Winter cycling types, please weigh in...
Results 1 to 25 of 47
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    A fixed-gear studded-tire bike for riding on snowy bike paths--yes or no?
    (Note: I would've posted this in the Fixed Gear sub, but I wanted an answer.)
    Donald Trump has never had a wife he didn't cheat on.
    There are over 8 million covid cases in the United States (as of October 15th), nine months after Donald Trump said it was "totally under control," and that "it's gonna be just fine."
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    I wouldn't do fixed. Studded tires are much harder going than anything else.
    If the snow isn't hard packed you'd probably be OK with knobbies. Studs aren't cheap, and do their best at low pressures on icey surfaces...but BEWARE traction sand on roads, it fouls studs and can make them useless.
    "We are doomed to live in very interesting times"
    Reputation: davesupra's Avatar
    Jun 2017
    I commute daily in the winter. Depending on how much snow you get (and how wet the snow is) and your gearing, a fixed gear bike might be very hard going. I'd run gears (and I do).
    Joe Biden: a case study in plastic surgery disasters.
    Liars often accuse you of lying. - Steve Maraboli
    xxl
    xxl is offline
    Moderator
    Mar 2002
    I already have the studded tires (you know how it is, you buy some bike toy, and then figure out how you'll use it). I'm wondering more about the "fixed" part of things, specifically handling and traction. I've dealt with studded tires enough to know that I'll not be setting any speed records, which is fine; I figure I'll only be doing short rides in cold temps (for me, that's the high 20s). I've ridden fixed-gear, but never off dry pavement. As I mentioned, it'd be used almost exclusively on a bike path that sees little winter travel (so it's often a surface that offers combinations of pavement, snow, and ice in the winter), so gears are simply an unnecessary complication.
    After a casual search of the internet, I've found a number of folks who swear by fixed-gears in winter, e.g., https://gearjunkie.com/fixed-gear-winter-bike
    Russian Troll Farmer
    Sep 2016
    I'd build it with a flip-flop hub. I did that years ago on my first fixie, and ended up preferring the freewheel side.
    "L'enfer, c'est les autres"
    xxl
    xxl is offline
    Moderator
    Mar 2002
    That's what I'm thinking, too (my current fixie has flip-flopability, but 27" wheels, so no studded tires for it!)
    Oct 2013
    The studs are only good on ice, all other applications they are not so good.
    IMO, riding on anything that has ice is CRAZY! ...even with studs unless your ice racing.
    BANNED
    Dec 2006
    Quote Originally Posted by davesupra View Post
    THIS. Nothing to add because it's all here.
    pmf
    pmf is offline
    Quote Originally Posted by xxl View Post
    How are you planning to keep your @ss crack warm? That would be a big issue with the hipsters I see in and around DC who commute 3 miles to work on their single speeds (which differs from fixed gear).
    Feb 2002
    If there is going to be any snow accumulation to deal with, you might really want some gears. Riding in actual snow is similar to, though not as hard as riding in sand. When the front wheel digs in and the back is sliding around, fixed gear would not be my choice. Also, the best tactic to deal with ice is a light hand on the bars and coast through it. A lot more of a challenge on a fixed gear. But if you're out to prove something to yourself (or others), have at it.
    gazing from the shadows
    Jan 2003
    Yes, if you post pics of your injuries after they happen.
    Reputation: ogre's Avatar
    Dec 2005
    I think itís time to enact n+1 and get a fat tire bike
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Quote Originally Posted by pmf View Post
    I plan to wear my winter cycling duds.
    xxl
    xxl is offline
    Moderator
    Mar 2002
    There's not going to be much in the way of accumulation, as we don't get that much snowfall (and if there is, I'll not be out in it), but there'll be patches of snow, mixed in with icy parts, often rutted up from previous riders (these are actually the worst hazards, IME). I've ridden it before, but on regular knobbies, and it was doable, but I had to pay attention.
    I'm not sure how often the front wheel would dig in and not the back (but better that than the other way around), since both F and R would be studded tires and the rear is usually loaded more. Some people even try to cheap out with only a studded tire upfront, but this seems foolhardy to me. Some winter biking folks online have advocated the fixed gear as better for these situations (obviously, I have no direct experience, or this thread wouldn't exist ), as they say one can slow the bike by "engine braking," i.e., backing off pedaling.
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Quote Originally Posted by ogre View Post
    In truth, as much as another bike appeals to me, with the snowfall around here I'd probably not be able to drag it out all that much.
    pmf
    pmf is offline
    Bingo!
    Three years ago there was a big snow storm headed for the DC area. I bought a huge snow blower at Home Depot the week before. The storm came and blower worked great -- I even did the neighbor's drive ways. I haven't used it since. Best purchase I ever made. I rode 400 miles last January.
    Get the fat tire bike.
    KWL
    KWL is offline
    Reputation: KWL's Avatar
    Jan 2005
    ...Get the fat tire bike.
    The nice thing about a fat bike is you can ride the snow & ice or single track or sand. I am having fun cruising the gravel alleys in my 1920's neighborhood. Throw some studs on it and it is perfect for rutted, iced up MUTS. Another vote for n+1.
    Ken
    P.J. O'Rourke: The Internet - whose idea was it to put all the idiots on earth in touch with each other?
    Sep 2011
    fixie in snow and studded tires?
    Wow here I am thinking I need to HTFU during the Socal winter when temps can drop into low 50s high 40s.
    Oct 2013
    OMG, that's freez'in!!! NoWay!
    If it's really patchy this and that, I would go fat tire for sure!
    BANNED
    Dec 2005
    https://media.giphy.com/media/slbQo8QFOUi1W/giphy.gif
    For God's sake man! Get a new bike!
    Reputation: SantaCruz's Avatar
    Mar 2002
    No answer on the fixed studded winter bike.
    But I think it mildly amusing a Moderator has to justify posting in the wrong(?) Forum to get replies.
    Carry on.
    Lots of bikes - vintage steel w/ friction thru modern Ti and CF w/ brifters.
    Oct 2013
    Yea, where is CX? Hump!
    BANNED
    Feb 2002
    It doesn't seem like you've ridden in snow much. Studs won't keep the front wheel from digging in to partially packed snow. I commuted year round for 30 years in Michigan and experienced this all the time.
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Perhaps to you it seems that way, but growing up in the Snow Belt, I've ridden in plenty of snow.
    What I haven't done is ride a fixed gear bicycle with studded tires in snow.
    I'm not sure what you're getting at regarding the traction of the front wheel; my experience (though not with studded tires on a fixed-gear bike, as I said) has been that if the front wheel is maintaining traction, rear-wheel skittishness is something I can handle (particularly at the lower speeds of winter biking). I'd much prefer that problem over having a front wheel that slides around.
    As I said, a number of winter cycling enthusiasts advocate fixed-gear bikes for winter (cf. https://www.sheldonbrown.com/winter.html).
    See also:
    Jan 2003
    As I said, a number of winter cycling enthusiasts advocate fixed-gear bikes for winter ...
    See also:
    If you rode across Canada, you are good to go for your commute.
    You are what matters, not others.
    Key word in ice and snow: gentle. Gentle movements, gentle accelerations. Can you do that on a fixed? From a dead stop and fully loaded? When a car or truck sheds a fenderberg in front of you (when you are not on the path)? Can you bunny hop on a fixed? Do you have the skills to not coast at all on a winter ride? Even when a huge pothole or other obstacle is suddenly in front of you that you could not see earlier because of snowfall/snowcover?
    Single speed, sure. Simple is good in the snow. But why do you want to go fixed? Do you need extra hipster points for a coffee discount?
  1. Replies: 42
    Last Post: 03-20-2009, 10:24 AM
  2. Campy fans, please weigh in.
    By weather in forum General Cycling Discussion
    Last Post: 06-29-2006, 02:07 PM
  3. Legal eagles weigh in please
    By Live Steam in forum Politics Only
    Last Post: 02-27-2006, 10:24 AM
