Asym Rim on Single Speed Hub
Results 1 to 5 of 5
    If you had to use a asym Rim on the back Of Single Speed MTB wheel. Would you offset it left or Right?
    With Offset right like it would be on a normal hub, makes NDs 100% and Drive Side 82%. The other way is NDS 94%, drive side 100%. FWIW. I think it would look a bit more normal offset right, but Im giving up 12% on drive side. Its 4.5 mm offset. With tension this close, Is it really going make much difference?
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I really don't see what the purpose of doing this would be. Asym rims make a bit of sense with an 11 speed freehub where tension disparities are significant. Otherwise, it's a solution to a problem that doesn't exist.
    It should also be noted that even in the case of a wheel with an 11 speed freehub, a good quality rim can take DS tensions around 130kgF. NDS tensions will fall in the 55kgF range which is sufficient tension. I have 6K miles on a wheel I built like this and have never had to re-true the wheel.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Feb 2002
    Quote Originally Posted by Enoch562 View Post
    No. Off-center rims are useful in providing better bracing angles and more even force distribution but with a single-speed wheel, these factors not an issue.
    Please, do me a favor and fight off the urge to comment on ANY of my post. You have no experience, and most of your dribble is some regurgitated dialogue you read some where.
    Banned Sock Puppet
    May 2014
    No experience, dribble, regurgitated dialogue? Certainly you can do better than that.
    Looks like Kerry basically told you the same thing. But hey, go build your single speed wheel with an asym rim if it makes you feel better. Have fun!
    "With
    -- DCGriz, RBR.
  1. Converting 10 speed hub to 11 speed hub.
    By Flexnuphill in forum Components, Wrenching
    Last Post: 06-19-2017, 04:42 AM
  2. Replies: 25
    Last Post: 02-16-2017, 07:19 AM
  3. New Shimano 105 11 Speed hub same size as old 10 speed hub?
    By NorCal FNG in forum Wheels and Tires
    Last Post: 01-17-2015, 09:19 PM
  4. Replies: 16
    Last Post: 03-17-2014, 03:57 PM
  5. Replies: 4
    Last Post: 03-01-2014, 12:32 PM
