giant tcr comp seatpost adjustments?
Results 1 to 3 of 3
    gastarbeiter
    Reputation: botto's Avatar
    howdy all
    have a stupid question for you.
    i want to swap a Flite for the stock Aliante that came with my tcrc0, but the clamp is stuck pretty tight, so i can't tilt the nut. i got the bike in january, and i recall the fitter using a rubber mallet to loosen the post bolt on the bike i was fitted on (same bike but they swapped saddles/post due to color).
    my question - how does one go about using a rubber mallet on a carbon post without damaging it to loosen the clamp?
    tia
    Jan 2006
    I just tapped mine from below using the handle-end of a mini-sledge...
    On a related note, I cna't seem to get the seat exactly level -- either the tip is slightly up or slightly down. A little down is hard on my shoulders/back and a little up can be rough on the nads on long climbs... Any solution to this besides swapping the post?
    Quote Originally Posted by botto
    howdy all
    tia
    Dec 2005
    I had a similar problem on my TCRc1. I ended up using a 6mm hex (at least I think it was a 6) with a pretty long handle - gave me plenty of leverage to loosen it.
