Two tire failures, need some advice
Results 1 to 23 of 23
    Jun 2015
    My son has suffered 2 tire failures that have me looking for a root cause. The bike is a Jamis Quest. New this season. I swapped out the OEM tires for a set of the new Pirelli P Zero Velo's, 700X25, using the OEM tubes. All good for about 6 weeks. He went out for a ride, and just before getting home, heard a loud pop, and had a rear flat. Inspection of the tire revealed a split sidewall, on the non-drive side, that was radial (perpendicular to the brake track) and about a 1/2 inch in size. When I took it all apart, did not notice anything unusual with the wheel. I chalked it up to a manufacturing defect, and replaced both tires with Conti Grand Prix 4 Seasons. One or two rides later, the exact same failure, in the same location (rear, non-drive side, radial split in the sidewall).
    When I installed the Conti's, I used new tubes, but they were 700X18-23, instead of 700X23-25. The Conti's were new, old stock, having spent about 3 years in my basement. My son weighs about 150 lbs and we were running 90 psi for pressure.
    Any thoughts on what might be going on here would be much appreciated.
    Jim D
    Nov 2009
    Quote Originally Posted by desaljs View Post
    Jim D
    Friendly warning, move post to tire section of forum.
    Dec 2005
    Not sure. Hopefully Kerry Irons will chime in and perhaps a picture would help if you have one?
    0.5"=12.7mm or half the width of the tire. Where did the split start and end? You said NDS but, across the bead or is the bead intact? Lastly, did both failure occur at or very near the same location around the wheel? Meaning, for example, both failures happened 90 degree or 180 degrees etc...from the valve hole.
    Jun 2015
    The split started close to the bead, but did not involve any part of the tire that clinches to the rim. It extended just short of the tread area. The bead was intact. Any yes, both splits occurred in about the same area, on the non-drive side of the tire. Loud pop both times. Hope this helps, and thanks!
    Dec 2005
    I'm obviously not sure but, the only time I ever had a tire do this there was a bur or some imperfection on the rim somewhere near the bead. (EDIT) on the inside of the brake track or facing the tire surface...if that makes sense.
    Sounds like either a combination of bad luck or not using tires suited for the terrain. Simple case of hitting something that cut the sidewall. I had that happen several times with those conti tires. I wouldn't even look at a gravel road with those.
    I would have suggested brake rub as a possibility but "perpendicular to the brake track" kills that theory.
    Jun 2015
    Sorry about posting this in the wrong section. Not sure how to move the post.
    Jim D
    Nov 2009
    Jim D
    I prefer you post it here but there is another guy that, well.................
    Reputation: BlazingPedals's Avatar
    Apr 2013
    It sounds like he's running over a piece of metal or something, that's cutting the tire.
    Dec 2005
    Quote Originally Posted by BlazingPedals View Post
    The op stated the two cuts have happened not only in the same spot across the tire (radially), similar sized, but also in the same location around the rim as referenced from the valve hole. The chances of hitting something in the same spot same orientation same length must be astronomical.
    Nov 2009
    brake pad rubbing tire?
    Oct 2013
    Might want to look at the wheel, not the tires/tubes. Take the tire/tube off and take a look at wobble & hop. I bet your wheel has a big hop in it. The tires will overheat after riding at that one hop and kablueeee. You can ask how I know.
    BANNED
    Reputation: PJay's Avatar
    May 2004
    A lot of tube pops happen near the valve, if the problem happens to have to do with wrong pressure. i used to be really good at filling up tubes with co2, but lately I have gone a bit too far, and the tube either bulges right around valve, or pops. Also, the construction is different at the valve relative to the rest of the tube. But I really cannot think of defects in more than one tube. Maybe harming tube with tire lever, in some systematic way, i.e. same place same technique, when mounting tire?
    Dec 2005
    Quote Originally Posted by factory feel View Post
    A number of things can cause brake pad rotation to be misaligned (front or trailing edge of pad can extend past the very top of the brake surface where it interfaces with the tire).
    It can happen quite easily if you don't pay attention and just installed new pads and say went from a 23 to a 25mm tire or went to a new wider type wheel and tried to squeeze the tire between the pads. They (pad holders) can easily rotate just enough to cause the pad to rub the tire...an easy fix with a hex wrench or two but, it does happen.
    Oct 2013
    another troll comment?
    This is ridiculous!
    BANNED
    'brifter' is a lame word.
    Why should he post a question about TIRES in a section other than WHEELS & TIRES? So he can turn into a troll like you?
    I work for some bike racers
    and a bunch of skateboards
    This is ridiculous!
    Ludicrous I say!!!
    Is there anywhere that might have a track for a gate or something that's attached to the ground? That your son happens to run over on his regular ride? That's the only thing I can think of now that would cause damage like that more than once. We have a rail that our gate rolls on at the shop, the rail is triangular in section and about an inch high...I could see that causing tire damage if hit hard enough.
    Nov 2009
    This is ridiculous!
    and outrageous!
    Nov 2009
    so you don't cry about it?
    Oct 2002
    Are there railway tracks he runs over? The high speed impact could produce a blow out like that. Maybe a bridge with an uneven approach? I am thinking the same as CX here. It's probably a rider induced stress. How old is your son?
    Jun 2015
    My son is 20. Good rider. We do have some railroad tracks on the route, and few bridge expansion joints that are a bit rough. We do hop or unload weight as we cross those. Also, some fresh tar and chip on some roads.
    Appreciate the input. I'm thinking road hazard, but will take a very close look at the inner surface of the rim. Just waiting for new tires to arrive. The wheel is true. No hops. No brake rub either.
    Jim
    a real member's member
    Jul 2016
    what kind/model of rim?
    Jun 2015
    Ritchey Comp Zeta 20/24 with DT spokes.
  1. Two Broken Spokes, Two Wheels, Two Rides
    By My Own Private Idaho in forum Wheels and Tires
    Last Post: 10-28-2014, 03:43 AM
  2. Tire pressure advice, I need some
    By HIMEHEEM in forum Cyclocross
    Last Post: 09-30-2010, 06:58 PM
  3. Tire advice please... I need to order some quick
    By solomr2 in forum Wheels and Tires
    Last Post: 12-31-2009, 08:22 AM
  4. Two tube failures in a week!!! HELP...
    By Pokey in forum Specialized
    Last Post: 07-16-2009, 11:15 PM
  5. A Trail of 'Major Failures' Traced to Rumsfeld
    By velocity in forum Politics Only
    Last Post: 08-25-2004, 05:52 AM
