Seatpost Size Question
Results 1 to 4 of 4
    Aug 2012
    From this picture, is my Seven seatpost size 27.2mm or 28.6mm? I measured the inside diameter of the seat tube and I am getting ~27.9mm with the tip of the tube already bent.
    How do you compare it with your seat tube? It is tightened the same way? What seatpost size will you recommend?
    I got my Seven used.
    Feb 2005
    Should be 27.2mm. They have a composite sleeve inserted in the seat tube to prevent seizing.
    Tim
    Aug 2012
    Thank you!
    May 2012
    Yes, it should be 27.2mm seatpost. I have the same sleeve and screw and everything. But my seatpost keeps sliding inside the seat tube. I've tightened it very hard. I asked my LBS about it and he said I need carbon paste which has fine grit in it to provide friction between two carbon surfaces.
