Although no expert I would speculate, on account of 2 water bottle mounts, early\ mid 80's. Those shift levers are, in my opinion, the finest friction shifters available. They shift, up or down, with eaqual smoothness and don't slip.
If you're going to give the bike a going over it'd be worth your time to make sure the springs in the shift lever bodies are intact. The little tab has been known to snap off. It's my understanding that if it does break a new tab can be bent on the same spring and it will still work as intended.
maybe the seat tube bottle bosses were added later and that decal was used as cover for the brazing.
what is the rear spacing? 126? and what is the rear derailleur? sorta looks like campy rally.
That fork crown was used up until early 80's, then the Air fork was phased in. Check the fork steerer for spiral ridges on the inside and that will indicate Columbus SL. The same ridges inside the down tube and seat tube would indicate SLX, but I suspect this frame is before SLX came out. My guess is your frame got a repaint and the owner ran out of money on the re-stickering.
I see you posted over at BF too. Check out this very helpful thread:
https://www.bikeforums.net/classic-v...-registry.html
 Originally Posted by blackfrancois
maybe the seat tube bottle bosses were added later and that decal was used as cover for the brazing...
Good call. The frame was definitely reworked because that pump peg style was never used on production frames. Nevertheless, it could be a Columbus SL or SLX quality.
The spacing is 126, and the rear derailleur is early Dura-Ace.
Cool bicycle. Ride it happily. And like velodog says, those retro-friction shifters are great. They were my go-to shift levers back in the day.
Mapie is a conventional looking former Hollywood bon viveur, now leading a quiet life in a house made of wood by an isolated beach. He has cultivated a taste for culture, and is a celebrated raconteur amongst his local associates, who are artists, actors, and other leftfield/eccentric types. I imagine he has a telescope, and an unusual sculpture outside his front door. He is also a beach comber. The Rydster.
By daveallen in forum Bikes, Frames and Forks
Last Post: 12-14-2010, 03:51 PM
By bigreen505 in forum Bikes, Frames and Forks
Last Post: 10-26-2010, 01:22 PM
Last Post: 10-24-2008, 07:55 PM
By acid_rider in forum Bikes, Frames and Forks
Last Post: 11-22-2006, 06:55 AM
By yzfrr11 in forum Bikes, Frames and Forks
Last Post: 03-29-2005, 08:18 AM
- You may not post replies
- You may not edit your posts
Forum Rules
