Why CO2? - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 85
Thread: Why CO2?
  1. #51
    Jan 2008
    Quote Originally Posted by brianmcg View Post
    The purpose of a CO2 cartridge is to get you home. When you get home you should let out the CO2 and fill with regular air from a proper floor pump.
    Right, I'm trying to avoid that.
    Anyways, our resident physical chemist is right, even if he did an awful job of explaining it to me.
    I did the calcs, and found that there's roughly .280 mols of gas in a regular road bike tire, and roughly .36 mols of co2 in a co2 cartridge.
    To put .36 mols of n2 in a co2 cartridge, I'd need to compress it at 89,629psi.
    Which probably isn't going to happen.
    I prefer to not think about this as losing an argument, rather, I prefer to think that the laws of physics and chemistry won.
  2. #52
    Quote Originally Posted by msrothwe View Post
    You fought the law and the law won
  3. #53
    Jul 2013
    Gee, thanks.
    The key point is that you can liquify CO2 under conditions that allow you to carry it in a canister in your bike bag. You can't do that with N2, so you can't store anywhere close to the number of molecules of gas you need to inflate a tire.
    (Is that better?)
    Quote Originally Posted by DaveG View Post
    Nah. He just tried to apply the law outside its jurisdiction.
    (The ideal gas law breaks down when the gas becomes a liquid -- which an "ideal gas" never does, by definition.)
  4. #54
    Jan 2008
    Quote Originally Posted by wgscott View Post
    Gee, thanks.
    (Is that better?)
    Gah, I meant to put a after my statement, not sure why it didn't work on tapatalk.
    But yes, your second explanation was much better. I failed to grasp the difference in density between a really pressurized but not quite liquid gas and a full-bore liquid co2.
    Right. Another thing that I messed up is that N2's critical point is far below CO2's, so it will want to be a gas at just about all pressures at a reasonable temperature.
  5. #55
    Reputation: ogre's Avatar
    Dec 2005
    You would also need to find green presta valve caps to let everyone know you're riding with nitrogen.
  6. #56
    Jun 2010
    Quote Originally Posted by ogre View Post
    who uses valve caps
  7. #57
    Reputation: Oxtox's Avatar
    Aug 2006
    nitrogen cylinders are typically color coded black, green is for oxygen...
  8. #58
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    Gee, thanks.
    (Is that better?)
    more of a demonstration of the difference between basic science and applied science. The basic scientist has to know how any why things act as they do in minute detail. The engineer just has to read the chart made by the basic scientist for him to make do
    not everyday do I run into a physchem doctor, though I am married to one
  9. #59
    Jul 2013
    Well, I never knew Carbon dioxide leaked out of tubes until confronted with the experimental evidence.
    You have my deepest sympathies, although I married someone who works with live HIV.
  10. #60
    Apr 2012
    Quote Originally Posted by BCSaltchucker View Post
    Which, I suppose is why ideal gases exist only in textbooks.
    scott s.
  11. #61
    Jul 2013
    Most gases have near-ideal behavior, as long as you don't get too close to liquification temperature or pressure.
  12. #62
    Feb 2002
    It's the Joule-Thompson effect. If would get cold even with a compressed gas (think of those compressed air canisters you get to blow dust out of electronics).
    The adiabatic expansion of a gas causes cooling as you have stated, but the latent heat of vaporization is a much bigger number in the total amount of temperature drop when you discharge a CO2 cartridge.
  13. #63
    Jul 2013
    You are right. I thought the JT effect would dominate.
  14. #64
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Propane would be the way to go... You could probably fill up five tires with a CO2 sized cartridge. Plus you could shoot flames out of your valves if necessary to scare off dogs, small children, the wife...
    Sent from my Nexus 6P using Tapatalk
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
  15. #65
    Feb 2002
    And one more thing: the gas is expanding AFTER it passes through the let-down valve after the outlet of the cartridge - all that cooling takes place in the CO2 device and the inner tube, not in the cart. The ONLY cooling that takes place in the cart is due to the boiling of the liquid CO2.
  16. #66
    Oct 2002
    Exactly what gives you the idea that CO2 would leak out faster than N? CO2 is a larger molecule that requires a larger pore to travel through.
  17. #67
    Reputation: Fireform's Avatar
    Dec 2005
    Why CO2?
    Quote Originally Posted by Tom Kunich View Post
    Actually this is not true. A carbon dioxide molecule is about 116 pico meters, whereas nitrogen is about 300. Which is why bike tires go flat faster when they're inflated with carbon dioxide.
    Arguments among misinformed people do not constitute a "debate."
    --Kerry Irons
    "Atheism is a religion like not collecting stamps is a hobby."
    --BianchiJoe
    Cervelo S3/Dura Ace
    Felt B2Pro/SRAM
    Cannondale CAAD10/105
  18. #68
    a real member's member
    Jul 2016
    Quote Originally Posted by Fireform View Post
    is this the main reason we should remove the co2 from the tube/tire after returning home and inflate with a floor pump?
  19. #69
    Dec 2005
    Quote Originally Posted by blackfrancois View Post
    Yes.
    --Kerry Irons
    --BianchiJoe
    Cervelo S3/Dura Ace
    Felt B2Pro/SRAM
  20. #70
    Oct 2002
    From memory a Nitrogen molecule (N2) is something like 300 picometers and a CO2 molecule is 330.
    I was sort of hoping that a materials scientist would chip in with the reason that CO2 leaves a tube somewhat faster than air (which is mostly nitrogen). I am not a chemist but an engineer.
    But CO2 doesn't "leak" out - it defuses through the butyl or latex rubber. This has to do with the make up of the material and not the size of the molecules themselves.
  21. #71
    Dec 2005
    I was going from memory too, but I was closer to right. CO2 is 232 pm, N2 is 330.
    http://physics.stackexchange.com/que...carbon-dioxide
    --Kerry Irons
    --BianchiJoe
    Cervelo S3/Dura Ace
    Felt B2Pro/SRAM
  22. #72
    δanned
    Reputation: SauronHimself's Avatar
    Nov 2012
    Physics background myself. While N2 is indeed 300 pm, a CO2 molecule is 232 pm. The C=O bond is 116 pm.
    Ghurarmu shirkush’ agh azgushu. Zant ya apakurizak. Gűl-n’ anakhizak.
  23. #73
    Dec 2005
    Quote Originally Posted by SauronHimself View Post
    Yeah, but the difference in HTFU/WTF coefficients is negligible.
  24. #74
    Oct 2002
    And we still do not have any good explanation of why CO2 defuses through hydrocarbon compounds faster than N2.
    We also do not have an explanation of the driving force or energy source of this diffusion.
    In any case the size of the molecule does NOT matter.
  25. #75
    Dec 2005
    Why CO2?
    Gas molecules do migrate through holes in the polymer. Allow me to direct you to a published article: https://imageserv5.team-logic.com/me..._20et_20al.pdf
    One salient quote:
    "The types of gas affect both solubility and diffusivity of the gas. Diffusivity greatly depends on
    the size of the gas molecule. The smaller the size of the gas molecule, the faster the diffusivity."
    --Kerry Irons
    --BianchiJoe
    Cervelo S3/Dura Ace
    Felt B2Pro/SRAM
