Alternating wear pattern on my GP4s
Results 1 to 2 of 2
    Nov 2009
    What causes it? Any way to prevent it? At the nipples I'm through the anodization on both sides of the rim. Between the nipples anodization is intact. The spokes feel looser than those on the clincher rim set (Open 4 CD) where the anodization wear has no pattern. Not drastically looser, just enough to notice.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    Common pattern. The rim deforms slightly under tension. My GP4s have the same thing as to all alloy, box section tubulars I've seen with a dark anodizing on the brake track.
    -Eric
