Basic wheel truing question
Results 1 to 20 of 20
    pmf
    pmf is offline
    This is a bit embarrassing ... it's been years since I've trued a wheel. I'm having brain [email protected] I guess. Anyhow, if I'm facing the wheel in a stand, with the cassette on the right hand side, if I turn the spoke clockwise (as i look down on it) it makes the spoke tighter, right?
    A wheelist
    It's no different than screwing a nut onto a bolt.
    Reputation: looigi's Avatar
    Nov 2010
    Quote Originally Posted by Mike T. View Post
    Exactly. I find it helpful to think of it as being opposite the left pedal.
    Seriously though. You generally don't turn the spoke, you turn the nipple. The nipple screws onto the spoke like a normal right-handed nut onto a bolt.
    A wheelist
    Quote Originally Posted by looigi View Post
    If the OP grabs a nut and a bolt and holds it to mimic a nipple and spoke, it will be clear which way to turn the "nut" for whatever way you want it to go..
    Reputation: JCavilia's Avatar
    Sep 2005
    At least it should be clear ;-)
    Anyway, presuming he meant "turn the nipple" rather than the "spoke," he was already correct.
    It doesn't matter which side the cassette is on.
    A wheelist
    Quote Originally Posted by JCavilia View Post
    I'd rather have mine on the right
    Apr 2008
    I am confused, the OP asked whether that by turning the nipple clockwise while looking "down" on it that it it tighten the spoke, wouldn't that actually loosen it? I just looked at a youtube video and the nipple got turned counterclockwise to tighten.
    I am probably the last person to have received an email from Sheldon Brown! A very nice gentleman.
    2008 Specialized Roubaix Elite Triple
    105 Shifter/derailleurs
    FSA Gossamer Triple MegaExo
    BWW Blackset Race 11 wheels
    Continental Gators 25c
    Kool Stop Salmon brake pads
    Cateye Strada Double Wireless CC-RD400DW
    Sigma PC-9 HRM
    RADBOT-1000 rear strobe flasher
    Blaze 1/2w LED headlight
    'brifter' is f'ing stupid
    you are correct
    #promechaniclife
    Feb 2003
    With the nipple at the bottom of the wheel, just remember: Righty Tighty, Lefty Loosey and you won't go wrong.
    Nov 2010
    Quote Originally Posted by cdhbrad View Post
    If you're looking down on the nipple from the hub toward the rim and turn the nipple clockwise, the spoke will get looser. You are basically screwing the nipple off the spoke.
    Feb 2003
    Agreed. We are saying the same thing. With a nipple near the bottom of the wheel, just at the feeler guages on most truing stands, and viewing it with the DS on my right, when I turn my spoke wrench toward my right, I am tightening the spoke and a turn to my left loosens the spoke.
    pmf
    pmf is offline
    OK, so to be clear, turning the nipple clockwise as I look down on it tightens the spoke? Does it matter how the wheel is oriented? If the cassette is on the RHS, I'm looking at the wheel from the back (if it were on the bike). Would it be the other way around if the cassette is on the LHS? I'm thinking not.
    Yes, I meant nipple, not spoke. The spoke is not supposed to turn. I did drop some oil on each nipple head to make sure the spoke didn't get wound up. They're bladed spokes, so its easy to see if the spoke turns.
    I can't believe I've completely forgotten this stuff. Years ago I built a few sets of wheels that worked reasonably well.
    c'mon guys, it's not that hard. you're basically screwing a nut onto a bolt, in simple terms. picture that and you'll be fine. if you still can't figure it out, turn it one way and see what happens...if it's what you want to happen, you're good. if not...
    #promechaniclife
    A wheelist
    I told 'em that in a previous post but it didn't do any good.
    Feb 2003
    .....I'm not the one who can't tighten or loosen a spoke as needed.
    Nov 2006
    Never understood "righty tighty". One side moves left, one side moves right!
    If you are struggling with the concept tightening nuts or bolts, "right hand" threads, which are the normal ones, follow the "right hand rule". Put your hand out like you are gonna shake. Curl your fingers in the direction you are turning the nipple. You'll either end up with a "thumbs up" or "thumbs down". The direction your thumb points is the direction that the nipple/bolt/nut moves.
    Sep 2005
    Still not clear. I don't know what you mean by "look down on it." Are you looking at a nipple that's on the far side of the wheel, so that you're looking past the hub at it? Clockwise would loosen in that event. Like you're looking at a nut from the bolt-head end, so turning clockwise moves the nut away from you, thus away from the bolt head, thus loosening it.
    Never mind. Just think as Mike and cx advised you. It's a nut, threading onto a bolt (the spoke) in the normal right-had fashion. If you thread it on further, it shortens (tightens, pulls on) the spoke.
    cdh, my truing stand has its feeler gauges up at eye level, close to me. when I adjust a nipple that's near the gauge, I'm looking "down" on the spoke "through" the rim (so to speak). In that position, clockwise tightens.
    I think there was a similar discussion here about cable adjusters a while back. It's all just instinctive to me now, so I have trouble explaining it in words. Hands on, I'm confident I could make just about anybody get it in 30 seconds.
    Feb 2003
    Leave it to a couple of lawyers to totally confuse a simple subject with too many words. Bolt+ Nut+ Tighten: I understand.
    cmg
    cmg is offline
    Reputation: cmg's Avatar
    Oct 2004
    another stupid question. Do you only lossen or tighten the spokes on the drive side?
    Quote Originally Posted by cmg View Post
    depends...on tension, and what the rim is doing. there is no way to answer a question like that in such general terms. you need to check the tension, then look at what direction the rim is going. most of the time the rim isn't just moving purely side-to-side, it will have some vertical movement as well.
    #promechaniclife
  1. Wheel truing question.
    By tikitorchfriday in forum Components, Wrenching
    Last Post: 08-15-2007, 12:47 AM
  2. Basic wheel upgrade question
    By rochrunner in forum Wheels and Tires
    Last Post: 03-20-2007, 07:56 PM
  3. wheel truing
    By bas in forum Components, Wrenching
    Last Post: 04-24-2006, 07:10 PM
  4. Wheel truing 101
    By CBar in forum Beginner's Corner
    Last Post: 06-17-2005, 05:47 PM
  5. Wheel Truing...
    By pr0230 in forum General Cycling Discussion
    Last Post: 08-05-2004, 11:19 AM
