Aerodynamics - rim depth vs. rim width
Results 1 to 8 of 8
    Nov 2002
    So with the recent hype of wider wheels being more "aero and stable in cross-winds, etc", what do you think is more aerodynamic (assuming equal conditions) - a rim that is slightly more shallow but wider vs a narrower rim that is deeper. Specifically, For an upcoming race I'm trying to decide between a Hed Jet 6 (wider 23mm rim) vs a Zipp 808 (non-firecrest model so it's not as wide).
    Jun 2013
    I went with the Shimano C50. Wide profile, 50mm obviously. I have been surprised by the fact that they do help me in windy conditions, about 3 minutes per hour, and I have not noticed any effects from strong crosswinds. I think Shimano got the shape right.
    Nov 2006
    Depends on the tire width and type. The older 808s will need narrower tires to be as aero as the Jets. If you're running wider tires go with the Jets. Otherwise its pretty close.
    Reputation: looigi's Avatar
    Nov 2010
    FWIW: Much of the improvement in insensitivity to crosswinds comes from the rim having a blunt inner edge more like the blunt edge formed by the tire. This makes the portion of the wheel behind the axle have similar aerodynamics and experience similar side-force to the portion of the wheel in front of the axle.
    ... 'cuz that's how I roll.
    Go with the ones you are most comfortable riding. The aero difference, whatever that might be, isn't going to change how you do in the race.
    Reputation: stevesbike's Avatar
    Jun 2002
    the Jets beat the 808s according to both companies published aero data.
    Feb 2005
    Jul 2014
    That's what I'm thinking. Either wheel will work just fine.
    I've done a good bit of racing and TT's over the years. Never heard anyone (yet) say "I would have won if I made a better front wheel choice".
    Mike
  1. Sitbones Width & your saddle width
    By btc in forum General Cycling Discussion
    Last Post: 03-25-2018, 07:17 AM
  2. Saddle Width vs. Sit Bone Width
    By azpoolguy in forum General Cycling Discussion
    Last Post: 01-07-2010, 04:40 PM
  3. Help: Tire width vs. frame/fork width question
    By TBone in forum Components, Wrenching
    Last Post: 08-07-2007, 11:51 PM
  4. Newbie Question: Tire Width vs. Rim width???
    By scotthunt1 in forum Cyclocross
    Last Post: 09-04-2005, 11:08 PM
