Valve extenders and tubes without removable cores?
Results 1 to 23 of 23
    Aug 2015
    Just ordered some deep dish wheels and wondering how the valve extenders work. Will the presta tip screw itself down when attaching the valve extender or do I need tubes with removable cores (or tubes with LONG stems)?
    I have quite a stockpile of short, non-removable-core tubes. Assuming I DO need removable cores because attaching the extender will close the presta valve, is there a workaround for this? Like crimping the tip with it open to keep it from screwing it down? Breaking the tip off once its open?
    I always carry a spare tube but if I were to flat that one too, just trying to think of how I'd address the situation if I was out in the wild and had to "bum" a tube from someone else and it didn't have a removable core. Hope that all makes sense.
    Jul 2012
    Never used them on presta, but have on schrader years ago (mtb). If they work the same then you'd just undo the valve then screw the extender on, then the extender when you use it just presses down on the normal valve to work. Well thats how the valve adapters seem to work presta->schrader for different pump heads. Could be completely wrong.
    All the gear and no idea
    Feb 2013
    With non removable core valves you just unscrew the top part and leave it loose while you screw the valve extender over the top of it. The valve extender shouldn't catch on it and do it up again.
    Personally I like using tubes with long valve stems (including my spare regardless of which wheels I'm running, deep or shallow profile etc), but carry a valve extender with me in case I need to bum a tube off someone in an emergency
    Reputation: stevesbike's Avatar
    Jun 2002
    Quote Originally Posted by TmB123 View Post
    this. plus you'll likely need some plummer's tape to wrap around the valve threads to make the seal tight. Mavic used to sell valve extenders that included small o-rings but I haven't been able to find these in awhile.
    'brifter' is f'ing stupid
    Quote Originally Posted by thisisthebeave View Post
    Just ordered some deep dish pizzas and wondering how the valve extenders work. Will the presta tip screw itself down when attaching the valve extender or do I need tubes with removable cores (or tubes with LONG stems)?
    ftfy...
    'Dish' is how the rim is centered over the hub. 'Section' describes the rim shape.
    Tubes w/ cores that can be removed are the best. If you can't get those I'd recommend opening the valve all the way then forcing it a bit more so it will stay or even crimping it a bit w/ pliers.
    And posting in the correct section of the forum is always good too.
    #promechaniclife
    Nov 2009
    I'm Hungry
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I've had them vibrate closed on me. I put a dab of Loctite on the valve nut threads to prevent it.
    I carry a spare with a long stem so I don't have to bother with the extender. I also carry an extender with o-ring in case I have to borrow a tube.
    You could put a few wraps of Teflon tape on your spare tube valve. If you had to, you should be able to remove it and put it onto the new tube. (Also helps to ride with friends who have deep wheels)
    Quote Originally Posted by stevesbike View Post
    There are other brands that make them. I have a few but can't remember the brand.
    Aug 2015
    I'll be using ENVE extenders if that matters
    They now do extenders for removable valve core tires/tubes. Those would be the best way to go on your deep section rims.
    #promechaniclife
    Feb 2013
    I bought some of the Silca valve extenders that have the silicon sleeve on them that is supposed to sit in the valve hole and stop rattling. They also come pre loaded with sealer on the thread so don't need plumbers tape and come with the small o-rings as well.
    Presta Valve Extensions (For ALL Presta valves) | SILCA
    Crank Addict
    Mar 2014
    All you need to know about valve extenders...
    Valve Extender How-To - Slowtwitch.com
    ___________________________
    2016 Pactimo Brand Ambassador
    www.Crankaddicts.cc
    www.skratchlabs.com
    www.hilltopbicycles.com
    2017 S-Works Tarmac SL5
    2015 S-Works DSW Allez
    2014 S-Works Shiv TT
    2015 Specialized Fuse Comp
    Aug 2015
    My extenders (enve) do not grip the threads of the valve. Based on this video it looks like the enve ones thread INTO the valve rather than on top of it.
    https://www.youtube.com/watch?v=SB1lEfnsWK0
    Feb 2013
    Right, so they are removable core extenders, so you need removable core valves on your tubes to use ones like that.
    You don't HAVE to use ENVE extenders, can use whatever you want.
    Just get Conti Race 28 tubes with 80mm valves. So. Much. Easier.
    Aug 2015
    Wouldn't that not work with a 70mm rear wheel depth? Only 10mm for the pump to grab?
    Feb 2013
    It would be close, and I guess that's up to you to work out what you can live with.
    It would actually be closer to 20mm as I assume the 70mm wheel depth is measured including the brake tracks, the valve only has to go through from the base of the tyre bed so you gain a bit there. As an example on my Zipp 404's (58mm deep wheel) I have 25mm of valve to the top of the threads showing and 30mm to the top of the knurled nut that you unscrew on an 80mm Conti tube. I use a Lezyne floor pump that screws onto the valve head so I don't have to seat a bigger clip on pump head to the valve either.
    Aug 2015
    Good call, forgot about the brake track. I was wondering how a 48mm valve on my other tubes left me with ~28mm left over on my 35mm deep wheels.
    The ENVE extenders are rubberized so they don't knock around in the wheel so I'll try those at first. If I don't like them I'll get 80mm tubes. Thanks for the help.
    Reputation: spade2you's Avatar
    May 2009
    I had one and and used it for several years. Worked great. Lost it when I moved and was super bummed.
    Reputation: Srode's Avatar
    Aug 2012
    Ok, I'm in the same boat here - have a stack of new 42mm presta Race 28 Continental tubes - Do they have removable cores? (I'm not at home to look at them for a couple days) ENVE 4.5s will be here Monday and they come with ENVE supplied extenders, so it sounds like I may need to get a different extender or different tubes to go with them.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Reputation: looigi's Avatar
    Nov 2010
    ...'Dish' is how the rim is centered over the hub. 'Section' describes the rim shape...
    I think we're losing the battle on that one. I guess wheels can have dish, and pizza can be be deep dish, so why not deep dish wheels? After all, we do have tacoed wheels, to continue with the fast food analogies.
    ... 'cuz that's how I roll.
    Sep 2002
    They can't vibrate closed on you. The 100 lbs off pressure inside the tube is forcing them open.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by factory feel View Post
    I'm Hungry
    Nope. Not at all fan of deep dish. I prefer Neapolitan or CA thin crust.
    "With
    -- DCGriz, RBR.
    coaster
    Reputation: Lelandjt's Avatar
    Sep 2008
    I use non-removable core valves with teflon tape on the threads. I superglue the nut in the open position. 28mm valves hidden in 50mm deep rims with a square of electrical tape covering the hole.
    May 2009
    I found some Topeak extenders for my spares via Amazon.
  1. tubes with removable valve cores
    By forgivenick in forum Wheels and Tires
    Last Post: 05-29-2012, 12:42 PM
  2. Do all tubes have replaceable valve cores?
    By ecub in forum General Cycling Discussion
    Last Post: 01-21-2012, 08:35 PM
  3. Valve extenders for non-removable core
    By Cpk in forum Wheels and Tires
    Last Post: 10-04-2010, 05:41 PM
  4. removable presta valve cores
    By spookyload in forum General Cycling Discussion
    Last Post: 02-09-2005, 05:31 PM
  5. do Vittoria and Vredestein tubulars have removable valve cores?
    By weiwentg in forum General Cycling Discussion
    Last Post: 06-29-2004, 09:58 AM
