ABEC 3 or 5 for wheel bearings and freehub?
Results 1 to 4 of 4
    Jul 2012
    I'm going to be replacing the rear wheel and freehub bearings soon. They have never been the same after I discovered that the drive side cone nut had been loose for awhile and I had number of rides while in this condition.
    Background:
    Back in the spring, I was having creaking noises and one of them was the BB bearings, but even after installing the V2 bearings ('12 Madone), I continued having noises. I later found (on a humble) that the drive side cone nut was loose, but I don't know how long it had been loose. The bearings felt rough, so I repacked with grease and it was ok, but they just were never the same. So, now I plan to just replace all 4 bearings.
    It's my understanding that higher ABEC ratings doesn't necessarily translate to better bearings. I read Enduro's information on this topic and noted the difference between their ABEC 3 and 5 bearings are the 5s have tighter tolerances, different grease, more roundness of the balls, frictionless retainers and some other stuff.
    In the bike world, which bearings are used?
    Would you go with ABEC 5 since they have a better build?
    Thanks...
    'brifter' is f'ing stupid
    Sure, why not? You're never going to feel the difference but the better quality bearing with better lubrication will last longer.
    #promechaniclife
    Jul 2012
    Thanks. That is what I was thinking, too. I wanted to check to see what others have done when it comes to wheel bearings. I ordered the 5s.
    Jul 2012
    All done. I've replaced all of the rear wheel bearings. No more rough and grindy bearings. The 2 freehub and drive side bearing were the problem child, which was the side that had the loose cone nut. The non drive side bearing was still in good shape.
  1. Swapping RSX 7-speed freehub for 8/9/10 speed freehub, FYI
    By shamethellama in forum Components, Wrenching
    Last Post: 07-11-2015, 04:26 PM
  2. Can Fulcrum Racing 1 Shimano freehub be changed to a Campy freehub?
    By slider2453 in forum Components, Wrenching
    Last Post: 04-01-2008, 04:52 AM
  3. ABEC-X vs. Grade-X
    By no msg in forum Components, Wrenching
    Last Post: 01-27-2008, 03:14 PM
  4. Replies: 8
    Last Post: 12-28-2006, 05:06 PM
  5. Replies: 1
    Last Post: 12-07-2005, 05:21 PM
