What a difference 3/4 of an inch makes!!
Results 1 to 25 of 39
    Jul 2013
    Iíve been on my Litespeed for over a year now. Three to four times a week. Minimum ten miles each ride (after work), averaging fifteen to twenty miles. Iíve spent a lot of time riding this bike, and the Ridley Noah before it. The Ridley has a seat mast that had to be cut, and a seat clamp that offered little by way of adjustment.
    Two days ago I went on a ride and noticed for the first time that my knees were going outward ever so slightly on the upstroke. Yesterday, before riding out, I raised the saddle by roughly 3/4 of an inch, and boy.... what a difference did it make in every aspect of the ride. It never occurred to me after this much time that my saddle was too low. Mate it wasnít even too low, per se. But I raised it anyway. And it was a fairly small change in saddle height, but the difference in ride and my performance was profound. I rode markedly faster in climbs and on level road. And, as you can imagine, my upper body was positioned better.
    So, check your saddle heights, boys. I cannot believe such a small change could make such a big difference.
    'brifter' is f'ing stupid
    3/4" is not small, that's HUGE.
    #promechaniclife
    Oct 2013
    You still may be way off!
    When riding, take your foot out of the pedal, put your heel on the pedal and soft pedal, when your leg is just slightly bent at the bottom of the stroke, you are getting really close.
    BANNED
    Proud luddite
    Reputation: azpeterb's Avatar
    Jun 2006
    Thatís what she said.
    What the what???
    Jul 2009
    Living in the Midwest, Iíve learned to drop my saddle a bit in the fall before putting my bike away for the winter. After a few rides in the spring I can slowly raise it back up a bit. I wrap a bit of electrical tape around the seat post to maintain a reference point.
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Reputation: Fredrico's Avatar
    Jun 2002
    Yep.
    Meaning, put heel on the pedal straight legged, then notice when pedaling on the balls of the feet, a slight bend in the leg at the bottom of the stroke? The fit kit prescribed 75 degrees.
    Congratulations, Waspinator. Very possible your seat was 3/4" too low. Seat posts frequently slip down in the seat tube over a season or two, so slowly, rider doesn't even notice. Racers check them all the time.
    Just be nice to the knees working in their glorious freedom!
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by Fredrico View Post
    Yep.
    This is why I keep a wrap of tape on my seat post, when I see it starting to bunch up I raise the post that little bit to smooth the tape back. The tape makes a good visual reference.
    Too old to ride plastic
    Oct 2013
    ...she said "let me have that thing". .....
    BANNED
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Let's also remember than different shoes have different sole thicknesses. I found that the optimal seatpost position is 1/4 inch different between summer and winter shoes. And believe me, I can feel 1/4 inch difference. As CX said, 3/4 inch is huge.
    I have two fairly unobtrusive markings I made on my seatpost with a knife.
    "With
    -- DCGriz, RBR.
    Jul 2013
    Yep.
    I have to confess... I had no idea that happened - ie seatposts slipping down. I always tighten my clamp thoroughly. Thatís good to know.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Waspinator View Post
    Some carbon frames are known to be prone to seatpost slipping. Carbon paste helps stop that.
    "With
    -- DCGriz, RBR.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Yep. Winter garb, specifically tights and winter shoes, have me lowering my saddle just a bit come cold weather.
    Donald Trump has never had a wife he didn't cheat on.
    There are over 6.2 million covid cases in the United States (as of September 6th), eight months after Donald Trump said it was "totally under control," and that "it's gonna be just fine."
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by xxl View Post
    Really? I find I have to raise the saddle with winter shoes since the soles are thicker.
    The extra layer of tights is insignificant.
    "With
    -- DCGriz, RBR.
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    I fine tuned my seat height, horizontal adjustment, and cleat position -- millimetres at a time -- to rid myself of a chronic left knee ITBS problem.
    If I moved the seatpost 3/4 now, I'd probably end up needing a cane to walk.
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Insignificant? Remember, we're talking a situation where a fraction of an inch is "huge."
    I agree, tights aren't that much of a change, but I notice...and once I do, well....
    Banned Sock Puppet
    May 2014
    Interesting. I don't notice anything with tights. Shoes, definitely.
    "With
    -- DCGriz, RBR.
    Sep 2007
    Are you two talking padded tights or non padded worn over padded shorts? One makes a difference, the other, not so much.
    Banned Sock Puppet
    May 2014
    I wear non-padded tights over padded shorts. I wouldn't think either would make much difference.
    "With
    -- DCGriz, RBR.
    Mar 2019
    The Lombard Fit Method for seat height is to make it even with the bars.
    And I hope your seat post is carbon with your knife marks. Great advice again.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by rudge66 View Post
    My seatpost is alloy. No, I would not recommend doing this with a carbon seatpost. That would be almost as stupid as your posts.
    "With
    -- DCGriz, RBR.
    You should find another forum to troll, really. Your crap is not even fun, it's just tiring.
    #promechaniclife
    Feb 2002
    I think it was a 3 mm change to Bernard Hinault's seat height that resulted in knee surgery for him.
    Banned Sock Puppet
    May 2014
    3mm is about one tenth of an inch. I can definitely feel one quarter of an inch. One tenth could conceivably make a difference.
    "With
    -- DCGriz, RBR.
    Mar 2019
    The Prairie Dog Method:
    I have my road bikes adjusted so the bars and saddle are pretty much level with each other. ...it's an easy enough fix to flip the stem and tilt the bars up a little.
    Sorry, but he (Lombard) is not properly fit to a road bike and unable to evaluate its potential. This would be immediately apparent on a group ride... before we even leave the parking lot.
    Banned Sock Puppet
    May 2014
    You might be surprised when I pass you up that 15% grade.
    "With
    -- DCGriz, RBR.
  1. 20 inch (451) v. 20 inch (406)
    By fredstaple in forum General Cycling Discussion
    Last Post: 06-07-2011, 05:00 PM
  2. Is a half inch going to make a difference
    By Banky in forum General Cycling Discussion
    Last Post: 09-08-2010, 08:41 AM
  3. Rollers 3 inch vs. 4.5 inch drums
    By cdadaa in forum General Cycling Discussion
    Last Post: 10-14-2007, 06:20 PM
  4. Gear inch = gear inch
    By iks in forum General Cycling Discussion
    Last Post: 08-22-2006, 11:51 AM
  5. 1 inch vs. 1 1/8 inch
    By MrShadowWalker in forum General Cycling Discussion
    Last Post: 10-11-2005, 07:22 AM
