot of seatpost exposed, a carbon post could help a bit. But it's an expensive add on that has only a small benefit. Look at getting gel pads for under the tape.
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    Your riding style has a lot to do with it. MTBs, fat tires and shocks let a rider get away with just slackly sitting on the bike and letting the bike absorb the bumps.
    On a road bike, you have to absorb the bumps with your body. Flex your elbows slightly. Raise up off the saddle ever so slightly when you go over a bump. This is easier to do if you are pedaling, and easier still if you have a good road bike position (different from an mtb position) and are riding hard.
    It's a different style of riding entirely. Learn to let the bike move around under you, and your arms / legs are the shock absorbers.
    Also +1 most concrete paths suck with bad seams every few feet.
    * not actually a Rock Star
    Reality Star
    Reputation: Don Duende's Avatar
    Sep 2007
    1. Bike fit
    2. Wider tires
    3. Lower tire pressure
    4. Gel handlebar tape
    5. Carbon fiber seatpost and handlebar
    6. Tubeless tires and wheelset
    Feb 2010
    Thanks for all the replies. I'm sure it will take a little longer to get adjusted than i thought. My to-do list this week will be to add wider tires (currently have 700 x 23) and gel tape to the handlebars. As far as paved bike paths, I think its safer than the roads in my area and I have access to a trail opening for a 20 mile paved trail system about a 1/2 mile from my front door.
    Aug 2006
    It took me a while to get used to roading my road bike. I didn't feel comfortable on it at all at first. If you've ever ridden BMX or a rigid mountain bike then you have a good idea of how to get off the seat and isolate yourself from the frame using knees and elbows as shock absorbers.
    Also a good pair of gloves goes a long ways toward helping hand/wrist soreness I found, but I also found that was something that went away as I rode more.
    Resident Curmudgeon
    Nov 2005
    Is it an aluminum frame? If it is, that explains a lot.
    Aside from that the advice above is good. Maybe the most effective change to achieve maximum comfort is to install the widest tires that will fit on your bike.
    Jan 2010
    I have a Fuji Roubaix all Al frame with the full carbon fork and it's one of my most comfortable bikes on the crappy urban rides I do here daily. So Mr V I don't agree with you. I run 25mm tires and it's a great ride.
    Feb 2010
    update
    Took some advice and purchased better, wider tires (Conti GP4000 700 x 25) and lowered air pressure to 100psi. Purchased some new bar tape w/gel inserts and leveled my saddle a smidge.
    I rode 12 miles today and noticed a difference. I won't say night and day but the new products definitely had a positive affect. Much more enjoyable ride.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by dan711
    For what it's worth, 100 psi is my max pressure for smooth roads. For crappy roads, my 700 x 25s get about 80 psi to haul my 150 lb body around in relative comfort.
    Jul 2009
    Basic question: do you have padded cycling shorts?
    Also, I found that padded gloves completely eliminated any finger numbness I was having (I use Pearl Izumi fingerless gloves).
    Asad
    m_s
    m_s is offline
    oh lonesome road for you
    Nov 2007
    When you say you're used to mountain bikes, do you mean just riding them on the street, or riding them on trails? becaus eif you're used to trail riding, you would know that no matter what, you can't rely on the bike to absorb things for you. Your own body is the best suspension. Relax your arms, that's big. If you see a particularly rough section of pavement, hover above the saddle and use your legs to absorb the shock.
    Guaranteed results. good luck.
    Reputation: Jerry-rigged's Avatar
    Jul 2009
    X2 - this is still too much pressure. I run my 700x23's at 90, and a bit less for chipseal roads. I weigh 190 now... The only time I run 100 or more PSI is on hill country rides where I KNOW I will have high speed down hill runs, and only then because the thought of a pinch flat at 40+mph scares me...
    Veni, Vidi, Vomiti.
    Beetpull DeLite
    Quote Originally Posted by wim
    Yup....I'll often decrease the pressure in my 23s to around 85-90 on rough roads. I'm about the same weight.
    Feb 2010
    So the consensus is to run tire pressure below 100psi. LBS's in my area said to run at 120. No wonder my ride was so rough. I will lower the new tires (Conti GP4000 700 x 25) to 90 and give it a go on my Saturday morning ride. Thanks
    Devoid of all flim-flam
    Reputation: Mapei's Avatar
    The way I see your problem, it's that everything is relative. A road-racing bike will always be more rattly and and stiff than a suspended mountain bike, no matter you do. It's part of the gestalt. Lower tire pressures, padded shorts, gloves, etc., definitely do their part, but your sporty Lotus Seven race car will never be a Cadillac. Aluminum is usually harsher and stiffer than steel or carbon-fiber, but it's a matter of degree. From a suspended MTB perspective, it's never a difference of night and day. A pothole will always be painful.
    In other words, don't expect miracles. As some folks above say, harden up a little. Be on the lookout for road imperfections and lift yourself slightly off the seat when you go over them so your arms and legs can absorb them. The payoff is that, as you've probably noticed, with your road bike you can go a heck of a lot faster with a heck of a lot less effort than with your mountain bike.
    Mapie is a conventional looking former Hollywood bon viveur, now leading a quiet life in a house made of wood by an isolated beach. He has cultivated a taste for culture, and is a celebrated raconteur amongst his local associates, who are artists, actors, and other leftfield/eccentric types. I imagine he has a telescope, and an unusual sculpture outside his front door. He is also a beach comber. The Rydster.
