Can a Specialized Roubaix be turned into a gravel bike?
Results 1 to 6 of 6
    Nov 2011
    Hi all,
    I have a 2013 Specialized Roubaix SL4 that i had used mainly for road however I'm started to see myself doing slightly more unpaved roads/more like gravel than full out mountain bike trails. So is it possible to convert my Roubaix to a gravel bike?
    thanks kindly.
    2013 Specialized Roubaix SL4 Expert Compact
    Sep 2009
    I think the main drawback will be the tire size limitations. A quick search leads me to believe that the largest tire you can fit is a 25mm.
    Nov 2011
    Thank you for responding. Is that because of my forks? If so is it possible to replaced the forks to something that would accommodate larger/wider tires?
    JSR
    JSR is offline
    Feb 2006
    Quote Originally Posted by s-one View Post
    Its the fork as well as the rear stays that are limiting. It may even be the brakes.
    There seems to be consensus that ~40mm is the size of tire you’d want for gravel. You’re not going to get close with that bike. I run 32mm on my Domane. That’s ok for the occasional gravel section, but still a little squirrely.
    Nov 2011
    Ah gotcha ok that's a bummer.
    Oct 2005
    The largest tire I could fit was a 28c schwalbe one tubeless. It would rub and was a struggle clearing the calipers. I think the early disc models (2015) would clear a 32c.
    Sent from my SM-N950U using Tapatalk
  1. Gravel Bike wheel q: Stan's ArchEX on gravel bike
    By stuarttx in forum Gravel Bikes
    Last Post: 03-23-2017, 06:53 PM
  2. Here is what i turned my Cross bike into.
    By crossracer in forum Cyclocross
    Last Post: 10-23-2012, 05:22 AM
  3. My bike just turned into a tank.
    By the mayor in forum Cyclocross
    Last Post: 09-16-2010, 11:37 AM
  4. Turned Time Trial bike into a road bike.
    By Spezzoto in forum Bikes, Frames and Forks
    Last Post: 01-20-2009, 04:38 PM
  5. How to tell your pet political cause has finally turned into a circus
    By Bocephus Jones II in forum Politics Only
    Last Post: 03-30-2005, 08:26 PM
