6 speed to 9 speed conversion, I need a parts list
Results 1 to 11 of 11
    Apr 2010
    1st post so bear with me. I have been an avid MTB for 15 years. I recently decided to get into road biking for exercise. I bought a beautiful Trek 500 tri-series.
    I know it would be easier and probably cheaper to just buy a new bike, but I really love the way this steel bike rides and feels.
    I want to convert it from a 6 speed friction to a 9 speed indexed with brifters.
    Can you guys give me a parts list of what I'll need in order to do this. I will be buying parts slowly over the next several months.
    I know I need a new wheelset, 9 spd. cassette, 9 spd. chain, rear deraileur, front deraileur, brifters.
    What else am I missing??
    Thanks,
    Tony
    Old and Fixed, Moderator
    Jan 2002
    Rear spacing? Before you start gathering parts, check the rear spacing.. 6 speed likely means the frame is spaced at 126mm(or possibly even 120mm). You need 130mm rear spacing to run 9 speed. If the frame is steel, it's possible to spread the rear from 126 to 130. If it is aluminum, probably not..
    Dave Hickey/ Fort Worth
    Reputation: zmudshark's Avatar
    Jan 2007
    I believe the Trek 500 Tri was only built in 1986, and was Reynolds 531. You will be able to spread the rear from126 to 130 with no problem.
    Though you can use your original crank, I would really suggest getting a modern one that matches the drivetrain. You would only need a rear wheel, the front is fine. One of the biggest improvements I've found on modern bikes is the brake calipers. They are MUCH better than the Shimano Z series than came on your bike.
    duh...
    Jan 2005
    entire drivetrain
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    Aug 2006
    your list so far
    new rear wheel or a new hub to be laced into your existing rim
    rear derailleur
    front derailleur
    brifters
    crankset
    chain
    cassette
    cables w/ housing
    cable stops for downtube braze ons
    the first half of that list can be purchased used, the second half you probably want to buy new
    Reputation: PlatyPius's Avatar
    Feb 2009
    Quote Originally Posted by bane
    your list so far
    rear derailleur
    front derailleur
    brifters
    crankset
    chain
    cassette
    cables w/ housing
    If the OP buys new brifters, they come with cable stops.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    duh...
    Jan 2005
    Quote Originally Posted by PlatyPius
    they should, but I recall that some lately do not
    Feb 2009
    Quote Originally Posted by FatTireFred
    No sh!+? So Shimano expects you to buy their $40 cable stops to use with their $140 (2300) brifters?
    Guess I'm glad I have an inventory of 100 or so of them here.
    EDIT: You're right. Just checked the new set of 105 brifters here....no cable stops.
    Aug 2006
    How are those 2300 brifters? I have a buddy that might be doing something similar to this soon (7 to 9/10 conversion)
    Feb 2009
    You'll see people rag on them on here a lot. I think they're fine. I'm a Campy guy, so I'm used to the thumb levers. Considering their price, they're fine for old bike conversions. I have a pair on my 1970s Stella.
    Reputation: Kuma601's Avatar
    How about a pic of your new ride before the parts are swapped?
    At your option, you don't need a crankset. If Shimano, update the big chain ring for one with the shift pins and you are good. I'm using a 600EX with a 6500 A series big ring. This was also used with the 7700 DT and now 7800 shifters. With all those new parts, might as well buy the crankset and that will also need a bottom bracket. If that far, might as well consider some updated brakes.
    Are you sure you don't want to just buy a complete bike?
