Shimano front shifter for a dropper lever
Results 1 to 4 of 4
    Feb 2003
    All. I have seen plenty of videos of folks using a sram shifter as a dropper lever. I tried to convert my son's tiara lever this weekend and darn if that did not go super well.
    Anyway have any specifics on how to setup a shimano shifter to be a dropper lever?
    I removed the little tab that drops into the rings and by doing so I actually removed the ability to actuate the cable. Ooops.
    Feb 2003
    Well, I did not find any videos or posts about how to modify a shimano lever. I wound up with a 105 lever and went after it. What I found was there is and obvious ratchet lever and a not so obvious one on the side. I had to trim the lever some and drill one hole in it to get rid of the not so visible ratchet lever. Now I have a shimano dropper shifter. Iím pumped.
    JSR
    JSR is online now
    Feb 2006
    Iím not quite sure Iím following you. Is it a 1x setup with the new 105 lever operating the dropper?
    Feb 2003
    Yes. I am going to post a primitive video on tube about this. See if this helps.
    https://www.youtube.com/watch?v=0bnu...ature=youtu.be
  1. Dropper seat post for gravel bike
    By tonyride in forum Gravel Bikes
    Last Post: 04-05-2019, 08:18 AM
  2. Shimano 5700 105 front shifter With 5800 105 front derailleur ?
    By bbohr in forum Components, Wrenching
    Last Post: 08-16-2016, 07:34 PM
  3. Dropper seatpost on Specialized Diverge?
    By borgey in forum Bikes, Frames and Forks
    Last Post: 11-07-2015, 08:14 AM
  4. Gravity Dropper on a roadbike?
    By FoShizzle in forum General Cycling Discussion
    Last Post: 07-21-2008, 03:24 PM
  5. Campy QS Front Shifter with Shimano Front Derailleur
    By HammerTime-TheOriginal in forum Components, Wrenching
    Last Post: 01-08-2007, 10:23 AM
