ultegra 6800 11s vs 6770 di2 10s ?
Results 1 to 25 of 36
    Nov 2005
    I'm looking to upgrade my present 6600 ultegra group, it needs new cables, cassette, chainrings, chain anyway its a 2008 edition with around 10000 miles and I'm looking at either 6770 di2 or the 6800 11 s. with price not being a factor, (i can get the 6800 for around $500 cheaper) any opinions either way? I've never had 11s or electronic so anyone with experience with either negative or positive opinion is what I'm asking. thanks for any help. I'll probably wait till the season is completely over for best pricing.
    δanned
    Reputation: SauronHimself's Avatar
    Nov 2012
    I personally enjoy my 10-speed Ultegra Di2. It shifts much more crisply than the 6600 I had on my Orbea Onix. While the 6800 11-speed group may be cheaper I'm hard pressed to see how 11-speed improves upon 10-speed. Ten cogs is already more than most people use anyway. With 11-speed systems you obviously need a wheel with a hub that is compatible. The wheel builders on this forum may also chime in with how 11-speed rear wheels are a new beast with respect to dishing and tensioning.
    Jul 2012
    This would be a very hard decision. Having upgraded my bikes to 11 and still having one with 10, I have felt that the added middle gear was very beneficial. I would still be hard pressed to give up 10spd di2 for 11spd mechanical though.
    Nov 2005
    thanks for the reply, I am leaning toward the di2, being in NJ I don't have a need for the extra gear and I forgot about changing my hub to be compatible with 11s.
    Reputation: siclmn's Avatar
    I just laugh at all the "I need to go to 11 speed because they invented it posts"
    I ride a lot of 18 to 22mph rides on my 1 speed. People are amazed that it can be done.
    To obsess over 10 to 11 speeds is ridiculous
    My road bike is DI-2 and it has worked perfectly for over 2 years now. No more tune-ups or chain falling off the chain ring problems.
    Bike shops are not pushing it because there is no yearly "taking it in to have it adjusted" any more.
    Aug 2010
    Isn't 11sp Ultegra di2 coming out in November? You could always wait for that if you want to future proof.
    Reputation: spdntrxi's Avatar
    Jul 2013
    I hope people go Di2 11s... because I'm looking to get Di2 10s on the cheap.. DA 7970 to be exact.
    Sep 2012
    I am having the same dilemma - 10 speed Di2 or 11 speed mechanical. Have thought about waiting for 11 speed Di2 but suspect the price will take it out of my reach. I am not really bothered about 11 speed specifically but the Di2 11 speed does look much better than the outgoing version. The Front & Rear deraillers certainly look smaller and neater on the bike.
    Feb 2013
    Re: ultegra 6800 11s vs 6770 di2 10s ?
    I'm in the same boat, 10 speed ui2 vs 11 speed 9000.... Same frame close in price. Leaning toward ui2 since I want to try electric and I think I'll have more options in the used aero wheel market
    Nov 2005
    I'm thinking when the di2 11s come out in november I'll buy the di2 10s for a great price or at least a good price.
    Quote Originally Posted by Dunbar View Post
    Apr 2013
    I've had both both a 9 speed and a 10 speed shemano. I can't imagine why anyone would feel the need to upgrade to an 11 speed. Not sure what the manufacturers are thinking. Either they watched too much spinal tap or just into jumping the shark.
    Aug 2010
    Quote Originally Posted by Trek_5200 View Post
    For those of us who climb 11sp offers wider range cassettes without the big jumps in the middle part of the cassette. 11sp Dura Ace and Ultegra are supposed to be a huge improvement over 5700/6700/7900 mechanical groups in shift quality. Shimano didn't do a great job with it's first generation of under-bar-tape mounted derailleur cables IMO. My 4600 Tiagra bike shifts smoother than my 5700 105 bike. I wouldn't drop hundreds (to $1k+) just for an 11th gear but if you're in the market for other reasons 11sp does make sense for some.
    Reputation: otaner142's Avatar
    Jun 2013
    Dont waste your money !! Its all about marketing !!! And loud hubs and aerodynamics and weight and bla bla bla ! Think smart they are all going to change at the press of a button and at your need!! 11 speeds ? Do you really need it ?
    Sep 2002
    Went through the same thing in the spring. 7970 or 9000.
    Went with the 9000 and converted two wheelsets to 11 speed, my Ksyriums amd Fulcrum were already compatible.
    No regrets, no looking back. Would not have been happy on a second tier group.
    Apr 2013
    Ditto!
    The bike companies are now marketing bikes like cars. Think about how you will use the bike and it's ride qualities. The number of gears , whether the carbon is defense grade, sold exclusively to your bike company is just marketing and an attempt to convince you the bike you currently have is obsolete.
    Nov 2005
    I can get the Ultegra DI-2 kit(shifters,derailleurs,all cables,battery,charger and crank) for $1249 from my lbs + installation now. Is this a good deal now, or should I wait for the di2 11s and the 10s will be even cheaper? this will be the shop that will do the install anyway and i don't want to pi$$ them off unless if I wait till november and the 10s kit is under $1000. thanks for any help.
    δanned
    Nov 2012
    Quote Originally Posted by rlrj View Post
    If you do a Google search, the Ultegra Di2 groupset goes for about $1290 shipped from Cycle Sports UK, so I'd say you're getting a good deal as is.
    Sep 2012
    I have found 2 Trek bikes that are the same price.
    Trek Domane. 5.9 2013 Di2 10 speed
    Trek Domane 5.2 2014 Ultegra 6800 11 speed
    Which one should I go for? Cannot decide!! Maybe i should post this in the Trek dedicated forum.
    Jun 2012
    I ride Ui2 and I would suggest it over mechanical for the smoothness and lack of adjustment alone. It's definitely a luxury, but if you want to drop the cash, go for it!
    I ran into the VP of sales for a big big company a couple of days ago, and he said that the sales of Ui2 are astonishingly low. Like 1/100 of di2 sales. That's why it's so cheap right now (got my bike for $1800 of retail recently).
    Jul 2012
    Quote Originally Posted by lostPixels View Post
    I don't understand that part, what you're basically saying is ui2 sales are astonishing low. So for every ui2 sale, they sell 100 di2's?
    I would hope that's a mistake since there is no such thing as ui2, but rather ultegra di2.
    Now if you meant for every electrical unit they sell, they sell 100 mechanical, that makes more sense.
    Jun 2012
    By Ui2 I mean Ultegra Di2. I see a lot of people abbreviating it as Ui2...
    I do mean that Ultegra Di2 is selling 1/100th of the rate as Dura Ace Di2. This is straight from the VP of Marketing and Sales of one of the top Bike companies (think Specialized, Cannondale, Trek etc.). I even looked him up after writing this to confirm he wasn't just BS'ing about his job.
    Jul 2012
    Wow, that's interesting. Thanks for clarifying
    Jun 2012
    Yup! He was saying that it's probably because of the price. Too expensive for most, but not the best for those who are willing to shell out for the top groupset.
    δanned
    Nov 2012
    I don't get why Ultegra Di2 would sell so poorly compared to Dura Ace Di2. I don't see how Dura Ace Di2 could shift any better because the Ultegra version is already fast and crisp.
    Jun 2012
    I agree. The only minimal advantages of Dura Ace are weight, and smaller derailleurs. Ultegra Di2 is amazing, especially because it's significantly discounted right now with 11 speed coming out, and lackluster sales.
  1. Ultegra 6800 cranks 10-speed compatible?
    By eickmewg in forum Components, Wrenching
    Last Post: 12-04-2014, 10:07 PM
  2. What's the difference btwn Ultegra Di2 6700, 6770, 6800, 6870 ?
    By Gc0aifi in forum Components, Wrenching
    Last Post: 02-17-2014, 10:58 PM
  3. Ultegra 6800 11-Speed...it's here!
    By krtassoc in forum Shimano
    Last Post: 10-11-2013, 10:05 PM
  4. Ultegra 6800 ship date
    By LEW 3 in forum Components, Wrenching
    Last Post: 07-23-2013, 12:08 PM
  5. 2014 Tarmac with Ultegra 6800 11-Speed!
    By krtassoc in forum Specialized
    Last Post: 06-22-2013, 05:38 PM
