Bontrager TLR Rimstrips with Tubes?
Results 1 to 12 of 12
    Jun 2014
    Hey All,
    I have a set of Bontrager Aeolus Comp 5 TLR wheels. The front wheel has been a pain in the d!ck and won't hold air so I'm giving up for now. I was wondering if I could run a tube fulltime with the TLR rim strip still installed or does it need to be removed and install a standard strip or tape?
    Thanks,
    Lew
    Reputation: Srode's Avatar
    Aug 2012
    Sure, I do it on one wheelset, not a problem at all.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: Nessism's Avatar
    Quote Originally Posted by Sweet Lew View Post
    Hey All,
    Thanks,
    Lew
    The reason for rim strips (on tube applications) is to keep the tube from expanding into the nipple cutouts and getting cut. I don't think it matters what kind of rim strip you use as long as it accomplishes that task.
    Jun 2014
    Thanks for the replies! Glad it can stay in. Per Bontrager, if you remove it, they recommend replacing it, and at $20 each, I'd rather not.
    Dec 2005
    When I replaced the stock bontrager tires on my Aeolus 3s with Corsa Gs, it was extremely difficult to mount the new tires without switching to standard rim tape. I got one tire mounted with great difficulty but couldnít finish the other one. I guess you wonít know until you try it. I didnít want to deal with it if I flatted on a ride so changed the rim tape on the first wheel I had successfully changed.
    Sep 2011
    Just get Scotch 8898 tape for $6/roll of 55m.
    I just bought and used some of this. Went around 1X but now wondering it I should have gone twice?
    Jul 2017
    Maybe old news...but I've found is easier to seal difficult tubeless setups after a few days mounted with tubes. I just break one side lose so I can slide out the tube.
    Good luck!
    Sep 2011
    Quote Originally Posted by Nessism View Post
    hmm so how did 1x around work out for you?
    Jun 2014
    Quote Originally Posted by JBarney View Post
    Good luck!
    Thanks for the tip. I unfortunately mangled the Bontrager TLR rim strip trying to get their AW2 TLR tire back on. I ended up ripping it out and just used their standard rim strip and a non TLR tire. Can't stand proprietary crap.
    Went back in and redid it with 2x based on info gathered on the internet. The depressions in the tape over the nipple cutout holes was pretty deep.
    Sep 2011
    I've used it 1x on my Hed belgium plus and yeah the depression is deep, but no tube has ever actually went thru the depression for me after all these years (still on the same tape after 3 years). But hey 2x is safer and tape cost is cheap.
  1. Bontrager Aura 5/Aura 5 TLR
    By Justin222729 in forum Wheels and Tires
    Last Post: 04-03-2014, 06:49 AM
  2. bontrager rxl tlr or hed ardennes lt
    By luwabra in forum Wheels and Tires
    Last Post: 03-03-2014, 01:21 PM
  3. Leaky Bontrager R2 TLR tires
    By cooskull in forum Wheels and Tires
    Last Post: 11-30-2013, 10:09 AM
  4. Looking for Bontrager R3 TLR 25c measurement on a 23mm rim...
    By alansmithee in forum Wheels and Tires
    Last Post: 10-17-2013, 05:11 PM
  5. Tubeless Conversion with Stans Rimstrips
    By jpick915 in forum Cyclocross
    Last Post: 08-14-2012, 09:09 AM
