Best 700x32c tires for road use.
Results 1 to 25 of 37
    Jun 2018
    Hello All,
    I have been riding my ďAll-RoadĒ bike with Maxxis Ramblers 700x38c and itís time to replace them. I originally put the 38s on it thinking I will be doing more gravel rides, but in reality I have been riding road most of the time.
    So, Iím looking at 700x32c tires (without knobs) in an effort to gain more speed and still keep some comfort.
    Of course, Iím searching for durability, high mileage use, with some flat protection.
    I searched the forum but most of the threads on this topic are old.
    Please advise. Thanks.
    'brifter' is f'ing stupid
    Conti GP5000 but as far as I know the 32mm isn't available yet. Obviously this is a highly subjective question, so bear that in mind.
    #promechaniclife
    Reputation: velodog's Avatar
    Sep 2007
    Have a look see at Compass\Rene Herse tires. They're damn fine riding tires.
    Too old to ride plastic
    Jun 2005
    Soma Supple Vitesse EX-K 700c x 33 light with a Kevlar bead and good flat protection. They ride really well and corner well
    Excellent tires.
    #promechaniclife
    Oct 2017
    I also love Compass tires on the road. I have 32mm and 38mm for various purposes, and love them.
    Reputation: Srode's Avatar
    Aug 2012
    This, I have a set of 35mm I use on my gravel bike for regular road use - very nice.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Jun 2018
    Thanks for your responses so far. Keep them coming.
    I need to take a look at the Compass tires mentioned here.
    changingleaf
    Aug 2009
    The Maxxis Re-fuse 32mm has such a tiny tread that's it's a good road tire and gives you a little traction in wet and has some flat protection.
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Bontrager AW3 Hard-case Lite or the R3 TLR line Hard-case Lite.
    Nov 2014
    Panaracer Gravel King come in a 32, Panaracer also makes the Compass and Soma tires that were previously referenced.
    https://www.panaracer.com/lineup/gravel.html
    Jun 2018
    Quote Originally Posted by changingleaf View Post
    I looked at the Re-Fuse but there are not too many reviews out there. I guess they are not as popular as their MTB tires.
    How durable are they? How well do they roll?
    Jun 2018
    Quote Originally Posted by harryman View Post
    The Gravel Kings (non SK) are popular tires but some say they wear fast.
    Jun 2018
    Quote Originally Posted by GlobalGuy View Post
    The only thing I am not sure about is the 120 tpi.
    I prefer 60 tpi for its durability compared to 120 tpi.
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by j102 View Post
    Umm,,,,you know that 120 threads per inch is gonna be more durable than 60 threads per inch, dont'cha? More than likely, the only difference is that the one has twice the fabric layers.....
    "L'enfer, c'est les autres"
    Jun 2018
    I thought it was the other way around. 60 tpi more durable.
    Sep 2007
    It kinda depends.
    How heavy are the threads used, how tightly are they woven, what is the tire construction, what are the threads(cotton, nylon, silk, other)? Typically 60 per inch are cheaper tires are heavier with thicker threads but like No Time says often 120 tpi comes from the tire construction where the fabric overlaps creating 2 layers at 120tpi maybe a 3rd wrap at 180tpi. Not always the case tho. Compass tires doesn't really advertise their thread count stating that they get their suppleness from a looser weave.
    Even if a higher end tire gets it's higher thread count from adding up each wrap the thread is most highly a finer thread less tightly woven. How does the manufacturer arrive at their thread count?
    But another thing that makes a cheaper tire more durable is the amount of rubber used, thicker stiffer tread.
    I have found, since going to larger tires, that durability has risen. A larger contact patch distributes the weight over more of the tread causing less wear. Also the lower pressure used allows the tire to deflect and rollover the debris where as a lower volume higher pressure tire has more of a tendency to pound the debris into the tire, causing a flat.
    Jun 2018
    It kinda depends.
    Thanks. Make sense.
    Iím going in the other direction: from 38s to 32s. Not much of a difference, but somehow going to smaller tires, with less contact area, and probably higher air pressures; thus the reason durability is part of the equation.
    Reputation: Rogus's Avatar
    Nov 2010
    I expect you're not going tubeless, but I am very pleased with my first tubeless tire experience using Hutchinson Sector 32s.
    Jun 2015
    The 120 tpi are arguably more durable on good roads than 60 tpi. One thing for sure is that IMO the 120 tpi ride nicer than the 60 tpi.
    Jun 2018
    Quote Originally Posted by Rogus View Post
    On my MTB yes. But no, I have not considered going tubeless on the road tires. I donít think I will.
    Jun 2018
    The 120 tpi are arguably more durable on good roads than 60 tpi. One thin for sure is that IMO the 120 tpi ride nicer than the 60 tpi.
    Thanks. I guess I have to reconsider my options.
    Jul 2018
    No complaints with my Roubaix 32's, but I have not used another tire in this size. I have them set up tubeless, and run about 50-55psi. Fast and comfortable.
    Dec 2011
    Continental Grand Prix 4000 All Season tires work great. I have no experience with the new 5000 series, but I am sure they are also very good.
    Reputation: 4slomo's Avatar
    Feb 2008
    Continental Gator Hardshell 32C tires for durability in desert climate. Rubber is too hard for wet conditions.
  1. Recommended tubeless tire for heavy rider? 700x32c
    By dirtiClydesdale in forum Wheels and Tires
    Last Post: 04-13-2017, 09:20 AM
  2. Replies: 0
    Last Post: 10-16-2015, 04:17 PM
  3. Replies: 11
    Last Post: 03-04-2014, 08:46 PM
  4. goin from a 622x37 Conti Contact to a 700x32C Pasela
    By gutfiddle in forum Commuting, Touring and Ride Reports
    Last Post: 08-19-2009, 06:14 AM
  5. tires, tires, tires
    By sparky821 in forum Commuting, Touring and Ride Reports
    Last Post: 01-22-2008, 03:39 PM
