OverDrive vs. OD2
Results 1 to 4 of 4
    Jun 2005
    OverDrive vs. OD2
    Has anyone ridden the TCR Advanced and the Advanced Pro side by side? I understand that they have the same frame, but different wheels and fork. Or specifically, steerer tube. The Advanced has the aluminum OverDrive 1.25-1.125 tapered, whereas the Pro has the carbon OverDrive 2 1.5-1.25 tapered steerer.
    Some say this is an annoyance because it's too hard to find a stem. Giant claims that it offers a 30% improvement in torsional stiffness which leads to more precise steering.
    I can't seem to find any reviews that actually compare both. I guess one issue is that the bikes also have different wheels, which likely has a greater impact than different steerers.
    Aug 2017
    The stem situation is actually not that bad. Apart from Giant, Canyon, Syncros and Ritchey (I think) also make 1.25" stems.
    I haven't compared the steerers, I just went with the nicest bike that fit my budget (Adv Pro 1 Disc).
    Aug 2017
    Forgot to mention that the Specialized Multi Stem (or however it's called) also works. It's essentially a 31.8 mm steerer tube stem (1&1/4") that comes with angled 1&1/8" spacers/sleeves for the steerer clamp area to fine-tune the angle. In the base setting without sleeves it's a 24 stem however, so quite the extreme position. But if anyone's looking for a super-aggressive stem for their Giant road bike, it's a great option.
    Oct 2017
    Quote Originally Posted by TiCoyote View Post
    I have a Canyon with a 1 1/4" steerer. I found quite a few options when shopping around. As mentioned above, Ritchey, Giant, Canyon, Syncros... also Zipp and FSA. I chose the Ritchey for the aesthetics. They are pricey, but very stiff and light.
    https://us.ritcheylogic.com/us_en/su...-c260-84d-stem
    If you are ok with Alloy, I think the Canyon stem was the most inexpensive, although you need to order the face plate separately if I recall....
  1. New Helmet: Gage or Overdrive?
    By TiCoyote in forum Apparel and Cycling clothes
    Last Post: 06-05-2017, 08:19 AM
  2. Cane Creek for Giant Overdrive
    By arinowner in forum Components, Wrenching
    Last Post: 11-07-2015, 05:49 AM
  3. Headset Reducers or others? Or Overdrive size forks?
    By Kinetic-UK in forum Bikes, Frames and Forks
    Last Post: 05-27-2012, 02:26 PM
  4. OD2 stem alternatives?
    By BikeArmsRace in forum Giant
    Last Post: 12-18-2011, 04:31 AM
  5. Replies: 24
    Last Post: 02-07-2009, 01:05 AM
