Power Pro Power Meter Problems
Results 1 to 8 of 8
    Lycra doesn't lie
    Reputation: Joe Steel's Avatar
    May 2008
    Hoping for some helpful suggestions...
    Recently purchased the 2019 TCR Advanced Pro Disc..
    https://www.giant-bicycles.com/us/tc...ced-pro-0-disc
    It's a beautiful bike and I'm really excited about enjoying it ... but I'm not able to get the built-in Power Pro power meter to function properly. The crankset was replaced by the LBS, but continues to read incorrectly. I'm seeing readings about 10x what I would expect -- and the data is consistent between my Garmin 810 and the Giant app. There was also a questionable significant difference measured between the right and left crank arm (83% right side, 17% left side).
    I've fully charged the crankset, followed the calibration process (both via the Giant app, and through the Garmin), and verified the firmware is current. All multiple times with no change.
    I've scoured the internet and I'm not finding anything related to this problem.
    Is there a pairing process or something not documented in the user manual that may have been missed?
    Thanks for any helpful suggestions.
    Jan 2019
    Nice bike you've got there!
    I just ordered a new Giant Defy Adv. Pro 0, which has the same Power Meter. It's going to be my first PM!
    I have two friends who just bought identical 2019 TCR Advanced SL with the Power Pro PM. Both have exactly the same problems you mention here. The first one started having problems back in December, he took the bike to the dealer here (El Salvador) and Giant replaced the complete crankset with a new PM as guarantee. It was two weeks ago aprox that the new crankset arrived and has had no problems so far.
    My other friend is at the dealership at this moment, he started having the same problems two days ago. He's putting the claim to see what happens.
    Long story short, both of them presented the same problems with the data, but also, when we inspected the cranksets, there's a plastic cover in the packside of the PM unit in the driveside (right side) of the crankset. This plastic cover has two small bolts, and in both cases, this plastic cover was broken. Go and check if yours is cracked also!
    We still don't know what's going to happen, if this is a design problem or if the materials are defective. What is Giant going to do? release a recall? are they going to replace all the defective Power Meters? I understand it's a new product for them, but didn't they made tests? real life tests?
    I'm hopping not to have problems with my Defy when it arrives, but please keep posted here how do you solve your situation!!
    Thanks in advance, Jose!
    Lycra doesn't lie
    May 2008
    Follow up to above:
    Original chrankset/power meter defective. 1st replacement crankset / powermeter defective.. 2nd replacement (or 3rd set, depending on how you look at it), works like it should.
    Phew... glad to have that sorted. I wasn't expecting the replacement set to have the same problem. That sort of threw me... glad that my bike shop and Giant dealt with it fairly quickly.
    Reputation: Ridin'Sorra's Avatar
    Sep 2004
    Mine doesn't want to show power readings on my 520.
    I'm positive must be something blatantly obvious I'm missing as the Garmin can see it and calibrate it but it just shows zero power and cadence.
    The Power Pro must be fine as the RideLink app shows me power, balance, cadence, etc.
    Oh, well... marvels of technology I guess.
    "que nadie se crea que subimos todos estos puertos sólo a base de spaghetti" - Fernando Escartín
    Sep 2004
    Well, it turns out that all it took was to remove other power meters from the 520 and leave only the Power Pro.
    Now it all works and it's sending Left+Right (Balance) power to the 520. So, all good now.
    I still have to compare it to the Wahoo Kickr to see how much they track against each other.
    Jan 2019
    Same case here... replacement CS is having problemas again, going tomorrow to store to place the claim... I’ll keep you posted
    Sep 2019
    Quote Originally Posted by josalpam View Post
    Solucionastéis el problema, josapalm? Tengo el mismo problema, aunque creo que en realidad, el problema viene por el emisor de la biela izquierda, que funciona mal. Un saludo!
    Did you solve this problem, josapalm? I've same problem, although I think that problem comes from the emitter of the left crank, which it's bad working. Greetings!
    [Apologize for mi englush]
    Jan 2019
    Hello! I have a theory, the plastic cover in the back of the Power Pro gets cracked because of the flexion in the two parts that conform the Shimano Crankset which are bonded with an epoxic glue. This crack allows humidity to get in to the sensors and that’s why it starts giving wrong readings. Is my understanding that model year 2020 ha already solved this problem. But until the existences of the 2019 model are gone, we will receive the defective Power Pro replacements.
    Hola! No te preocupes, yo hablo español! tengo una teoría: el crankset Shimano al ser de dos piezas y estar pegadas por un epoxico, tienen una flexión, esto hace que el protector plástico del cableado del cerebro del Power Pro a los sensores en la biela se raje y permita pasar humedad. Y allí se daña! Eso sucede del lado derecho, pero afecta la comunicación entre ambas bielas. Tengo entendido que el modelo 2020 del Power Pro ya solucionó este problema. Pero mientras se terminan las existencias de los Power Pro anteriores eso nos estarán enviando de reemplazo.
  1. Giant Power Pro Power Meter!?!?
    By PoorInRichfield in forum General Cycling Discussion
    Last Post: 09-07-2018, 07:02 PM
  2. To Power Meter or not to Power Meter...
    By OVRLOK in forum General Cycling Discussion
    Last Post: 07-15-2017, 09:40 AM
  3. Train with power meter = race with power meter?
    By obiwan kenobi in forum Racing, Training, Nutrition, Triathlons
    Last Post: 10-06-2010, 01:52 PM
  4. Which Power Meter: Power Tap, SRM, or Ergomo?
    By Speedi Pig in forum Components, Wrenching
    Last Post: 08-27-2009, 09:58 PM
  5. Polar power system vs Ibike power meter.
    By the_rydster in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-19-2006, 07:52 AM
