braze-on with lightweight clamp vs clamp-on
Is there any weight savings to be had by buying a braze-on with a carbon clamp (if such an animal is made)? For me this would be specific to Campy. I have done a forum search and only came up with threads discussing factory parts. Before I order a Record clamp-on I can't help wondering if a dependable, weight saving, braze-on/clamp set up is available.
Juanmoretime
There are two options.
Yes a carbon clamp that works with a braze on derailleur is a available from here:
http://fairwheelbikes.com/shop/index...ece49b6bf53e2f
Fairwheel can also supply you with alloy bolts to replace the steel one that holds the cage together, the cage pivot bolt and the limit screws.
The other option is to order the tuning bolts from fairwheelbikes and take a dremel tool and machine the clamp down. See the link.
http://weightweenies.starbike.com/ph...ht=popawheelie
If you search some more over at weight weenies you will find clamps where most of the clamp has been machined away like cutting a large slot in the band since al the material on the band isn't necessary.
For my next trick I will now set myself on fire!
I checked out the Fairwheel website. At 90 bucks for a carbon clamp and 300 for a drilled derailleur those are some pricey grams! I just bought a Look 585 frameset in great shape off of e-bay and will be gradually building it up as a project bike. I hope to build it under 15 lbs. I bookmarked Fairwheel and Weightweenies, thanks JMT. Drilling looks risky (as in ruining a part) but fun. I don't think you could get away with sending the part back and saying "I was just riding along when it broke"
Juanmoretime
I would still contact Jason at FWB and get all the alloy tuning bolts since this will be relatively cheap and cut 6 or 7 grams easy. All the fastners on the derailleur can be replaced and the steel ones just aren't necessary. I've been riding a tuned front Record derailleur for over a year and half and it still works fine.
BTW, you welcome!
Be careful with the BTP carbon clamps. I have seen/heard of mnay cracking. So far mine has held up well. Jason @ FWB sold me mine. Got bolts from him in the past as well. Good guy!
DIRT BOY
"Pain is a big fat creature riding on your back. The farther you pedal, the heavier he feels. The harder you push, the tighter he squeezes your chest. The steeper the climb, the deeper he digs his jagged, sharp claws into your muscles." - Scott Martin
There was a thread on this on the weightweenies.com site- apparently the first version of the btp clamps were cracking but it seems to have been solved w/ the 2nd generation.
DIRT BOY
Just won an e-bay auction on a record braze-on, will now begin the clamp search. Would not have gone with a braze-on but for the good info here. Thanks all!
- You may not post replies
- You may not edit your posts
Forum Rules
