What is the point of the tapered steerer?
Results 1 to 25 of 25
    Bike Wing Conspiracy
    Reputation: onespeed's Avatar
    Mar 2002
    Starting to collect the items to build up the frame I got on Ebay.
    Do I need to pair a tapered steerer with a specific stem or bars?
    Why are they making tapered steerers?
    I dont get it.
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    Quote Originally Posted by onespeed View Post
    Yes: the size of stem that fits the steerer. Bars will need to fit the other end of the stem.
    In order to sell more bicycles.
    * not actually a Rock Star
    DL1
    DL1 is offline
    Apr 2007
    Not sure what you mean exactly by tapered steerer, but parts are often tapered when the forces to which they are subjected are higher at one end than the other. This is the case in particular when a part that is fixed at one end is subjected to bending loads.
    Reputation: TWB8s's Avatar
    Sep 2003
    More info please. What is the frame and fork?
    Banned forever.....or not
    Aug 2002
    Isn't "New and improved" always better than "old"?????
    Dogbert.
    I>U
    Mar 2002
    Check out this auction - tapered steerer
    Quote Originally Posted by DL1 View Post
    Orbea Carbon Road Bike Fork Tapered Steerer 1.5 1-1/8" 39.8mm rake | eBay
    Reputation: minutemaidman's Avatar
    Jun 2010
    I dont get it.
    Tapered steerers make the front end stiffer.
    A while back I decided to ride a bike as often as possible. These are my observations from the saddle, one pedal stroke at a time, on my way to being a better cyclist.
    Reputation: JCavilia's Avatar
    Sep 2005
    The point is to have a bigger bearing at the bottom where the load is bigger. Whether that's necessary or useful is another question.
    Does your frame have the tapered headtube that's made for this fork? They need to match.
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    Quote Originally Posted by minutemaidman View Post
    ^^^^This is not just hypothetical, it really does make for a stiffer front end. I think you'll like it. I've put ~1000 miles on a new frame that has a 1.125x1.5 tapered steered and the handling is sweet.
    warrrrrrrgh!!!
    Reputation: foto's Avatar
    Feb 2005
    I have that same orbea fork on my BMX bike. The front end doesn't feel that much stiffer.
    warrrrrrrgh!!!
    Feb 2005
    Is this the frame? That CSK you posted earlier? Are you sure you know what you are doing?
    FixedGearFever - CSK Track Frameset Warehouse Clearance Sale!
    Dec 2006
    I feel the real reason they came about was to solve the problem of brake squeal with cantilever brakes on carbon forks. Carbon forks were just not rigid enough to resist the flex from cantilevers and the physical limitations of the standard 1 1/8" carbon fork crown were a contributor.
    Otherwise, I never heard anyone complain that 1 1/8" carbon forks weren't stiff enough, until the marketing people told them so...
    Reputation: rbart4506's Avatar
    Aug 2004
    Quote Originally Posted by Clipped_in View Post
    I will agree...
    Have a 2008 Tarmac Expert (standard carbon steerer) and a 2010 Tarmac Expert (tapered carbon steerer). The 2010 Tarmac tracks so much straight when sprinting. The bike just goes straight no matter how much I flail away when sprinting...
    I noticed this the first time out on the bike and everytime when I switch between the two...
    BTW I'm using the same powertap wheelset, so that isn't the reason...
    warrrrrrrgh!!!
    Feb 2005
    I love it.
    This is like asking if I should buy a BB30 crankset for "my frame" without saying which frame, and everyone saying "yeah get it"!
    That should work real well on my old fuji...
    warrrrrrrgh!!!
    Feb 2005
    Or if I should get a smaller helmet to save weight.
    warrrrrrrgh!!!
    Feb 2005
    Or if a 30.2 diameter seatpost would be a good choice for me.
    Jan 2010
    Quote Originally Posted by foto View Post
    I love it.
    I'm with foto on this one............are you sure you should be doing this?
    There's sometimes a buggy.
    One.
    Reputation: Rogus's Avatar
    Nov 2010
    Quote Originally Posted by TWB8s View Post
    The frame is the main part of the bike. Everything else attaches to it.
    The fork is what the front wheel is attached to.
    Hope this helps.
    Jan 2010
    Quote Originally Posted by Rogus View Post
    Hope this helps.
    I can see this getting quite interesting.
    One.
    warrrrrrrgh!!!
    Feb 2005
    Hope this helps.
    but is it stiff?
    Nov 2009
    it would be. those are the lightest. also the stiffest, yet vertically compliant... or is it laterally compliant? uhhh
    Sep 2003
    Hope this helps.
    I was going to say something witty but why should I force politeness?
    Eat a dick.
    Sep 2003
    It mean it takes a 1 1/8" bearing on top and a 1.5 (1 1/2") bearing on the lower. The steer tube is tapered to fit those sizes. The head tube will match accordingly.
    waterproof*
    Sep 2003
    there's nothing wrong with square taper.
    Oct 2009
    The point of the tapered steerer is usually about 900mm above the stem.
  1. on tapered steerers
    By kingennio in forum Bikes, Frames and Forks
    Last Post: 08-03-2010, 01:36 AM
  2. aftermarket tapered forks
    By j-man in forum General Cycling Discussion
    Last Post: 01-24-2010, 08:59 PM
  3. Tapered CX forks/headtubes?
    By TedH in forum Cyclocross
    Last Post: 05-20-2009, 08:17 AM
  4. Campag tapered BB question
    By kiwi_1234 in forum Components, Wrenching
    Last Post: 03-01-2009, 09:32 AM
  5. Carbon steerer vs chromoly steerer
    By skyline377 in forum Components, Wrenching
    Last Post: 01-24-2005, 10:59 AM
