Anybody had this happen?
Results 1 to 25 of 25
    Apr 2018
    Brand new Conti GP5000 tubeless, maybe 110 miles. The bubble is so soft you could likely pinch and pierce it with your fingernail.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I had that happen on a Specialized tire a number of years ago. The last 3 miles of my ride was a cyclical "bump, bump, bump". A few minutes after I arrived at the start site - BOOM!!!!!!!
    "With
    -- DCGriz, RBR.
    What the Hell is going on
    Reputation: JaeP's Avatar
    Mar 2002
    That's why I avoid Conti tires. I've had that problems with, I think, their Ultra tires. Conti Tubulars, on the other hand . . .
    You'd think we were here for something other than fun. - Ishmael
    Sep 2011
    RIP conti tire
    'brifter' is f'ing stupid
    You cut the sidewall. Could happen after 100' or 1000mi. Could happen to any tire although some are stronger than others. Oh well.
    #promechaniclife
    Apr 2018
    I've been running Conti 4000's and 5000's for many years now with great luck although only about 6 months on tubeless now (this was the first real ride on this particular one).
    I agree that it looks like a sidewall cut in the picture although I don't remember running anything over at all especially that would have reached that far around the sidewall. For reference the line with the shadow above the obvious hole isn't a cut it's actually the little extra rubber that dangles for a while from the factory form. The actual cut/hole stops about midway up the "9"
    Banned Sock Puppet
    May 2014
    The one I had wasn't a cut. It was a fairly large bubble that tore open the sidewall.
    "With
    -- DCGriz, RBR.
    Sep 2011
    Quote Originally Posted by gloverb103 View Post
    now that you put it that way, then I think this tire has a defect. In addition, the other frayed spot on the sidewall tells me this tire is defective, because i've never seen 2 damaged spots on the sidewall that happened due to road debris cut.
    Pothole. Rock. Doesn't have to get cut in the classic sense by a broken bottle or a steak knife someone left in the road.
    #promechaniclife
    Sep 2011
    true, but if you look at the photo closely, you'll notice that on the other side of the cut there is also fraying spots of varying gradation. Yet,, there is absolutely no "intermediate scratches" on the sidewall between all these frayed spots. If the sidewall was to hit a big enough pothole to cause multiple frays and a big cut, I'd expect to see scratches on the surrounding rubber too.
    I'll bet if the OP take a look inside the tire, there might be signs of the case shearing too.
    Apr 2018
    I would look on the inside but the shop where it was purchased has already replaced it and will follow up with their own claim with Conti as they agree it's not road damage.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    I've put tens of thousands of miles on Conti 4000, 5000, tubed, and tubeless. Never had that happen.
    Definitely looks like he caught the edge of a pothole. One large gash and 5-6 other vertical slashes. on either side.
    Oct 2013
    He didn't mention a pot hole, so I'm going with 'defect'.
    BANNED
    Banned Sock Puppet
    May 2014
    While I have no love for Conti, I have no hatred for them either. I have just always found options that are better for me and at a better price point. It seems they are a very popular tire, so statistically, the more units there are, the more problems/complaints/incidents there will be. Granted there is always a possibility of QC issues.
    "With
    -- DCGriz, RBR.
    And you've never heard of 'JRA' either? Not saying the OP is lying but there are many times we don't get the whole story.
    ETA: Kinda bummed I wasted post # 15,000 on this.
    #promechaniclife
    Apr 2018
    You guys crack me up haha roadies are fun.
    Seriously though it was noticed after a 104 mile ride so anything is possible but this isn't my first rodeo and and have nothing to gain by "not providing the whole story" haha fun thread though! I'm not a Conti fanboy or hater, don't really care about the brand name whatsoever I've just had good luck in the past so I stick with what I know (like most) and what is readily available to me locally.
    .je
    .je is offline
    Reputation: .je's Avatar
    Aug 2012
    The casing being visible through the rubber especially where rubber mold sections meet suggest the casing wasn't well placed in manufacture. However that tire wouldn't come apart in regular use.
    The scratches to the left side of the image and in the numbers say to me that the tire scraped something that tore it.
    Oct 2013
    ... so grov is JRA's alternative presence?
    ... I run Michelin, those conti's are for the birds!
    BANNED
    tlg
    tlg is online now
    May 2011
    Potholes come in all shapes and sizes. He could've caught the edge of a shallow pothole and not even realized it.
    You can run over one of these at a fast speed and barely feel it with the shallow leading and trailing edges, but catch the sidewall on the sharp side.
    Apr 2011
    That shape looks like something ogre may want for his next avatar?
    Banned Sock Puppet
    May 2014
    Not to worry, CX. Before you know it, you will be at 20,000.
    "With
    -- DCGriz, RBR.
    Reputation: ogre's Avatar
    Dec 2005
    Quote Originally Posted by bvber View Post
    Ha Ha! I don't see any creatures trying to escape, but I'll stare at it some more
    Reputation: Oxtox's Avatar
    Aug 2006
    of the dozen sets of Conti 4Ks I've used, only had one sidewall issue, and it was on a Series I tire...nearly new, sidewall developed a weak spot and tore open. simply chalked it up to mfg defect and bought a Series II as a replacement.
    never had any problems with the Series II tires.
    getting ready to mount my first set of 5Ks, expect them to be fine.
    THAT'S a pothole! What is it...3 layers deep?
    #promechaniclife
    tlg
    tlg is online now
    May 2011
    Ha... that's a walk in the park. We call that "rough road".
  1. What would you do if you had this happen to you?
    By aliensporebomb in forum The Lounge
    Last Post: 02-10-2011, 06:10 PM
  2. Well it had to happen...The Streetfire
    By stunzeed in forum BMC
    Last Post: 09-28-2008, 12:27 AM
  3. Anyone had this happen?
    By fastpedaler in forum Components, Wrenching
    Last Post: 05-15-2008, 02:55 AM
  4. Anyone had this happen before?
    By gray8110 in forum Components, Wrenching
    Last Post: 05-30-2005, 11:45 AM
  5. Had to happen sometime (ride report)
    By hayaku in forum General Cycling Discussion
    Last Post: 04-05-2004, 07:07 AM
