Zwift with no wi fi
Results 1 to 11 of 11
    Mar 2012
    Zwift with no wi fi
    Does anyone know if you can run Zwift with just mobile data?
    I have a 7S I phone and a I pad with unlimited data- AT&T
    Any help much appreciated....
    Jun 2013
    You should, but it depends on your concerns. If you are worried about data, with 3k users on, using a 2016 Kickr w/ power streaming "instant", a cadence monitor, but no heart rate, data was streaming between 250Kbps and 350Kbps at the start. On the mountain, with only 0-3 users visible, it was between 100Kbps and 250Kbps. I sent 16MB and received 36MB after 30 minutes.
    That said, if you contact zwift developers on their support site, they should be able to answer all your questions.
    Oct 2002
    Yeah Zwift are really good with the support. How is your typical data rate and is it constant?
    Oct 2017
    Bandwidth is only part of the equation. Latency is going to be the issue. Whether or not it's a usable connection is going to depend on the quality of the connection you have with your provider at your given location, and your tolerance for the quality you get as a result.
    Can it be done? Probably.
    Will it be usable? That's a more complicated question (and answer).
    Mar 2012
    Both products get throttled down after 22GB,and I have limited hot spot use.
    Reputation: Srode's Avatar
    Aug 2012
    Guessing your video card might be a bottle neck too, if it's compatible with Zwift. The first laptop I tried to use with Zwift wouldn't work because of the video processing limit on it.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Mar 2012
    Upload 13.2 download 10.2 latency 67
    Oct 2002
    Quote Originally Posted by gabkr View Post
    might be better to get wifi. less stress.
    Jun 2013
    Zwift runs on iphone/ipad...pc/mac not required.
    Jun 2013
    Is that the latency from your device to the zwift servers? If it's the latency to a speed test site, it wouldn't be relevant. However anything under 250ms should provide a relatively smooth experience.
    Mar 2012
    Latency
    Quote Originally Posted by colnagoG60 View Post
    It is from a test site.
  1. Love the new "hill" on Zwift.
    By bmach in forum General Cycling Discussion
    Last Post: 03-22-2016, 04:41 PM
  2. Replies: 6
    Last Post: 02-25-2016, 05:41 AM
  3. Zwift question
    Last Post: 02-18-2016, 01:25 PM
  4. Zwift racing and or group rides - It has gotten bigger and better
    By pittcanna in forum General Cycling Discussion
    Last Post: 02-18-2016, 06:37 AM
  5. Zwift and trainer difficulty setting
    By sasquatch16 in forum General Cycling Discussion
    Last Post: 02-16-2016, 02:57 AM
