RD hanger issue
Results 1 to 20 of 20
Thread: RD hanger issue
    Nov 2014
    RD hanger issue
    I had an Axiom SL built in 2013. The LBS built it up with Campy Record 11. The bike was great except I was disappointed that my old '95 8 speed Record was a much more precise shifter. I chocked that up to progress.
    After more B adjustments by LBS than I care to remember, I finally found a really good Campy mechanic that discovered the Seven's rear derailleur hanger is placed to work with Shimano/SRAM but not Campy. He contacted Seven and learned that all frames are shipped to the LBS with a Campy adapter. The problem is that the LBS that is the sole Seven shop in my city forgot to include it in the build. They also used the Campy front brake bolt instead of the one Enve provides. Braking is now much better no thanks to LBS.
    Nov 2014
    IMG_0106.jpgIMG_0108.jpgToday I had the adapter/spacer from Seven installed and...the shifting problem persists.
    Am I alone in having Campy-Seven compatibility problems?
    Edit: Add photos
    Jan 2010
    I'd like to see Sevens explanation as to why they think a spacer is needed behind the RD for an 11-speed system. Regardless, the first thing to check is the hanger alignment with a proper tool. Has that been done?
    There's sometimes a buggy.
    One.
    Nov 2014
    Hanger alignment was the first thing ruled out. This seems to be the problem and, to me, a stickier issue to explain.
    Quote Originally Posted by bikerjulio View Post
    Jan 2010
    Interestingly Shimano has 24-26 mm for "L" and 4-10 mm for "X" which is very close to the Campy spec. So, if you are correct the frame meets neither spec. I cannot see a couple of mm in the "L" dimension being of too much importance, in fact it's a benefit for running larger cassettes. Not sure I see either issue as responsible for a shifting issue. If you post this in the "wrenching" section you might get some more feedback.
    Shimano Framebuilder Info - Pvdwiki
    One.
    Nov 2014
    As I understand it, the problem is with X being to far rearward not allowing for enough chain wrap. One of the solutions the "Campy" mechanic suggested was a longer chain with the only disadvantage of chain contact if I were ever to go small chainring (34t) with small cog (12t).
    Edit: Thanks for the link. Things are really confusing now, lol.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    RD hanger issue
    Do I dare ask the obvious? Have you asked the LBS/Seven to take the bike and fix the shifting?
    With bicycles in particular, you need to separate between what's merely true and what's important.
    Jan 2010
    Quote Originally Posted by dcgriz View Post
    One problem as I see it, is that the story provided in the OP by the "good Campy mechanic" makes absolutely no sense.
    For one - unlike what the expert told him, there is essentially no significant difference between Campy and Shimano frame specs - how could there be?
    OP also talks about a "Campy adapter" when in fact an "11-speed" washer is what is shown. This is the only frame I've ever seen that needs to space out the RD for 11-speed which also makes no sense to me.
    The LBS also suggests a longer chain will fix the problem. Really??
    My interpretation of all this is that OP is barking up the wrong tree, and that he's the victim of a poor installation job. I'd be checking for cable routing and friction problems, as well as rechecking alignment and RD setup.
    He needs a more competent mechanic IMO.
    Or to read up on these things and do it himself.
    One.
    Nov 2014
    I took my last ride for the season today and will be taking it back to the LBS to diagnose. As I've mentioned above, they have made a half dozen different mistakes not related to the shifting problem, but the possibility that it could be a warranty issue leaves me no choice. They said that the were going to throw a new cassette on it to see if that makes a difference.
    To clear any confusion I may have caused, the mechanic that was recommended as a Campy specialist, measured the relationship of the dropout to the hanger and compared that to Campy specs. After finding that Seven might be out of spec, he called Seven and was assured there was an adapter that had been left off the initial build by the LBS and would ship one to him. When it arrived a week later he found that it was just a spacer and also could not figure out how that could make a difference. He installed it anyway and saw no change.
    Bikerjulio, you're right. It doesn't make sense since the problem involves an upshift to one specific cog (fourth one up, don't know # of t). Insufficient chain wrap doesn't explain why/how all the rest of the shifts are fine and why it's less of a problem with a freshly lubed chain.
    Jan 2010
    Could be as simple as an incorrectly assembled cassette, with a spacer in the wrong place, or the wrong spacer.
    One.
    grizzly moderator
    Feb 2011
    RD hanger issue
    If it is just an incorrectly assembled cassette it should put to shame all the mechanics that have worked on the bike for not spotting such an elementary issue immediately just by looking at it.
    At any rate, it's a 5 minute proces to disassemble and reassemble the cassette just to make sure.
    grizzly moderator
    Feb 2011
    RD hanger issue
    I agree on all points
    Jan 2010
    Thinking about this possibility again, it seems to me unlikely. It's hard to screw up an 11-speed record cassette.
    One.
    grizzly moderator
    Feb 2011
    RD hanger issue
    Hard to believe but maybe the fourth cog is flipped (upside down)?
    Jan 2010
    No, the offset spline pattern makes it impossible to flip a Campy sprocket.
    I'm back to an install issue.
    One.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Any resolution to the issue?
    Trying to cram the rest of my life into the rest of my life!
    Jan 2010
    Quote Originally Posted by DaveT View Post
    The issue was moved over to this thread, without a satisfactory (to me anyway), answer.
    http://forums.roadbikereview.com/com...ml#post4779119
    One.
    Nov 2014
    The issue has been resolved in a sensible and prudent manner for one with more money than years. I'm not rich, but at 57, I don't know how many more strong years I have left. Not enough to spend anymore time enduring the seemingly endless excuses of that particular LBS.
    So, I bought a Colnago C60 with Super Record from another shop.
    Well, that's certainly a fix for your problem!
    Nov 2014
    At the risk of being perceived as a nut job, but with a desire above all else to be fair, I report the following.
    In another thread http://forums.roadbikereview.com/com...em-343272.html I tell of transferring my Campy components from the Seven onto another frame as a test to try to zero in on the shifting problem.
    It is true that the first ride of the components on the different frame was amazing. Upshifting that precise and instantaneous and downshifting with a shorter throw and with the shift completed simultaneous with the click of the lever. It was the Campy Record I was familiar with and met my expectations for the first time since the purchase in 2013. So I reasoned that the Seven frame was out of spec. and the reason for the poor performance.
    Until the next day on the second ride. Shifting was down the crapper. Again. Downshifting to the forth sprocket was hit and miss, mostly miss, and the throw of the lever seemed longer and stretchier. Again.
    Obviously not the fault or problem of the Seven frame. Apologies to Seven and thanks to those who have responded trying to help.
  1. Broken Derailler hanger issue
    By Sauvi in forum Trek
    Last Post: 02-03-2014, 07:03 PM
  2. Best fix for loose FD hanger???
    By NEO Dan in forum Components, Wrenching
    Last Post: 09-03-2010, 06:39 PM
  3. CR1 D-hanger fix
    By rbutler in forum Scott
    Last Post: 03-28-2008, 03:17 PM
  4. cervelo r2.5 derailleur hanger issue
    By rockstar in forum Components, Wrenching
    Last Post: 09-05-2006, 06:30 PM
  5. ACK! Where do I get a hanger?
    By SCW in forum Components, Wrenching
    Last Post: 05-13-2005, 08:02 AM
