2012 Supersix Evo Tyre Clearance
Results 1 to 8 of 8
    May 2012
    Being an older bike it has minimal tyre clearance around chainstay. I am running 25mm tyres. Stupid question but to maximise tyre clearance is it better to run the tyres at a higher or lower pressure? What pressure would you recommend? I'm 83kg.
    Many thanks.
    Sent from my SM-N920I using Tapatalk
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    You should run tire pressure based on your weight and riding conditions. Not for tire clearance. Besides, pressure change in the tire will have no affect on the tire width at the chainstays.
    I'd start at 80psi front. 100psi rear. Lower it as applicable.
    I suppose one could argue the lower the better if you are using tires that eventually stretch to become bigger. But even then I'm not sure it would matter and if it does they'll probably just expand a little later with less PSI.
    But as said there should be no connection between PSI and clearance.
    Oct 2013
    Also consider road conditions just as important. If you know there are no chuckholes or sharp edges, you could probably reduce those # by at least 10# F/R.
    BANNED
    changingleaf
    Aug 2009
    Higher pressure will reduce your tire clearance. If the tire isn't rubbing the frame when you stand up and sprint or climb then you're probably fine at the pressure you're running. You can only go so low without risking a pinch flat. If you don't ride in groups or can always see a pothole before you hit it then you can get away with less air pressure.
    May 2012
    Quote Originally Posted by changingleaf View Post
    Thanks changingleaf. I'm using a 25mm Conti 4 season. How low can you go? Yes I ride by myself and happy to take the pinch flat risk. Cheers!
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    At 220 lbs, I ran my 25's at 90 psi rear, 80 psi front without issue. YMMV
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    changingleaf
    Aug 2009
    It can vary for different people. I would start with 80/90 and probably go up if necessary.
  1. 2016 supersix evo 105 vs 2017 evo 105
    By sheepherder in forum Cannondale
    Last Post: 10-30-2017, 07:02 AM
  2. Rear clearance challenges on my Supersix Evo
    By vtsteevo in forum Wheels and Tires
    Last Post: 12-06-2015, 07:30 AM
  3. Upgrade from Cannondale SuperSix non-EVO to C-dale SuperSix EVO
    By multirider in forum Bikes, Frames and Forks
    Last Post: 03-16-2015, 11:36 AM
  4. Colnago Cx-1 Evo vs Cannondale Supersix Evo Red
    By mcgusto in forum General Cycling Discussion
    Last Post: 08-26-2013, 09:36 AM
  5. 2012 supersix Evo vs 2011 supersix Hi -mod
    By Supinator in forum Cannondale
    Last Post: 10-04-2012, 06:51 PM
