Axiom SL Di2/EPS factory retrofit
Results 1 to 5 of 5
    May 2011
    Hi,
    I asked my LBS about retrofitting my Axiom for Di2, and it's $1000 when done by Seven. There are several mods, including some strengthening procedures that are performed around the drilled holes. Optionally, they can remove the barrel adjusters, but this also requires getting it painted to cover up this repair. (an additional $400 for basic paint job.)
    Question is, has anyone done this and are they happy with the results? I'd like to get others opinion before dropping $1400+ for a frame retrofit.
    Thanks!
    Apr 2013
    Quote Originally Posted by mgringle View Post
    Hi,
    Thanks!
    Saw this the other day. Seven is certainly a good outfit to work with previous buyers in this way. This makes seven truly a bike for a life-time. While , I'm clearly biased in favor of mechanical, do have to ask in light of the substantial cost of upgrade, 'why and what do you hope to gain?'. Your great bike will not get any better.
    May 2011
    Quote Originally Posted by Trek_5200 View Post
    I respect your opinion regarding electronic not being better than Di2/EPS, I just happen to disagree. I really wasn't trying to make this thread about what is better, I was more interested in hearing about anyone's experience or thoughts on converting.
    Aug 2007
    if your bike is painted it will require repaint when you do the di2 holes. seven drills a hole in the tubing then welds a reinforcing ring around it.
    Reputation: kmak's Avatar
    Sep 2011
    sounds like the perfect opportunity to just go ahead and order a new frame, the incremental cost is worth it. :-)
  1. Calfee Di2 internal battery retrofit
    By Chainstay in forum Components, Wrenching
    Last Post: 02-08-2013, 09:47 PM
  2. Campy Retrofit
    By ACC in forum Retro-Classic
    Last Post: 02-25-2010, 12:53 AM
  3. S&S Retrofit
    By Dumbod in forum Hot Deals
    Last Post: 04-27-2009, 03:13 AM
  4. S&S retrofit in Texas or vicinity?
    By M.J. in forum Commuting, Touring and Ride Reports
    Last Post: 09-11-2008, 09:50 AM
  5. FSA megaexo ISIS B.B.retrofit/Teamissue?
    By twelvepercent in forum Components, Wrenching
    Last Post: 02-21-2005, 10:12 AM
