Wahoo elemnt bug: for firmware ELEMNT WF42-1422: sensors unpairng and phone unpairing
Results 1 to 5 of 5
    Reputation: pittcanna's Avatar
    Oct 2014
    All please do not upgrade your wahoo elment to the firmware above.
    ELEMNT WF42-1422, has a known bug, were sensors and phnoe connection will drop if you are going into a strava live segment.
    In a few weeks there going to be releasing a firmware fix.
    If you have already upgraed to the the above firmware, un check your live segments now, to avoid loosing ride data and/or sensor data.
    Oct 2014
    Thanks for the info.
    I've been on the new firmware since it came out and haven't experienced this issue. I rarely use live segments though, so that may be why.
    Oct 2014
    Yeah this bug affects you if you have a live segment checked. So just keep them unchecked there will be a new firmware in 2 weeks.
    Crank Addict
    Mar 2014
    Is this only for the Elemnt or the Bolt as well?
    I have the latest firmware on the Bolt and have been running live track, hit segments on Wednesday and Sunday with no issues.
    ___________________________
    2016 Pactimo Brand Ambassador
    www.Crankaddicts.cc
    www.skratchlabs.com
    www.hilltopbicycles.com
    2017 S-Works Tarmac SL5
    2015 S-Works DSW Allez
    2014 S-Works Shiv TT
    2015 Specialized Fuse Comp
    Oct 2014
    Quote Originally Posted by TricrossRich View Post
    Bolt is unaffected.
    it is the big version.
  1. Wahoo ELEMNT
    By Wetworks in forum General Cycling Discussion
    Last Post: 12-15-2017, 06:19 AM
  2. Replies: 8
    Last Post: 06-12-2017, 03:31 AM
  3. Can Garmin speed and cadence sensors be used with the Wahoo Elemnt?
    By ToiletSiphon in forum General Cycling Discussion
    Last Post: 01-14-2017, 06:28 PM
  4. Ant+ and Bluetooth combo computers, P.Meters and sensors problems.
    By Kendogz161 in forum Components, Wrenching
    Last Post: 12-19-2015, 02:51 PM
  5. Upgraded my router firmware- have you? New TV too
    By Coolhand in forum The Lounge
    Last Post: 05-19-2008, 06:09 PM
