AQI 0! Who's taking advantage?
Results 1 to 11 of 11
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Air quality finally back to excellent in Bay Area last couple days... time to ride before it swings back the other way!
    Saw the stars clearly last night for the first time in forever.
    Hoping for Diablo summit ride this week but work and kids likely to interfere.
    Jul 2011
    I probably won't be able to get out until Sunday, so may be hot and hazy again. Waiting on some disc brake pads to come in so I can rebuild the calipers on Friday or Saturday.
    Neophyte
    Jul 2007
    Managed to get an hour in on trails with the CX bike... Blue sky!
    Jul 2011
    Quote Originally Posted by 4Crawler View Post
    Now there's your problem:
    Somehow my brake caliper must have moved and caused the pad to wear off center. From the outside, there seemed to be decent pad thickness but inside, the friction material was gone. Hopefully new pads show up on Friday so I can get the brakes built and get the caliper re-aligned.
    Neophyte
    Jul 2007
    Whoa! If cxwrench sees that he may shame you! Rotor seems okay?
    Jul 2011
    Yes, that rear rotor looks to be in good shape. My new pads came in today, ahead of schedule, so I need to get those installed and then get the rear caliper re-aligned. I had been wanting to move my rear wheel back about 3mm and would have needed to move the caliper for that, so time to jump in and do that as well.
    And this all was prompted by a broken spoke 2 weeks ago that had me pulling the rear wheel to fix that. Then since the old rear tire was starting to show age cracks, I mounted up a new tubeless tire. That's when I saw the state of the brake pads. So I guess the broken spoke was a lucky break after all.
    After moving the rear wheel back in the adjustable dropout, I was also able to fit a different caliper adapter in place and I think this will get the pads to line up better on the rotor. Still have to get the front brake pads changed out Sat. then get out for a ride on Sun.
    Oct 2013
    Suggestion: Install all the parts then use the brake lever to lock the disk, then tighten the brake mounting bolts, should be perfectly aligned then?
    BANNED
    Jul 2011
    Yes, that works for the side-side alignment but my issue is more with the front-back alignment of the pads to the rotor. I think I have it dialed in now. When I first built the bike, I didn't fully appreciate the interaction of the horizontal slotted dropout and the fore-aft adjustments and rotation of different adapters for the rear brake caliper. Its strange though that the first time I replaced pads about 4 years ago, the wear seemed more even, but maybe I wasn't paying close enough attention. I must have inadvertently changed something in the mean time that threw the pads off to one side of the rotor.
    With this frame, it has about 20mm horizontal adjustment of the rear axle position (chain stay 425-445mm) as well as the caliper location. But I found I also needed to rotate the caliper up/CCW a little as I moved the axle back to get the pads to line up with the rotor better. Once you figure that out, it's obvious. But this is my first frame with both that style dropout and disc brakes:
    Jul 2011
    Got out of a test ride on Sunday afternoon. Hot in the valley but fortunately the temperature inversion that's been hanging around most of the last month is gone. Back to the normal 15F cooler temps once you start climbing up in the Santa Cruz mtns.
    Rear brake is working great with the new pads and re-aligned caliper, totally silent. Also, I think I'm liking the 10mm longer wheelbase, front tire seems to stay planted easier on steep 30% ramps on the dirt trails. I think my RD is also working a little better with the new 11-45 cassette. I had been getting some chain skipping in the lower gears under heavy load but at least on a few tests, that seems to have gone. With the axle/cassette moved back, now the upper jockey wheel sits just in front of the large cog instead of right in line with the diameter. Maybe that bit of gap helps, time will tell.
    View from the Grizzly Flat parking area on Hwy. 35 looking SW towards the area of the CZU fire complex. Just a bit of haze in the air:
    Neophyte
    Jul 2007
    I managed the desired Diablo summit ride on Saturday although the top half was a disaster. Didn't realize I was riding that hard up to the junction and was dehydrated from previous day running shenanigans.
    BTW great pic from your ride, I miss the views on Skyline which I got to ride more up until last year (would work in Palo Alto once a week until partner re-org moved all my contacts to Taiwan and Houston).
    Jul 2011
    Looks like a nice day to ride up Diablo.
    So much for the good air quality. Smoke rolled in today and we're sitting at 180+ right now.
  1. taking advantage of your smrts my thermostat upgrade
    By superflylondon in forum The Lounge
    Last Post: 01-24-2016, 07:58 PM
  2. Replies: 5
    Last Post: 11-19-2015, 01:05 PM
  3. What's to Stop Nations From Taking Advantage of Us?
    By weltyed in forum Politics Only
    Last Post: 09-25-2008, 01:15 PM
  4. Bush admin...stoop to taking advantage of a sick Ashcroft
    By Bocephus Jones II in forum Politics Only
    Last Post: 05-16-2007, 03:43 AM
  5. Advantage of aero/TT/tri bike?
    By K-Zero in forum General Cycling Discussion
    Last Post: 03-15-2004, 07:15 AM
