Drop bars with flare commendations
Results 1 to 7 of 7
    Reputation: ogre's Avatar
    Dec 2005
    I've got a Moots Routt YBB with 11sp di2 Ultegra. I want to update my regular 46cm/31.8mm dia drop bars to something with Flare. I see a lot of choices - I want something pretty light, butd I'm not sure how much flare to get. I've seen between 12 and 33 degrees so far, and I would think I would want 'a lot of flare', i.e., close to 33 degrees than 12. Any recommendations and pros/cons to what you all have?
    Oct 2017
    My favorite flared bar by far is the Easton EC70 AX. I have them on my Moots Routt RSL and my Norco Search XR gravel bikes.
    I've always used Enve Compact Road bars on my road bikes. When I went looking for a slightly flared bar for riding gravel, I tried the Enve Gravel bar, but found the curve transition into the hoods too abrubt. It's a much sharper curve than their road bars have.
    At a recommendation of someone over on the riding gravel forums, I tried the Easton, and love it. It has a great curve transition into the hoods. The flare is 16 degrees, which is perfect for my riding style. The drop is the same as my Enve road bars. They have grooves to stash cables and hoses in so the look is nice and clean.
    https://eastoncycling.com/collection...ts/ec70-ax-bar
    WIDTH (C to C): 40 - 42 - 44 - 46cm at hoods (at drops +68mm)
    FLARE: 16 degrees
    WEIGHT: 42cm 220g
    CLAMP DIAMETER: 31.8mm
    REACH: 80mm
    DROP: 120mm
    MATERIAL: EC70 CARBON
    The 44 is in stock at Jenson USA
    https://www.jensonusa.com/Easton-EC7...hoCcvAQAvD_BwE
    BikeTiresDirect.com has 42/44/46 in stock but for a little bit more money.
    https://www.biketiresdirect.com/prod...dlebar?sesgl=1
    Apr 2010
    I think these are pretty cool and will get you some attention in the dirt
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Apr 2016
    I am currently running the Whisky No.9 12F bar on my Addict Gravel. I highly recommend it. While I rarely go in the drops, the flare starts right at the levers so I still get a more comfortable hand position. I do wish the flats were a little aero though. But that's a very minor complaint.
    Reputation: threebikes's Avatar
    Jan 2009
    25° aggressively flared, wide drop bar for true off-road performance and comfort Vibrocore™ foam core reduces transmission of harmful frequencies of vibration, and increases bar fatigue life and ultimate strength..
    https://spank-ind.com/products/spank...core™-drop-bar
    Giant TCR
    Oct 2002
    https://www.on-one.co.uk/i/q/HBOOMI/...idge-handlebar
    I've used mine for over 10 years. Short drop with plenty of flare. Bars are like saddles, very much down to personal preference and comfort varies by the person.
    Jan 2009
    Giant TCR
  1. Bontrager Flare RT light
    By ricktreese in forum General Cycling Discussion
    Last Post: 06-23-2017, 10:39 AM
  2. finally saw an Iridium flare last night
    By Creakyknees in forum The Lounge
    Last Post: 03-02-2016, 04:26 PM
  3. Orfos Flare vs. Bontrager Flare R...Tail Light fight
    By colnagoG60 in forum Components, Wrenching
    Last Post: 07-02-2015, 08:49 AM
  4. big drop drop-bars
    By donki in forum Components, Wrenching
    Last Post: 11-14-2011, 11:45 AM
  5. First Group Ride = Drop Drop Drop
    By Darin in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-18-2009, 08:16 PM
