If you are having login problems....
Results 1 to 24 of 24
    cyclist
    Reputation: gregg's Avatar
    Oct 2000
    If you are having login problems, 3 things to check.
    Everyone who has registered in the old system has been copied over to this new system. This means your username, password and email address should all be on file. (If you registered on the old forums when they first came out, you may not be in the system) If you've changed your username multiple times on the old system, keep in mind that it was your most recent info that was copied over. We might run into some problems with passwords not being correct, etc. So this is the order of operation on how you should try logging in here:
    1.) Simply try logging in with the username/password you had in the old forum.
    http://forums.roadbikereview.com/
    And enter your login/password in the box. If that doesn't work, go to the next step.
    2.) Try retrieving your password. You'll be asked for your registered email address. Enter that and submit, and you'll receive an email with details on how to proceed. You must use the email address you had on file with us in our old system. If you do not have access to that email address anymore, this step will not work for you. You'll have to go on to the next step.
    http://forums.roadbikereview.com/login.php?do=lostpw
    3.) If the first two steps didn't work, you can try registering a new account.
    http://forums.roadbikereview.com/register.php
    This will only work if you are using an email address that is not in our system. We only allow one account per email address. If our system tells you that your email address is already in use when trying to register a new account, it is because your info is already in our new system, but that there is a mixup with your username and password preventing you from being able to login. If you are not able to login after following these steps, please post the errors you receive in the old forums system (linked immediately below) so that we can look into it:
    http://forums.consumerreview.com/[email protected]@.efe395a
    We'd rather you post your problems with the new system there instead of emailing us so others can view the problems and see the fixes. If you are able to register a new account, your problem is solved.
    We'll leave the old forums open for posting for another few weeks until all the wrinkles of this new system are ironed out. After that time, we'll end up migrating the old boards to the new platform, then turn off posting there so that everyone can move over to here. We'll leave those forums open for reading only, and save them as an archive.
    Thanks for your support and patience.
    -gregg kato, Site Manager
    cyclist
    Oct 2000
    Don't forget that username and password are case sensitive.
    -g
    Reputation: covrc's Avatar
    Mar 2004
    Classified Sign In Trouble
    Hi,
    I have no problem signing into the website with my screen name and password.
    When I try to sign onto classifieds to place and ad, I get a message that my screen name is not found.
    Any ideas about this. I can sign out and back in at 'Home' site, but when I go to Classifieds, I get shut down.
    Thanks.
    covrc
    the other Derek
    Reputation: bustamove's Avatar
    Aug 2004
    Another conflict causing login problems
    AOL and Earthlink users must shut off their ISP software before logging into the message boards. ISP applications cause conflicts with our forums software and login problems ensue.
    Oct 2011
    I've emailed the moderators with my forum issues and am not getting a response. Since I can't start a thread and can't get a response I'm left with replying to other threads in hopes of getting assistance.
    I receive a message every time I log in asking me to post my first thread in the General Cycling forum, but when I try it says I must have 5 posts firsts.
    I tried to post a new thread in this forum, but again, when I try it says I must have 5 posts first to start a new thread.
    Either I'm having a unique technical issue, of this forum has some weird-ass restrictions.
    (Sorry - would NEVER normally post this as a first post on a forum, but since I can't post a new thread, and can't get a response from moderators, what am I to do?)
    the other Derek
    Aug 2004
    @DallasMCS - you are being affected by two rules. One is the vBulletin software recognizing that you have not posted any new threads within a designated time period. The rule is there just to encourage participation.
    The 2nd rule we have in place is that new users cannot create new threads until replying to a minimum of five existing threads. This rule is in place to prevent spammers from creating new accounts and then spamming the forums right away.
    Reply to a few more threads until you reach the minimum of 5, then you should be able to create a new thread.
    Derek
    A smile is a curve that sets everything straight.
    Nobody
    Apr 2012
    This is Fixed / Doug. Looks like all my info was lost. Was able to register new user name with same email address. Can you restore my old one? I cant live with one green square.
    Call me a Fred
    Reputation: MikeBiker's Avatar
    Mar 2003
    Quote Originally Posted by 3.14159 View Post
    You have to post a pic of your fork so that we know that it is really you.
    Mike
    You may starch my jumper
    Hang it upside your wall
    You know by that, baby
    I need my ashes hauled.
    Sleepy John Estes
    H
    MarkS-new
    Guest
    MarkS here. I'm in the same boat as Fixed. If physasst is likewise situated and Fixed and I are not restored to our former name/status, it will be Wild West Days in PO.
    Slightly Opinionated
    Reputation: robdamanii's Avatar
    Feb 2006
    I'm guessing that along with the site attack and script append, they nuked the mods accounts to prevent post locking or cleaning up the mess.
    Seems to be confirmed on Vbulletin forums.
    Quote Originally Posted by bigrider View Post
    Teh Lounge- "Its not just for weirdos anymore. It is for those trying to escape the noobsauce questions."
    Quote Originally Posted by QuiQuaeQuod View Post
    Trolling the lounge is like noodling for piranha.
    The Daily Grind Cycling Journal & Tailwind Coaching
    Call me a Fred
    Mar 2003
    Does this mean that we are unmodulated? Anarchy reigns!
    Mike
    Sleepy John Estes
    H
    MarkS-new
    Guest
    Quote Originally Posted by MikeBiker View Post
    It looks like the RBR equivalent of a bomb going of at the State of the Union Address has occurred. At least when everyone who is anyone in the US Government is gathered for the State of the Union Address, one cabinet secretary is kept away in a secure, undisclosed location in the event that a disaster occurs and wipes out everyone. Yes, anarchy reigns. But, don't get too far out of hand. Once the mods are back in control, who knows what kind of crackdown will ensue.
    Feb 2006
    We can post boobies completely unfettered!
    MarkS-new
    Guest
    Quote Originally Posted by robdamanii View Post
    Now, to get us truly back to the Wild West Days of 2000 when I joined RBR, you need to compress all the forums into one and then post whatever you want without fear of the banhammer.
    newb
    Apr 2012
    guys ive been getting a redirect everytime I look at a post, seems your vbulletin has been compromised. I got around the issue by turning off javascript.
    Reputation: wtfbbq's Avatar
    Apr 2012
    Gripped still locked out
    I was on vacation for the great hacker fiasco 2012. I still can't get in with me usual user name and password. Any help?
    Aug 2012
    No login problems here, just sayin.
    Jun 2012
    Anyone having trouble logging on to MTBR forums? I can't log on, so I can't report anything to the admin over there. Every time I attempt to log on, it tells me I have exceeded to number of log on attempts allowed, even if I only tried once. Any thoughts?
    cyclist
    Oct 2000
    Quote Originally Posted by jmal View Post
    Yes, we are having problem with login on Mtbr right now. We hope to have it fixed soon.
    -gregg
    Jun 2012
    Thanks. I was finally able to log in again.
    cyclist
    Oct 2000
    Yup, just fixed it
    Aug 2012
    Testt
    Aug 2012
    Testing
    Aug 2012
    Testin
