Wrist Pain
Results 1 to 9 of 9
Thread: Wrist Pain
    Jun 2005
    Wrist Pain
    Over the past few weeks, Iíve been getting wrist pain during and after long rides. Specifically, it is tendonitis, between my wrist and forearm, on the outside of my wrist, the ulnar side, from the bony knob on my ulna to about two inches above my forearm.
    I recently built up a new bike, and I matched the measurements to my other bike: saddle height, fore aft, stem height. However, the new bike has zipp 70 handlebars, which have a 70 mm reach. My other bike has specialized tarmac handlebars which have an 85 mm reach. With the shorter reach, I can reach the hoods and shift is more easily, but Iím wondering if this is causing extra strain on my wrist.
    Iím attaching pictures of the bars. Let me know if they are set up wrong. The black ones on the new bars, the white ones are the old ones.
    Reputation: nova_rider's Avatar
    Sep 2005
    Any difference in stem length between the two? Holding everything else the same, shorter reach will put your wrist at a more acute angle, and that can cause problems.
    Jun 2005
    The stem is the same length, but the new one is 8deg and the old one is 6 deg. I put an extra 5mm spacer below the stem to compensate.
    Quote Originally Posted by TiCoyote View Post
    You didn't matched the measurements if you changed the reach to the shifters.
    Sep 2005
    Reach difference alone between old and new is 15mm, enough to make a noticeable difference on your wrist and shoulders. You can perhaps play with your saddle adjustments as long as it doesn't mess up your knee position. If that doesn't work, you might be looking at a longer stem.
    Reputation: Srode's Avatar
    Aug 2012
    Looks like the heal of your hand is on the bars solidly on the old set up and not so much on the new one. What I am seeing looks like a pretty significant difference between the two set ups.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Reputation: PBL450's Avatar
    Apr 2014
    This. If you want to make adjustments to your previous geo thatís cool, but do it after a ton of miles on as close to a replicated geo as possible on the new bike with all systems working fine. Very small differences effect me a very lot. Maybe Iím uniquely sensitive.
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    Never Give Up!
    Mar 2009
    What I am seeing looks like a pretty significant difference between the two set ups. The old bars with the white tape appear to be rotated downward a bit more than the bars with the black tape and the reach to the shifters look to be in different locations... therefore putting your hands/wrist in two different positions
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Oct 2017
    Your hoods are rolled down further on the bike with the white bar tape. On the other bike they are nearly flat at the same angle as the stem.
    This will change your wrist angle significantly.
  1. Handlebar suggestions - Wrist pain
    By tribune in forum Cyclocross
    Last Post: 01-31-2009, 09:27 PM
  2. Left Wrist Pain
    By Kennedy in forum General Cycling Discussion
    Last Post: 05-17-2006, 10:06 AM
  3. Wrist pain...
    By rbart4506 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-18-2005, 04:13 PM
  4. Wrist pain HELP!!!
    By freezin_is_the_reason in forum General Cycling Discussion
    Last Post: 10-27-2004, 04:39 PM
  5. wrist pain... early carpal tunnel?
    By xcroadie in forum General Cycling Discussion
    Last Post: 06-11-2004, 06:04 PM
